查看: 3200|回复: 1
one-hot状态机两种编码方式综合成果的比较
CHANG 发表于 2010-6-26 01:48:57 | 显示全部楼层 |阅读模式
1.非index编码方式
`timescale 1ns/10ps
module test_sm(
     clk,
     rst_n,
     state_out
input    clk;
input    rst_n;
output [5:0] state_out;
wire [5:0] state_out;
parameter    U_DLY = 1;
parameter    STATE0 = 6'b000001,
       STATE1 = 6'b000010,
       STATE2 = 6'b000100,
       STATE3 = 6'b001000,
       STATE4 = 6'b010000,
       STATE5 = 6'b100000;
reg [5:0]    current_state;
reg [5:0]    next_state;
assignstate_out = current_state;
//------------------------------state machine---------------------------
  if (rst_n == 1'b0)
  current_state <= STATE0;
  current_state <= #U_DLY next_state;
always @(current_state)
  case (current_state) //synopsys parallel case
  STATE0:
    next_state = STATE1;
  STATE1:
    next_state = STATE2;
  STATE2:
    next_state = STATE3;
  STATE3:
    next_state = STATE4;
  STATE4:
    next_state = STATE5;
  STATE5:
    next_state = STATE0;
  default:
  endcase
2.index编码方式
`timescale 1ns/10ps
module test_sm(
     clk,
     rst_n,
     state_out
input    clk;
input    rst_n;
parameter    STATE0 = 0,
       STATE1 = 1,
       STATE2 = 2,
       STATE3 = 3,
       STATE4 = 4,
       STATE5 = 5;
  if (rst_n == 1'b0)
  current_state <= 6'b1;//because the coding of IDLE is 000001
  next_state = 6'b0;
  case (1'b1) //synopsys parallel case
  current_state[STATE0]:
    next_state[STATE1] = 1'b1;
  current_state[STATE1]:
    next_state[STATE2] = 1'b1;
  current_state[STATE2]:
    next_state[STATE3] = 1'b1;
  current_state[STATE3]:
    next_state[STATE4] = 1'b1;
  current_state[STATE4]:
    next_state[STATE5] = 1'b1;
  current_state[STATE5]:
    next_state[STATE0] = 1'b1;
  endcase
综合工具synplify、quartus4.1,器件用cyclone EP1C4-I7,没有加任务约束。
用synplify的流程为:先在synplify下综合,再导入quartus4.1布局布线。
不用synplify的流程为:直接在quartus4.1下综合。
结果:
a.非index编码:
       资源占用 频率
synplify    6个LE 320M
quartus     10个LE  320M
b.index编码
       资源占用 频率
synplify    6个LE 320M
quartus     7个LE 320M
注:synplify将它综合成移位寄存器了,不过在另外一个用index编码的复杂的状态机中,
它是将其综合成状态机了。synplify可以认index编码的状态机,而quartus似乎不行(通过
rtl viewer来看)
 楼主| CHANG 发表于 2010-6-26 02:37:30 | 显示全部楼层
综合出来的频率相同的原因可能是这状态机较为简单,体现不出差异
GMT+8, 2026-5-24 07:05 , Processed in 0.033650 second(s), 22 queries .
