查看: 2413|回复: 3
VHDL syntax error at counter10.vhd(32) near
CTT 发表于 2010-6-27 23:21:14 | 显示全部楼层 |阅读模式
Error (10500): VHDL syntax error at counter10.vhd(32) near text "process";expecting "if"
就是说
end process;
这句话有问题
我的源程序如下:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity counter10 is
   port (clk:in std_logic;
     reset:in std_logic;
     din:in std_logic_vector(3 downto 0);
     dout
ut std_logic_vector(3 downto 0);
     c
ut std_logic);
end counter10;
architecture Behavioral of counter10 is
signal count:std_logic_vector(3 downto 0);
dout<=count;
process(clk,reset,din)
if reset='0' then
  count<=din;
  c<='0';
  else if rising_edge(clk) then
    if count="1001" then
     count<="0000";
     c<='1';
     count<=count+1;
     c<='0';
     end if;
   end if;
end process;
end Behavioral;
请帮忙指点一下怎么改
interi 发表于 2010-6-28 01:10:29 | 显示全部楼层
错误很简单!<br>
但不太容易看!<br>
错误就是 ELSE IF<br>
要么改成IF-ELSIF-END IF组合<br>
要么再加一个END IF;
usb 发表于 2010-6-28 02:34:13 | 显示全部楼层
else if 改成 ELSIF 啊~~~~~~~<br>
elsif rising_edge(clk) then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;elsif count="1001" then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;count&lt;="0000";<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;c&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; else<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;count&lt;=count+1;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;c&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; end if;
interig 发表于 2010-6-28 03:55:15 | 显示全部楼层
我在软件上试了一下,这样可以运行,本人也是刚学maxplus2的菜鸟啊~~~~~~<br>
library ieee;<br>
use ieee.std_logic_1164.all;<br>
use ieee.std_logic_arith.all;<br>
use ieee.std_logic_unsigned.all;<br>
entity counter10 is<br>
&nbsp; &nbsp;&nbsp; &nbsp; port (clk:in std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; reset:in std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; din:in std_logic_vector(3 downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; dout
ut std_logic_vector(3 downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; c
ut std_logic);<br>
end counter10;<br>
<br>
architecture Behavioral of counter10 is<br>
&nbsp; &nbsp;&nbsp;&nbsp;signal count:std_logic_vector(3 downto 0);<br>
begin<br>
&nbsp; &nbsp;&nbsp;&nbsp;dout&lt;=count;<br>
<br>
process(clk)<br>
begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if rising_edge(clk) then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if count="1001" then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; end if;<br>
end process;<br>
end Behavioral;
GMT+8, 2026-5-24 07:05 , Processed in 0.032085 second(s), 20 queries .
