查看: 7591|回复: 15
请教一个状态机进行序列检测的问题
VVC 发表于 2010-6-26 00:31:18 | 显示全部楼层 |阅读模式
以前没有接收过这方面的系统训练,不太确定自己想的对不对。
我想实现对序列 11011进行检测,
绘制的状态转换图见附件
VHDL代码如后所示
该代码在QuartusII中综合后得到的RTL图与我这里设计的似乎不一样
请高手指教
谢谢
library ieee;
use ieee.std_logic_1164.all;
entity checksequ is
    port(clk    :    in    std_logic;
        rst        :    in    std_logic;
        din        :    in    std_logic;
        dout    :    out    std_logic);
end checksequ;
architecture behav of checksequ is
    type state is (S5, S4,S3, S2, S1, S0);
    signal CurState    :    state;
    signal NextState:    state;
BEGIN
    process( clk, rst)
        if rst = '1' then
            CurState <= S0;
        elsif clk'event and clk = '1' then
            CurState <= NextState;
        end if;
    end process;
    PROCESS (clk, rst)
    BEGIN
        IF clk'EVENT AND clk = '1' THEN
            CASE CurState IS
                WHEN S0 =>
                    IF din = '1'THEN
                        NextState <= S1;
                        dout <= '0';
                    ELSE
                        NextState <= S0;
                        dout <= '0';
                    END IF;
                WHEN S1 =>
                    IF din = '1'THEN
                        NextState <= S2;
                        dout <= '0';
                    ELSE
                        NextState <= S0;
                        dout <= '0';
                    END IF;
                WHEN S2 =>
                    IF din = '0'THEN
                        NextState <= S3;
                        dout <= '0';
                    ELSE
                        NextState <= S2;
                        dout <= '0';
                    END IF;
                WHEN S3 =>
                    IF din = '1'THEN
                        NextState <= S4;
                        dout <= '0';
                    ELSE
                        NextState <= S0;
                        dout <= '0';
                    END IF;
                WHEN S4 =>
                    IF din = '1'THEN
                        NextState <= S5;
                        dout <= '1';
                    ELSE
                        NextState <= S0;
                        dout <= '0';
                    END IF;
                WHEN S5 =>
                    IF din = '1'THEN
                        NextState <= S5;
                        dout <= '0';
                    ELSE
                        NextState <= S3;
                        dout <= '0';
                    END IF;
            END CASE;
        END IF;
    END PROCESS;
END behav;
interi 发表于 2010-6-26 01:11:48 | 显示全部楼层
基本上就是这样了,&lt;EDA实用教程&gt;里有这个例子.<br>
异步复位在第二个进程里没有用啊.
interi 发表于 2010-6-26 03:03:11 | 显示全部楼层
o ,我觉得第二个进程没有必要再用rst了的吧?<br>
先要了的,后来去掉了,忘了从敏感量列表中去掉了<br>
谢谢您的回复
longt 发表于 2010-6-26 04:48:39 | 显示全部楼层
仿真了一下,上面的代码有点儿错误,其实那个同步的时钟只需要在第一个process中有就可以了<br>
否则仿真结果会不对。<br>
即最后的代码如下:<br>
library ieee;<br>
use ieee.std_logic_1164.all;<br>
&nbsp;&nbsp;<br>
entity checksequ is<br>
&nbsp; &nbsp; &nbsp; &nbsp; port(clk&nbsp; &nbsp; &nbsp; &nbsp; :&nbsp; &nbsp; &nbsp; &nbsp; in&nbsp; &nbsp; &nbsp; &nbsp; std_logic;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; rst&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; :&nbsp; &nbsp; &nbsp; &nbsp; in&nbsp; &nbsp; &nbsp; &nbsp; std_logic;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; din&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; :&nbsp; &nbsp; &nbsp; &nbsp; in&nbsp; &nbsp; &nbsp; &nbsp; std_logic;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; dout&nbsp; &nbsp; &nbsp; &nbsp; :&nbsp; &nbsp; &nbsp; &nbsp; out&nbsp; &nbsp; &nbsp; &nbsp; std_logic);<br>
end checksequ;<br>
<br>
architecture behav of checksequ is<br>
&nbsp; &nbsp; &nbsp; &nbsp; type state is(S5,S4,S3,S2,S1,S0);<br>
&nbsp; &nbsp; &nbsp; &nbsp; signal CurState&nbsp; &nbsp; &nbsp; &nbsp; :&nbsp; &nbsp; &nbsp; &nbsp; state;<br>
&nbsp; &nbsp; &nbsp; &nbsp; signal NextState:&nbsp; &nbsp; &nbsp; &nbsp; state;<br>
BEGIN<br>
&nbsp; &nbsp; &nbsp; &nbsp; process( clk, rst)<br>
