查看: 2767|回复: 4
哪位大虾帮忙找找这个状态机程序的错(VHDL)
interi 发表于 2010-6-26 01:40:22 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
entity moore2 is port(
  clk, rst:   in std_logic;
  id:     in std_logic_vector(3 downto 0);
  y:    out std_logic_vector(2 downto 0));
end moore2;
architecture archmoore2 of moore2 is
  signal state,next_state: std_logic_vector(2 downto 0);
constant state0: std_logic_vector(2 downto 0) := "000";
constant state1: std_logic_vector(2 downto 0) := "010";
constant state2: std_logic_vector(2 downto 0) := "011";
constant state3: std_logic_vector(2 downto 0) := "110";
constant state4: std_logic_vector(2 downto 0) := "111";
a:process(clk,rst)
        if (rst='1') then
        state<=state0;
        elsif(clk'event and clk='1')then
        state<=next_state;
        end if;
    end process    ;
b: process (state, rst)
      if (rst='1') then
        state <= state0;
      end if;
        case state is
          when state0 =>
              if id = x"3" then
                next_state <= state1;
                next_state <= state0;
              end if;
          when state1 =>
              next_state <= state2;
          when state2 =>
              if id = x"7" then
                next_state <= state3;
              end if;
          when state3 =>
              if id < x"7" then
              elsif id = x"9" then
                next_state <= state4;
              end if;
          when state4 =>
              if id = x"b" then
              end if;
          when others =>
        end case;
  end process;
y <= state(2 downto 0);
end archmoore2;
用quartus编译后的错误信息:
Error: Can't resolve multiple constant drivers for net "state[2]" at moore2.vhd(22)
Error: Constant driver at moore2.vhd(30)
Error: Can't elaborate top-level user hierarchy
我是新手请多指教
ups 发表于 2010-6-26 03:36:34 | 显示全部楼层
两个process中有相同变量的赋值吧。
HDL 发表于 2010-6-26 04:51:30 | 显示全部楼层
谢谢喽!!!
UFP 发表于 2010-6-26 05:36:48 | 显示全部楼层
把沿的变化放在elsif后也不好吧
Sunlife 发表于 2015-6-17 10:46:07 | 显示全部楼层
GMT+8, 2026-5-23 07:48 , Processed in 0.047298 second(s), 24 queries .
