查看: 2285|回复: 3
【求助】:高手帮忙看看我的vhdl程序问题出在什么地方
HDL 发表于 2010-6-26 00:43:49 | 显示全部楼层 |阅读模式
用vhdl编了一个控制cpu接口读写数据的程序。
不知道里面的状态机设置有没有问题
p.s.:可以这样描述一个进程吗?ncpu_rdy_reg不是周期信号,我想取他的下降沿。
process(np_sp_clk_reg ,ncpu_rdy_reg)
    if rising_edge(np_sp_clk_reg) or falling_edge(ncpu_rdy_reg) then
        present_state<=next_state;
       end if;
end process;
ngtim 发表于 2010-6-26 01:29:12 | 显示全部楼层
library IEEE;<br>
use IEEE.STD_LOGIC_1164.ALL;<br>
use IEEE.STD_LOGIC_ARITH.ALL;<br>
use IEEE.STD_LOGIC_UNSIGNED.ALL;<br>
<br>
entity test is<br>
&nbsp; &nbsp; port (&nbsp; &nbsp;&nbsp;&nbsp;<br>
&nbsp; &nbsp; &nbsp; &nbsp; nCPU_RDY:&nbsp; &nbsp; in std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; <br>
&nbsp; &nbsp; &nbsp; &nbsp; NP_SP_CLK&nbsp; &nbsp; : in std_logic;&nbsp;&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; <br>
&nbsp; &nbsp; &nbsp; &nbsp; nIF_SP_RESET : in std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;<br>
&nbsp; &nbsp; &nbsp; &nbsp; nCPU_CS&nbsp; &nbsp;&nbsp; &nbsp;:&nbsp; &nbsp; out std_logic;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; <br>
&nbsp; &nbsp; &nbsp; &nbsp; CPU_D&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;: inout std_logic_vector(31 downto 0);&nbsp; &nbsp; &nbsp; &nbsp; <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;CPU_A&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;: out std_logic_vector(10 downto 0);&nbsp; &nbsp; &nbsp; &nbsp; <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;nCPU_RD&nbsp; &nbsp;&nbsp; &nbsp;: out std_logic;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; <br>
&nbsp; &nbsp; &nbsp; &nbsp; nCPU_WR&nbsp; &nbsp;&nbsp; &nbsp;: out std_logic;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; <br>
&nbsp; &nbsp; &nbsp; &nbsp; nCPU_WIDTH&nbsp;&nbsp;: out std_logic_vector(1 downto 0);&nbsp; &nbsp; &nbsp; &nbsp; <br>
&nbsp; &nbsp; &nbsp; &nbsp; nCPU_BADD&nbsp;&nbsp;: out std_logic_vector(1 downto 0);&nbsp; &nbsp; &nbsp; &nbsp; <br>
&nbsp; &nbsp; &nbsp; &nbsp; RJ_LED_Y&nbsp; &nbsp;&nbsp;&nbsp;: out std_logic_vector(3 downto 0);&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;RJ_LED_G&nbsp; &nbsp;&nbsp;&nbsp;: out std_logic_vector(3 downto 0);&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;RJ_LEDA_G&nbsp; &nbsp; : out std_logic_vector(3 downto 0);&nbsp; &nbsp;&nbsp; &nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;RJ_LED_EN : out std_logic&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;);<br>
end test;<br>
<br>
architecture rtl of test is<br>
type state_type is (idle,wr_add,wr_cs_assert,wr_wr_assert,wr_data,wr_wr_deassert,judge_wr_rdy,wr_cs_deassert,wr_data_deassert,rd_cs_assert,rd_rd_assert,rd_fetch_data,judge_rd_rdy,rd_wait_deassert,rd_rd_deassert,rd_cs_deassert);<br>
<br>
signal&nbsp;&nbsp;present_state,next_state : state_type;<br>
signal&nbsp;&nbsp;read_data_reg : std_logic_vector(31 downto 0);<br>
<br>
signal ready : std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;--ready for write and read<br>
<br>
<br>
begin<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; nCPU_WR&lt;='1';<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; nCPU_RD&lt;='1';<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; nCPU_CS&lt;='1';<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; CPU_A&lt;="11111111111";<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; CPU_D&lt;="00000000000000000000000000000000";<br>
<br>
&nbsp; &nbsp; &nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; nCPU_WIDTH&lt;="11";&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--32-bit mode<br>
&nbsp; &nbsp; &nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;nCPU_BADD&lt;="00";&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --little endian [31:0]<br>
&nbsp; &nbsp; &nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; ready&lt;='1';<br>
-----------------write and read--------------------<br>
process(present_state,ready,CPU_D,nCPU_RDY, nIF_SP_RESET)&nbsp; &nbsp; &nbsp; &nbsp; <br>
begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --need initial state <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if nIF_SP_RESET = '0' then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;next_state&lt;=idle;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else<br>
