查看: 2304|回复: 1
我的状态机出现时序滞后,请问高手怎么办
ATA 发表于 2010-6-26 01:17:56 | 显示全部楼层 |阅读模式
程序如下:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity pci9054 is
   port(lhold: in std_logic;
    lholda: out std_logic;
    blast: in std_logic;
    ads: in std_logic;
    lbe: out std_logic_vector(3 downto 0);
    ready: out std_logic;
    dataout: in std_logic_vector(31 downto 0);
    ld: out std_logic_vector(31 downto 0);
    lw_r:in std_logic;
    bterm:in std_logic;
    lreseto:in std_logic;
    lclk:in std_logic
end pci9054;
architecture behav of pci9054 is
signal shift_val:std_logic;
type state is(s0,s1,s2,s3,s4);
  process(blast,lw_r,ads,lclk)
  variable p:state;
    if (lclk'event and lclk='1')then
  case p is
   when s0=>if lhold='0' then
      p:=s0;
      lholda<=lhold;
      ready<='0';
      elsif lhold='1' then
      p:=s1;
      lholda<=lhold;
      ready<='0';
      end if;
   when s1=>if ads='1' then
      p:=s1;
      lholda<=lhold;
      ready<='0';
      elsif(ads='0' and lw_r='0')then
      p:=s3;
      ready<='1';
      elsif(ads='0' and lw_r='1')then
      p:=s2;
      ready<='1';
      elsif lhold='0'then
      p:=s0;
      lholda<=lhold;
      ready<='0';
      end if;
   whens2=>if blast='1' then
      p:=s2;
      ready<='1';
      p:=s4;
      end if;
   when s3=>if blast='1' then
      p:=s3;
      ready<='1';
      p:=s4;
      end if;
   when s4=>if( lhold='1' and blast='0') then
      p:=s1;
      lholda<=lhold;
      ready<='0';
      elsif( lhold='0' )then
      p:=s0;
      lholda<=lhold;
      ready<='0';
      end if;
   when others=>null;
   end case;
  end if;
end process ;
end behav;
     我想让lholda跟随lhold变化,但实际上仿真结果是其滞后了三个周期,ready也是如此,请问高手怎么办,并且如果我想让lreseto变高后再进入状态0即初始状态,应该如何更改语句。谢谢!
longtim 发表于 2010-6-26 03:05:06 | 显示全部楼层
3 cycles? you must be kidding
GMT+8, 2026-5-24 06:20 , Processed in 0.031836 second(s), 22 queries .
