查看: 15658|回复: 35
VHDL实现USB2.0控制器设计
FFT 发表于 2010-6-27 23:07:53 | 显示全部楼层 |阅读模式
--控制器SSRAM
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity usbf_mem_arb is --实体声明
generic(SSRAM_HADR:integer:=14);
port(phy_clk,wclk,rst:in std_logic;
sram_adr:buffer std_logic_vector(SSRAM_HADR downto 0);
sram_din:in std_logic_vector(31 downto 0);
sram_dout:buffer std_logic_vector(31 downto 0);
sram_re,sram_we
ut std_logic;
--SSRAM接口
madr:in std_logic_vector(SSRAM_HADR downto 0);
mdout
ut std_logic_vector(31 downto 0);
mdin:in std_logic_vector(31 downto 0);
mwe:in std_logic;
mreq:in std_logic;
mack:buffer stdlogic;
--内部DMA操作接口
wadr:in std_logic_vector(SSRAM_HADR downto 0);
wdout
wdin:in std_logic_vector(31 downto 0);
wwe:in std_logic;
wreq:in std_logic;
wack:buffer std_logic  --应用模块的wishbone接口
end entity
architecture arch_of_mem_arb of usbf_mem_arb is
signal wsel:std_logic;
signal mcy:stdlogic;
signal wack_r:std_logic;
wsel<=(wreq or wack)and not(mreq);
--对SRAM数据输出
process(wsel,wdin,mdin)
if(wsel='1')then
sram_dout<=wdin;
else sram_dout<=mdin;
end if;
end process;
--sram地址线输出
process(wsel,wadr,madr)
if(wsel='1')then
  sram_adr<=wadr;
else sram_adr<=madr;
end if;
end process;
  --sram写操作使能控制
process(wsel,wwe,wreq,mwe,mcyc)begin
if(wsel='1')then
  sram_we<=wreq and wwe;
else sram_we<=mwe and mcc;
end if;
end process;
sram_re<='1';
mdout<=sram_din;
mack<=mreq;
mcyc<=mack;
--应用模块之间的wishbone接口
wdout<=sram_din;
wack<=wack_r and not(mreq);
process(rst,phy_clk)begin
    if(rst='0')then
     wack_r<='0';
    else if(ph_clk' event and phy_clk='1')then
    wack_r<=wreq and not(mreq)and not(wack);
    end if;
end process;
end architecture;
 楼主| FFT 发表于 2010-6-28 00:43:11 | 显示全部楼层
--控制器WISHBONE<br>
--file:usb_wishbone.vhd<br>
&nbsp; &nbsp; library ieee<br>
&nbsp; &nbsp; use ieee.std_logic_1164.all;<br>
&nbsp; &nbsp; use ieee.std_logic_arith.all;<br>
&nbsp; &nbsp; use ieee.std_logic_unsigned.all;<br>
<br>
&nbsp; &nbsp; entity usbf_wb is<br>
&nbsp; &nbsp; generic(USBF_UFC_HADR:integer:=17);<br>
&nbsp; &nbsp; port(wb_clk,phy_clk:in std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;rst:in std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;wb_addr_i:in std_logic_vector(USBF_UFC_HDR downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;wb_data_i:in std_logic_vector(31 downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;wb_data_o:buffer std_logic_vector(31 downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;wb_ack_o:buffer std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;wb_we_i:in std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;wb_stb_i:in std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;wb_cyc_i:in std_logic:<br>
&nbsp;&nbsp;--应用程序的WISHBONE接口<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp;&nbsp;ma_adr
ut std_logic_vector(USBF_UFC_HADR downto 0);<br>
&nbsp; &nbsp;&nbsp;&nbsp;ma_dout
ut std_logic_vector(31 downto 0);&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp;&nbsp;ma_din
ut std_logic_vector(31 downto 0); <br>
&nbsp; &nbsp;&nbsp;&nbsp;ma_we:buffer std_logic_vector(31 wownto 0);<br>
&nbsp; &nbsp;&nbsp;&nbsp;ma_req:buffer std_logic;<br>
&nbsp; &nbsp;&nbsp;&nbsp;ma_ack:in std_logic;<br>
&nbsp; &nbsp;--存储器仲裁器接口<br>
&nbsp; &nbsp;&nbsp; &nbsp;<br>
&nbsp; &nbsp;&nbsp;&nbsp;rf_re:buffer std_logic;<br>
&nbsp; &nbsp;&nbsp;&nbsp;rf_weut std_logic;<br>
&nbsp; &nbsp;&nbsp;&nbsp;rf_din:in std_logic_vector(31 downto 0);<br>
&nbsp; &nbsp;&nbsp;&nbsp;rf_doutut std_logic_vector(31 downto 0);<br>
&nbsp; &nbsp;&nbsp;&nbsp;);<br>
&nbsp; &nbsp;&nbsp;&nbsp;end entity;<br>
<br>
&nbsp; &nbsp;&nbsp;&nbsp;architecture arch_usbf_wb of usbf_wb is<br>
&nbsp; &nbsp;&nbsp;&nbsp;constant IDLE:std_logic_vector(5 downto 0):="000001";<br>
&nbsp; &nbsp;&nbsp;&nbsp;constant MA_WR:std_logic_vector(5 downto 0):="000010";<br>
&nbsp; &nbsp;&nbsp;&nbsp;constant MA_RD:Std_logic_vector(5 downto 0):="000100";<br>
&nbsp; &nbsp;&nbsp;&nbsp;constant WO:Std_logic_vector(5 downto 0):="001000";<br>
&nbsp; &nbsp;&nbsp;&nbsp;constant W1:Std_logic_vector(5 downto 0):="010000";<br>