&nbsp; &nbsp; &nbsp; &nbsp; case present_state is<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when idle =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; if ready='1' then<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=wr_add;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; else <br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=idle;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; end if;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when wr_add =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; CPU_A&lt;="10100000001";&nbsp; &nbsp;&nbsp; &nbsp;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=wr_cs_assert;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when wr_cs_assert =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; nCPU_CS&lt;='0';<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=wr_wr_assert;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when wr_wr_assert =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; nCPU_WR&lt;='0';<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=wr_data;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when wr_data =&gt;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; <br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; CPU_D&lt;="00000000000000000000000000001111";&nbsp; &nbsp;&nbsp; &nbsp;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=wr_wr_deassert;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when wr_wr_deassert =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=judge_wr_rdy;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when judge_wr_rdy =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; if nCPU_RDY='0' then<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=wr_cs_deassert;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=judge_wr_rdy;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when wr_cs_deassert =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=wr_data_deassert;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when wr_data_deassert =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when&nbsp;&nbsp;rd_cs_assert =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=rd_rd_assert;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when rd_rd_assert =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; nCPU_RD&lt;='0';<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=rd_fetch_data;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when rd_fetch_data =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; read_data_reg&lt;=CPU_D;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=judge_rd_rdy;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when judge_rd_rdy =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=rd_wait_deassert;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=judge_rd_rdy;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when rd_wait_deassert =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=rd_rd_deassert;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when rd_rd_deassert =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; next_state&lt;=rd_cs_deassert;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when rd_cs_deassert =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; ready&lt;='0';<br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; when others =&gt;<br>
&nbsp; &nbsp; &nbsp; &nbsp; end case;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;end if;<br>
end process;<br>
<br>
process(NP_SP_CLK,nCPU_RDY)<br>
begin<br>
&nbsp; &nbsp; &nbsp; &nbsp; if rising_edge(NP_SP_CLK) or falling_edge(nCPU_RDY) then <br>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; present_state&lt;=next_state;<br>
end process;<br>
-----------------------------------------------decode----------------------------------<br>
&nbsp; &nbsp; &nbsp; &nbsp; RJ_LED_EN&lt;='0';<br>
&nbsp; &nbsp; &nbsp; &nbsp; RJ_LED_Y&lt;=read_data_reg(1 DOWNTO 0) &amp;read_data_reg(7 DOWNTO 6) ;<br>
&nbsp; &nbsp; &nbsp; &nbsp; RJ_LED_G&lt;=read_data_reg(5 DOWNTO 4) &amp;read_data_reg(3 DOWNTO 2);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;RJ_LEDA_G&lt;="1111";<br>
<br>
end rtl;
UFP 发表于 2010-6-26 01:55:25 | 显示全部楼层
问题解决了<br>
原来是在同一个进程里面不能出现两个时钟沿触发<br>
当然这个程序还有其他的bug<br>
不过还没有解决<br>
再接再厉啦<br>
ANG 发表于 2010-6-26 03:33:05 | 显示全部楼层
我开始的时候也经常碰到这种问题
GMT+8, 2026-5-24 06:21 , Processed in 0.032806 second(s), 20 queries .
