查看: 2672|回复: 1
我的状态机是怎么回事??
AAT 发表于 2010-6-26 01:35:01 | 显示全部楼层 |阅读模式
大家看看我的程序和仿真的时序,前面的状态机没定义,怎么改?
ENTITY sample_addr_generator IS
    PORT
        clk : in std_logic;        -- 时钟
        le    : in std_logic;        --与采样 计数器连接
        rst: in std_logic;    --复位
        rang: in STD_LOGIC_VECTOR(9 downto 0);    --integer range 0 to 1023;    --计数范围
        addr : out STD_LOGIC_VECTOR(9 downto 0);    --integer range 0 to 1023;    --地址,连到采样缓存的写入地址端
        wr : out std_logic;
        stat : out std_logic    --工作状态,0为可生成地址,1为发生地址已到计数范围,停止工作
END sample_addr_generator;
ARCHITECTURE a OF sample_addr_generator IS
    TYPE STATE_TYPE IS (ST_RST, ST_IDEL,ST_INIT0, ST_INIT1, ST_INIT2, ST_INIT3, ST_LE0, ST_WR, ST_WAIT_LE0 );
    SIGNAL state : STATE_TYPE := ST_IDEL;
    SIGNAL    cqi    : STD_LOGIC_VECTOR(9 downto 0) := "0000000000";    --INTEGER RANGE 0 TO 1023 := 0;
BEGIN
    PROCESS (clk, rst, le, rang)
    BEGIN
        -- 复位
        IF rst = '1' THEN
            stat <= '0';
            cqi <= "0000000000";
            wr <= '0';
            state <= ST_RST;
        ELSIF clk'EVENT AND clk = '1' THEN
            CASE state IS
                -- 空闲状态
                WHEN ST_IDEL =>
                    stat <= '0';
                    cqi<= "0000000000";
                    wr <= '0';
                    state <= ST_IDEL;
                -- 延时等待两个le的周期
                WHEN ST_RST =>
                    IF le= '0' THEN
                        state <= ST_INIT0;
                        state <= ST_RST;
                    END IF;
                WHEN ST_INIT0 =>
                    IF le = '1' THEN
                        state <= ST_INIT1;
                        state <= ST_INIT0;
                    END IF;
                WHEN ST_INIT1=>
                    IF le = '0' THEN
                        state <= ST_INIT2;
                        state <= ST_INIT1;
                    END IF;
                WHEN ST_INIT2 =>
                    IF le = '1' THEN
                        state <= ST_INIT3;
                        state <= ST_INIT2;
                    END IF;
                WHEN ST_INIT3=>
                    IF le = '0' THEN
                        state <= ST_INIT3;
                        state <= ST_LE0;
                    END IF;
                -- 等待le变高好发出wr 信号
                WHEN ST_LE0 =>
                    stat <= '1';
                    IF le= '0' THEN
                        state <= ST_LE0;
                    elsif le = '1' THEN
                        wr <= '1';    -- 发出写脉冲
                        state <= ST_WR;
                    END IF;
                WHEN ST_WR =>
                    -- 发wr信号无效
                    wr <= '0';
                    -- addr 增1
                    cqi <= cqi +1;
                    IF cqi >= rang then
                        stat <= '0';
                        cqi <= "0000000000";            -- 采样个数达到预计值,则进入空闲状态
                        state <= ST_IDEL;
                        state <= ST_WAIT_LE0;    --
                    end if;
                -- 采样个数未达到预计值,等待Le变低
                WHEN ST_WAIT_LE0 =>
                    IF le = '1' THEN
                    ELSE
                        state <= ST_LE0;     -- le ='0',进入下一个写入周期
                    END IF;
                WHEN OTHERS =>
                    stat <= '0';
                    wr <= '0';
                    state <= ST_IDEL;
            END CASE;
        END IF;
    END PROCESS;
    addr <= cqi;
END a;
HANG 发表于 2010-6-26 01:52:05 | 显示全部楼层
从CODE看RST=1之后,状态才有了确定的值。这个不定的值是你的激励造成的(RST信号靠后)。你应从RST=1之后来分析对否。--这个现象不是CODE造成的,是激励造成的。
GMT+8, 2026-5-24 06:20 , Processed in 0.031839 second(s), 22 queries .
