查看: 3511|回复: 6
求助:状态机在高速率下无法正确运行
ATA 发表于 2010-6-26 02:05:21 | 显示全部楼层 |阅读模式
最近写了一个单进程的moore状态机,这个程序后仿真时能够在25MHZ正确运行,但是现在要求运行在77.6MHZ,这时会出现timing violation,并且数据也有错误,dataout信号毛刺很大,无法使用。请各位高人指教,我应当从哪些方面修改呢?
  赶进度,没法向老板交差,谢谢各位了。
  下面是程序:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity xytcl is
  Port ( LR_FIFO_R : outSTD_LOGIC;
   LR_FIFO_Empty : inSTD_LOGIC;
   VI_FIFO_R : outSTD_LOGIC;
   VI_FIFO_Empty : inSTD_LOGIC;
   RP_FIFO_W : outSTD_LOGIC;
   RP_FIFO_Full : inSTD_LOGIC;
   SC1_FIFO_W : outSTD_LOGIC;
   SC1_FIFO_Full : inSTD_LOGIC;
   RP_FIFO_Con : inSTD_LOGIC;
   SC1_FIFO_Con : inSTD_LOGIC;
   SC2_FIFO_W : outSTD_LOGIC;
   SC2_FIFO_Full : inSTD_LOGIC;
   SC2_FIFO_Con : inSTD_LOGIC;
   SC3_FIFO_W : outSTD_LOGIC;
   SC3_FIFO_Full : inSTD_LOGIC;
   SC3_FIFO_Con : inSTD_LOGIC;
   SC4_FIFO_W : outSTD_LOGIC;
   SC4_FIFO_Full : inSTD_LOGIC;
   SC4_FIFO_Con : inSTD_LOGIC;
   SCI_RAM_R : outSTD_LOGIC;
   SCI_RAM_A : outSTD_LOGIC_VECTOR (11 downto 0);
   SCI_RAM_D : inSTD_LOGIC_VECTOR (31 downto 0);
   VI : inSTD_LOGIC_VECTOR (1 downto 0);
   datain : inSTD_LOGIC_VECTOR (63 downto 0);
  dataout : outSTD_LOGIC_VECTOR (63 downto 0);
  clk,rst : in STD_LOGIC
end xytcl;
architecture Behavioral of xytcl is
type my_type is (st0,st1,st2,st3,st4,st5,st6,st7,st8);
signal current_state:my_type;
signal first_read : STD_LOGIC_VECTOR (63 downto 0);
process (clk,rst)
  variable st7_count : INTEGER range 0 to 7;
  if (rst='1') then
  current_state<=st0;
  LR_FIFO_R<='0';
  VI_FIFO_R<='0';
  RP_FIFO_W<='0';
  SC1_FIFO_W<='0';
  SC2_FIFO_W<='0';
  SC3_FIFO_W<='0';
  SC4_FIFO_W<='0';
  SCI_RAM_R<='0';
  SCI_RAM_A<="000000000000";
  dataout<="ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ";
  elsif(clk'event and clk='1')then
  case current_state is
when st0=> if LR_FIFO_Empty='0' then
current_state <= st1;
current_state <= st0;
end if;
RP_FIFO_W<='0';
SC1_FIFO_W<='0';
SC2_FIFO_W<='0';
SC3_FIFO_W<='0';
SC4_FIFO_W<='0';
LR_FIFO_R<='1';
VI_FIFO_R<='1';
LR_FIFO_R<='0';
VI_FIFO_R<='0';
end if;
when st1=>
current_state <= st2;
LR_FIFO_R<='0';
VI_FIFO_R<='0';
RP_FIFO_W<='0';
SC1_FIFO_W<='0';
SC2_FIFO_W<='0';
SC3_FIFO_W<='0';
SC4_FIFO_W<='0';
when st2=>
if datain(35 downto 33)="000" then
current_state <= st7;
current_state <= st3;
end if;
dataout<=datain;
RP_FIFO_W<='1';
LR_FIFO_R<='1';
st7_count:=0;
    RP_FIFO_W<='0';
LR_FIFO_R<='0';
SCI_RAM_A<=CONV_STD_LOGIC_VECTOR(240+(CONV_INTEGER(VI&"00"
+CONV_INTEGER(datain(53 downto 52))),12);
SCI_RAM_R<='1';
end if;
first_read<=datain;
when st3=>
SCI_RAM_R<='0';
current_state <= st4;
when st4=>
if SCI_RAM_D(31)='1' then
current_state <= st5;
end if;
dataout<="0000"&SCI_RAM_D(23 downto 0)&first_read(35 downto 0);
LR_FIFO_R<='1';
st7_count:=0;
case SCI_RAM_D(29 downto 28) is
  when "00"=>SC1_FIFO_W<='1';
  when "01"=>SC2_FIFO_W<='1';
  when "10"=>SC3_FIFO_W<='1';
  when "11"=>SC4_FIFO_W<='1';
  when others => null;
end case;
LR_FIFO_R<='0';
SCI_RAM_R<='1';
SCI_RAM_A<=CONV_STD_LOGIC_VECTOR(CONV_INTEGER(SCI_RAM_D(11 downto 0))+CONV_INTEGER(first_read(43 downto 36)),12);
end if;
when st5=>
SCI_RAM_R<='0';
current_state <= st6;
when st6=>
LR_FIFO_R<='1';
st7_count:=0;
end case;
when st7=>
if st7_count>3 then
current_state <= st8;
end if;
st7_count:=st7_count+1;
when st8=>
if LR_FIFO_Empty='1' then
end if;
LR_FIFO_R<='0';
LR_FIFO_R<='1';
VI_FIFO_R<='1';
end if;
when others => current_state <= st0;
   end case;
   end if;
  end process;
end Behavioral;<a href='http://www.caijiqi.net/cms/taker/helpcenter/discuz7.jsp' target='_blank' title='discuz论坛采集'><img alt='discuz论坛采集' width='1' height='10' border='0' src='http://www.caijiqi.net/ad.gif'></a>
CHA 发表于 2010-6-26 02:43:05 | 显示全部楼层
你这个程序我给你用synplify综合了一下,频率可以工作在接近300M了<br>
应该不是频率的问题
longtim 发表于 2010-6-26 04:41:58 | 显示全部楼层
可是我在ISE下进行后仿真在20多MHZ没问题,到70多MHZ就不行了,出现timing violation,有的信号错,输出的64bit数据dout基本全是毛刺。<br>
&nbsp; &nbsp;&nbsp; &nbsp;请高人指教是怎么回事!!!
AAT 发表于 2010-6-26 06:32:00 | 显示全部楼层
正常, 这是因为你的状态机代码没有写好的缘故. <br>
<br>
唯一解决的方法, 就是逐步去优化你的代码, 找出你代码中的关键路径进行优化分析
CHANG 发表于 2010-6-26 06:56:29 | 显示全部楼层
那么能不能大概提示一下我该从哪些方面入手呢?谢拉。
FFT 发表于 2010-6-26 07:02:52 | 显示全部楼层
我觉得双进程的方式可能更好。。。
Sunlife 发表于 2015-6-17 11:30:35 | 显示全部楼层
GMT+8, 2026-5-23 07:48 , Processed in 0.034343 second(s), 24 queries .
