查看: 4596|回复: 12
sram的verilog程序
VVC 发表于 2010-6-27 23:53:30 | 显示全部楼层 |阅读模式
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date:
// Design Name:
// Module Name:  sram_test
// Project Name:
// Target Device:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module sram_test( rst  ,
      clkin  ,
      sram_ab  ,
      sram_db  ,
      sram_wr  ,
      sram_rd  ,
      sram_cs  ,
      sram_be  ,
     error,
      task_start , //Start  Testing ---LED1
      task_finish,//TestingFinish---LED2
  flash_ce,
  flash_oe,
  flash_we
input   rst   ;
input   clkin ;
output [17:0] sram_ab ;
output [1:0]  sram_be ;
inout[15:0] sram_db ;
output    sram_wr ;
output    sram_rd ;
output    sram_cs ;
output error;
output    task_start ;
output    task_finish;
output  flash_ce,flash_oe,flash_we;
//ports
wire    rst   ;
wire    clkin ;
reg  [17:0] sram_ab ;
wire [15:0] sram_db ;
reg     sram_wr ;
reg     sram_rd ;
reg     task_start ;
reg     task_finish;
wire flash_ce=1;
wire flash_oe=1;
wire flash_we=1;
reg     clk_2;
wire    clk;
reg[2:0]  STATE,NEXT;
reg     error ;
reg[15:0] sram_db_reg;
reg[15:0] count  ;
//parameters
parameter IDLE = 3'D0,
     WRITE_1= 3'D1,
     WRITE_2= 3'D2,
     READ_1 = 3'D3,
     READ_2 = 3'D4;
assignsram_cs = 1'b0;
assignsram_be = 2'd0;
assignsram_db = sram_rd ? sram_db_reg:'hz;
reg [1:0] clk_count;
always @(posedge clkin or negedge rst)
if(!rst)
clk_count<=2'd0;
  clk_count<=clk_count+1'b1;
assign clk = clk_count[1];
//state machine
always @ (STATE or sram_ab or error or task_start)
case(STATE)
IDLE  : if(task_start)
       NEXT = WRITE_1;
       NEXT = IDLE ;
WRITE_1 : NEXT = WRITE_2;
WRITE_2 : if( sram_ab >= 18'h3ffff)
       NEXT = READ_1;
       NEXT = WRITE_1;
READ_1: NEXT = READ_2;
READ_2: if(sram_ab >= 18'h3ffff)//error ||
       NEXT = IDLE;
       NEXT = READ_1;
default : NEXT = IDLE ;
endcase
//registe the state
always @ (posedge clk or negedge rst)
if(!rst)
  STATE <= IDLE;
  STATE <= NEXT;
if(!rst)
  sram_ab  <=18'h3ffff;
  sram_db_reg<=16'h1fff;
  sram_wr  <=1'b1;
  sram_rd  <=1'b1;
  case(STATE)
  IDLE  : begin
      sram_rd <= 1;
      sram_wr <= 1;
  WRITE_1 : begin
      sram_ab <= sram_ab+1;
      sram_db_reg <= sram_db_reg+1;
      sram_wr <= 1'b0;
      sram_rd <= 1'b1;
  WRITE_2 : begin
      sram_wr<= 1'b1;
      sram_rd<= 1'b1;
  READ_1: begin
      sram_wr <= 1'b1;
      sram_rd <= 1'b0;
      sram_db_reg <= 'h1fff;
  endcase
if(!rst)
   error  <= 1'b0;
   task_start <= 1'b1;
   task_finish<= 1'b0;
   count  <= 16'h1fff;
case(STATE)
WRITE_1 : //if( sram_ab < 'd1024 )
      task_start <= 1'b1;
      count  <= 16'h1fff;
READ_1: begin
     count<=count+1;
READ_2: begin
     if( sram_db != count)
       error <= 1'b1;
       error <= 1'b0;
         task_finish <= 1'b1;
         //task_start<= 1'b1;
endcase
HDL 发表于 2010-6-28 00:57:15 | 显示全部楼层
好,不错,帮顶
ups 发表于 2010-6-28 02:28:30 | 显示全部楼层
hehe,kankan kan xian
ICE 发表于 2010-6-28 02:58:24 | 显示全部楼层
我顶楼主的无私奉献
HANG 发表于 2010-6-28 03:00:36 | 显示全部楼层
真是好人~
yihui 发表于 2011-1-14 14:42:55 | 显示全部楼层
O(∩_∩)O谢谢
pfwang1014 发表于 2011-7-14 17:34:55 | 显示全部楼层
谢谢楼主啊,无私
pirate_2011 发表于 2011-7-14 17:46:56 | 显示全部楼层
学习,学习,看看撒
蓝余 发表于 2011-7-16 13:51:42 | 显示全部楼层
不错的代码啊!好贴
liujilei311 发表于 2011-7-17 21:30:36 | 显示全部楼层
很不错,顶一个!!!!!
GMT+8, 2026-5-23 21:15 , Processed in 0.034604 second(s), 19 queries .
