查看: 2784|回复: 2
状态机,和非状态机的差别
HDL 发表于 2010-6-26 01:38:22 | 显示全部楼层 |阅读模式
状态机,和非状态机的差别
状态机的下降沿检测
Library IEEE;
Use        IEEE.Std_Logic_1164.All;
Entity OZT Is
Port (
        CLK : In Std_Logic;
        Rst : In Std_Logic;
        Din    : In Std_Logic;
        Dut : Out Std_Logic
End OZT;
Architecture OZT_Arc Of OZT Is
Type State Is (ZZ,ZO,OZ,OO);
Signal Pres_S : State;
Begin
Process (Rst,Pres_S,Din,CLK)
Begin
If Rst='1' Then
    Pres_S<=ZZ;
    Dut<='0';
Elsif Clk'Event And Clk='0' Then
Case Pres_S Is
    When ZZ=>
        If Din='1' Then
        Pres_S<=Zo;
        Else
        Pres_S<=ZZ;
        End IF;
    When Zo=>
        If Din='1' Then
            Pres_S<=Oo;
        Else
            Pres_S<=OZ;
        End If;
    When OZ=>
        If Din ='1' Then
            Pres_S<=Zo;
        Else
            Pres_S<=ZZ;
        End If;
    When OO=>
        If Din ='1' Then
            Pres_S<=Oo;
        Else
            Pres_S<=OZ;
        End If;
    End CAse;
End If;
If Pres_S=OZ Then
    Dut<='1';
Else Dut<='0';
End If;
End Process;
End OZT_Arc;
没有使用状态机 的下降沿检测,
Library IEEE;
Use        IEEE.Std_Logic_UnSigned.All;
Use     IEEE.Std_Logic_Arith.all;
Entity OZT Is
Port(
    CLK : In Std_Logic;
    Rst : In Std_Logic;
    Lod : Out Std_Logic;
    STSK : In Std_Logic);
End OZT;
Signal Lot : STd_Logic_vector(0 To 1);
Begin
Process(Rst,CLk,Lot,sTSK)
Begin
If Rst='1' Then Lot<="00";
ElsIf Clk'Event And Clk='0' Then
Case Lot Is
When "00"=>
    If Stsk='1' Then Lot<="01";
    Else Lot<="00";
    End If;
When "01"=>
    Else Lot<="10";
    End IF;
When "10"=>
    Else Lot<="00";
    End IF;
When "11"=>
    If Stsk='1' Then Lot<="11";
    Else Lot<="10";
    End IF;
End Case;
End If;
End Process;
Lod<=(Not Lot(1)) And Lot(0);
End OZT_Arc;
大鹏 发表于 2020-7-1 17:24:42 | 显示全部楼层
状态机,和非状态机的差别
大鹏 发表于 2020-7-15 18:58:14 | 显示全部楼层
状态机,和非状态机的差别
GMT+8, 2026-5-22 15:42 , Processed in 0.033510 second(s), 24 queries .