&nbsp; &nbsp; &nbsp; &nbsp; begin<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; if rst = '1' then<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; CurState &lt;= S0;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; elsif clk'event and clk = '1' then<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; CurState &lt;= NextState;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; end if;<br>
&nbsp; &nbsp; &nbsp; &nbsp; end process;<br>
&nbsp; &nbsp; &nbsp; &nbsp; <br>
&nbsp; &nbsp; &nbsp; &nbsp; PROCESS (CurState, din)<br>
&nbsp; &nbsp; &nbsp; &nbsp; BEGIN<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; CASE CurState IS<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; WHEN S0 =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; IF din = '1'&nbsp;&nbsp;THEN<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; NextState &lt;= S1;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; dout &lt;= '0';<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; ELSE<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; NextState &lt;= S0;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; END IF;<br>
<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; WHEN S1 =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; NextState &lt;= S2;<br>
<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; WHEN S2 =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; IF din = '0'&nbsp;&nbsp;THEN<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; NextState &lt;= S3;<br>
<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; WHEN S3 =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; NextState &lt;= S4;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; <br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; WHEN S4 =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; NextState &lt;= S5;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; dout &lt;= '1';<br>
<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; WHEN S5 =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; END CASE;<br>
&nbsp; &nbsp; &nbsp; &nbsp; END PROCESS;<br>
<br>
END behav;
HDL 发表于 2010-6-26 05:10:11 | 显示全部楼层
其实还有一种方法是用相关运算得到序列匹配的比特数,这样就可以实现容错检测.当序列比较长的时候,通常是用相关的方法.
ANG 发表于 2010-6-26 06:28:33 | 显示全部楼层
原帖由 myxxyy 于 2006-4-8 18:20 发表<br>
其实还有一种方法是用相关运算得到序列匹配的比特数,这样就可以实现容错检测.当序列比较长的时候,通常是用相关的方法. 能否给个实际的例子或者介绍性资料? 谢谢
tim 发表于 2010-6-26 06:31:31 | 显示全部楼层
状态机我一直就没有领会其精髓
ngtim 发表于 2010-6-26 08:24:09 | 显示全部楼层
这么简单的检测还要用状态机啊?
usb 发表于 2010-6-26 09:35:15 | 显示全部楼层
这么简单的检测还要用状态机啊? <br>
<br>
----------<br>
那你说说看
VVIC 发表于 2010-6-26 11:17:38 | 显示全部楼层
原帖由 caesar000 于 2006-4-11 09:17 发表<br>
这么简单的检测还要用状态机啊? 当然可以不用状态机,对于这么简单的检测,可以采用下面的代码就可以了(当然或许大侠还有更精炼的,希望不吝赐教)<br>
我当时是为了练习状态机而写的,其实最初我写的代码大概是下面这个样子,希望再给予指点指点,我是初学者<br>
<br>
library ieee;<br>
&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;port(clk :&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;in&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; rst :&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;in&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; din :&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;in&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;dout :&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;out&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;std_logic);<br>
end checksequ;<br>
<br>
&nbsp; &nbsp; &nbsp; &nbsp; signal regshift&nbsp; &nbsp; &nbsp; &nbsp; :&nbsp; &nbsp; &nbsp; &nbsp; std_logic_vector(4 downto 0);<br>
begin<br>
&nbsp; &nbsp; &nbsp; &nbsp; process(clk, rst)<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; if rst = '0' then<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; regshift &lt;= "00000";<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; regshift(4 downto 1) &lt;= regshift(3 downto 0);<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; regshift(0) &lt;= din;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; if regshift = "11011" then<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; else<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; end if;<br>
end behav;
GMT+8, 2026-5-23 06:08 , Processed in 0.043485 second(s), 24 queries .
