查看: 2223|回复: 4
关于XC3S400控制adc采样问题
ups 发表于 2010-6-27 23:54:28 | 显示全部楼层 |阅读模式
编译后报错next_state不能综合,请大家指教。
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity test is
port(
    clk,busy: in std_logic;                         -- Clock, nominally 50 MHz
    data: in std_logic_Vector(15 downto 0);    -- data from adc
    convst,rd,cs: out std_logic
end test;
architecture Behavioral of test is
type states is ( st0,st1,st2,st3,st4,st5,st6,st7,st8,st9,st10,st11,st12,st13,st14,st15,st16);--定义各状态的子类型
signal current_state, next_state: states :=st16;
signal regl1 :std_logic_vector(15 downto 0);--中间数据寄存信号1
signal regl2 :std_logic_vector(15 downto 0);--中间数据寄存信号2
signal clk_5M: STD_LOGIC:='0';
signal start_adc: STD_LOGIC:='0';
signal con_sample: STD_LOGIC:='0';
signal init_count: STD_LOGIC:='0';
-------------------system use 500 divisior to make 10us to enable adc to convert----------
divisor1: process(clk)                                --10分频
variable counter : integer range 0 to 5:=0;
if(clk'event and clk = '1')    then
    current_state <= next_state;
    if(counter = 5)    then
        clk_5M <= not clk_5M;
        counter := 0;
        counter := counter + 1;
    end if;
end if;
end process divisor1;
divisor2: process(clk_5M)                                --50分频与10分频一起使用,用于定时采样,定时时间为10us
variable counter : integer range 0 to 25:=0;
if(clk_5M'event and clk_5M = '1')    then
    if(counter = 25)    then
        start_adc <= not start_adc;                     --Timer 10us enable ADC
        counter := 0;
    end if;
end if;
end process divisor2;
divisor3: process(clk)                                    --150分频3us时间用于精确的等待ADC转换完成
variable counter : integer range 0 to 150:=0;
if(init_count = '1')    then                                --init_count为定时等待开始标识
        if(counter = 150)    then
            con_sample <= '1';                            --con_sample为定时结束,下个状态开始标识
            counter := 0;
            counter := counter +1;
     end if;
end if;
    con_sample <= '0';
end if;
end process divisor3;
-------------------sample state switch---------------------------------------------------
adc_sample: process(current_state,start_adc)                        --ADC转换(current)
if(start_adc'event and start_adc='1')    then
    next_state <= st0;
end if;
case current_state is
when st0    =>        --st0为空闲状态
                next_state <= st1;
                cs <= '1';
                rd <= '1';
                convst <= '0';
when st1    =>        --st1为启动ADC转换状态
        next_state <= st2;
                cs <= '1';
                rd <= '1';
                convst <= '1';
when st2    =>        --st2为等待ADC转换结束状态
                if busy = '0' then                                        --如果BUSY没有置高,则继续convst
                next_state <= st2;
                next_state <= st3;
                init_count <= '1';                                        --to start count for 3us wait time
                end if;
                cs <= '1';
                rd <= '1';
                convst <= '1';
when st3=>        --st3 wait for 3us to complete the convertion
                if con_sample = '1' then
                init_count <= '0';
                next_state <= st4;
                next_state <= st3;
                end if;
                cs <= '1';
                rd <= '1';
                convst <= '1';
when st4    =>        --read first data ,读取时间为30ns
                next_state <= st5;
                cs <= '0';
                rd <= '1';
                convst <= '1';
when st5    =>        --读取第一个转换值,读取时间为30ns
                next_state <= st6;
                rd <= '0';
                convst <= '1';
                cs <= '0';
when st6    =>        --读取第一个转换值,读取时间为30ns
                next_state <= st7;
                rd <= '0';
                convst <= '1';
                cs <= '0';
when st7    =>        --读取第一个转换值,读取时间为30ns
                next_state <= st8;
                cs <= '0';
                rd <= '0';
                convst <= '1';
                regl1 <= data;
when st8    =>        --读取第一个转换值,读取时间为30ns
                next_state <= st9;
                rd <= '0';
                convst <= '1';
                cs <= '0';
                regl1 <= data;
when st9    =>        --wait for interval 20ns
                next_state <= st10;
                cs <= '0';
                rd <= '1';
                convst <= '1';
when st10    =>        --wait for interval 20ns
                next_state <= st11;
                cs <= '0';
                rd <= '1';
                convst <= '1';
when st11    =>        --读取第2个转换值,to perform read for 30ns
                next_state <= st12;
                cs <= '0';
                rd <= '0';
                convst <= '1';
when st12    =>        --读取第2个转换值,to perform read for 30ns
                next_state <= st13;
                cs <= '0';
                rd <= '0';
                convst <= '1';
when st13    =>        --读取第2个转换值,读取时间为30ns
                next_state <= st14;
                cs <= '0';
                rd <= '0';
                convst <= '1';
                regl2 <= data;
when st14    =>        --读取第2个转换值,读取时间为30ns
                next_state <= st15;
                cs <= '0';
                rd <= '0';
                convst <= '1';
                regl2 <= data;
when st15 =>                                                             --to adjust to wait state
                next_state <= st16;
                cs <= '1';
                rd <= '1';
                convst <= '1';
when st16 =>                                                             --to adjust to wait state
                cs <= '1';
                rd <= '1';
                convst <= '0';
when others=>
                cs <= '1';
                rd <= '1';
                convst <= '0';
end case;
end process adc_sample;
end Behavioral;
ERROR:Xst:827 - (“路径”) line 98: signal next_state cannot be synthesized, bad synchronous description.
CCIE 发表于 2010-6-28 01:21:43 | 显示全部楼层
同关注ing
CHANG 发表于 2010-6-28 02:25:44 | 显示全部楼层
是不是因为给初值了:<br>
interig 发表于 2010-6-28 02:49:16 | 显示全部楼层
我的想法和楼上类似
CCIE 发表于 2010-6-28 03:22:14 | 显示全部楼层
看看了&nbsp;&nbsp;不错
GMT+8, 2026-5-24 07:05 , Processed in 0.032269 second(s), 20 queries .
