查看: 2967|回复: 2
LED控制VHDL程序与仿真
I2C 发表于 2010-4-9 23:16:20 | 显示全部楼层 |阅读模式
FPGA驱动LED静态显示
--文件名:decoder.vhd
--功能:译码输出模块,LED为共阳接法
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity decoder is
Port (seg:in std_logic_vector(3 downto 0 );   --四位二进制码输入
q3ut std_logic_vector(6 downto 0) );   --输出LED七段码
end decoder;
architecture Behavioral of decoder is
         process(seg)
                 case seg is
                      when "0000" => q3<="0000001";--0
                      when "0001" => q3<="1001111";--1
                      when "0010" => q3<="0010010";--2
                      when "0011" => q3<="0000110";--3
                      when "0100" => q3<="1001100" --4
                      when "0101" => q3<="0100100";--5
                      when "0110" => q3<="0100000";--6
                      when "0111" => q3<="0001111";--7
                      when "1000" => q3<="0000000";--8
                      when "1001" => q3<="0000100";--9
                     when others => q3<="1111111";
              end case;
     end process;
end Behavioral;
 楼主| I2C 发表于 2010-4-9 23:16:39 | 显示全部楼层
FPGA驱动LED动态显示(4位)
--文件名:dynamic.vhd。
--功能:动态扫描模块,位选信号高电平有效。
library IEEE;
entity dynamic is
  Port ( clk : in std_logic;
            reset: in std_logic;
            din1 : in std_logic_vector(6 downto 0);       --译码后的数据信号1(4位2进制数据
通过例1中的decoder模块译码得到din1,din2,din3,din4)
            din2 : in std_logic_vector(6 downto 0);       --译码后的数据信号2
            din3 : in std_logic_vector(6 downto 0);       --译码后的数据信号3
            din4 : in std_logic_vector(6 downto 0);       --译码后的数据信号4
           shift: out std_logic_vector(3 downto 0);      --位选信号
           bus4 : out std_logic_vector(6 downto 0));     --数据信号
end dynamic;
architecture Behavioral of dynamic is
     signal scan_clk:std_logic_vector(1 downto 0);
                process(clk,scan_clk,reset)                        --分频进程
                     variable scan:std_logic_vector(17 downto 0);
                                  if reset='1' then
                                        scan:="000000000000000000";
                                        scan_clk<="00";
                                 elsif clk'event and clk='1'then
                                        scan:=scan+1;
                                end if;
       scan_clk<=scan(17 downto 16);
end process;
process(scan_clk,din1,din2,din3,din4)       --扫描进程
           case scan_clk is
                   when "00"=>
                          bus4<=din1;
                         shift<="0001";
                 when "01"=>
                         bus4<=din2;
                         shift<="0010";
                 when "10"=>
                         bus4<=din3;
                         shift<="0100";
                when "11"=>
                         bus4<=din4;
                         shift<="1000";
               when others=> bus4<="0000000";shift<="0000";
       end case;
end process;
end Behavioral;
muyanlong456 发表于 2011-3-19 14:35:44 | 显示全部楼层
请问
2楼是FPGA驱动LED点阵的驱动程序吗?!
GMT+8, 2026-5-24 01:57 , Processed in 0.044659 second(s), 24 queries .
