查看: 2524|回复: 0
求助,不能综合,大家帮忙看一下谢谢1
AAT 发表于 2010-6-26 01:19:56 | 显示全部楼层 |阅读模式
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity test is
generic(width:integer:=16);
Port (trig: inSTD_LOGIC;
   resetn : inSTD_LOGIC;
   CS : inSTD_LOGIC;
Slk: inSTD_LOGIC;
   Dout : outSTD_LOGIC;
   ACK : inoutSTD_LOGIC);
end test;
architecture Behavioral of test is
signal shift_buf: std_logic_vector(width-1 downto 0);
loadshift:process(resetn,trig,count_outQ)
  if resetn='0' then
   shift_buf<=(others=>'0');
elsif (ACK='1') then
  shift_buf<=count_outQ;
end if;
end process loadshift;
shifter:process(Slk)
if (Slk'event and Slk='1') then
elsif CS='1' then
  shift_buf<=shl(shift_buf,"1");
  shift_buf(0)<='0';
   end if;
end process shifter;
   Dout<=shift_buf(width-1);
end behavioral;
提示错误:Signal shift_buf<10> cannot be synthesized, bad synchronous description.
大家帮忙看一下谢谢!该程序的简单功能就是计数器的结果并入移位寄存器,然后是移位输出受到外部信号slk和总线使能信号cs的控制输出,
不受其他控制
GMT+8, 2026-5-24 06:20 , Processed in 0.030687 second(s), 20 queries .