&nbsp; &nbsp;&nbsp;&nbsp;constant W2:Std_logic_vector(5 downto 0):="100000";<br>
&nbsp; &nbsp;&nbsp;&nbsp;signal state,next_state:std_logic_vector(5 downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; <br>
&nbsp; &nbsp;&nbsp;&nbsp;signal wb_req_sl:std_logic;<br>
&nbsp; &nbsp;&nbsp;&nbsp;signal wb_ack_d,wb_ack_sl,wb_ack_sla,wb_ack_s2:std_logic;<br>
&nbsp; &nbsp;&nbsp;&nbsp;signal rf_we_d:std_logic;<br>
--状态机状态<br>
&nbsp; &nbsp;&nbsp;&nbsp;begin<br>
&nbsp; &nbsp;&nbsp;&nbsp;ma_adr&lt;=wb_addr_i;<br>
&nbsp; &nbsp;&nbsp;&nbsp;ma_dout&lt;=wb_data_i;<br>
&nbsp; &nbsp;&nbsp;&nbsp;rf_dout&lt;=wb_data_i;<br>
--数据,地址由应用模块驱动,输出至存储器或内部存储器<br>
&nbsp; &nbsp;&nbsp;&nbsp;process(wb_clk)begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(wb_clk'evevt and wb_clk='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(not(wb_addr_i(17)0='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; wb_data_o&lt;=rf_din;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; else wb_data_o&lt;=ma_din;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; end if;<br>
&nbsp; &nbsp;&nbsp;&nbsp;end process;<br>
--数据通道,仲裁数据输入来源是寄存器或储存器<br>
&nbsp; &nbsp;&nbsp;&nbsp;process(phy_clk)begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if phy_clk'event and phy_clk='1'then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; wb_req_s1&lt;=(wb_std_i nd wb_cyc_i);<br>
--wishbone 请求<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if wb_clk'event and wb_clk='1' then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; wb_ack_sl&lt;=wb_ack_d;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if wb_clk'event and wb_clk='1' then <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; wb_ack_o&lt;=(wb_ack_s1 and not(wb_ack_s2)and not(wb_ack_0));<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; wb_ack_s2&lt;=wb_ack_s1a;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; wb_ck_s2&lt;=wb_ack_s1a;<br>
&nbsp; &nbsp;&nbsp;&nbsp;--内部寄存器写使能驱动<br>
&nbsp; &nbsp;&nbsp;&nbsp;rf_we&lt;=rf_we_d;<br>
&nbsp; &nbsp;&nbsp;&nbsp;process(phy_clk,rst)begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(rst='0')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;state&lt;=IDLE;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; elsif wb_clk'event and wb_clk='1' then <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;state&lt;=next_state;<br>
<br>
&nbsp; &nbsp;&nbsp;&nbsp;process(state,wb_req_s1,wb_addr_i,ma_ack,wb_we_i)<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;next_state&lt;=state;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;ma_req&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;ma_we&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;wb_ack_d&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;rf_re&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;rf_we_d&lt;='0';<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;case state is&nbsp;&nbsp;--状态机状态转移<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; when IDLE=&gt;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if(wb_req_s1='1' and wb_addr_i(17)='0'and wb_we_i='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; ma_req&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; ma_we&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_state&lt;=M_WR;&nbsp; &nbsp; --存储器写状态<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;end if;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if(wb_req_s1='1' and wb_addr_i(17)='0'and wb_we_i='0')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_state&lt;=MA_WR;&nbsp; &nbsp;--存储器读状态<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if(wb_req_s1='1' and wb_addr_i(12)='0'and wb_we_i='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; rf_we_d&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_state&lt;=W0;&nbsp; &nbsp;&nbsp; &nbsp;--寄存器写状态<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if(wb_req_s1='1' and wb_addr_i(12)='0'and wb_we_i='0')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; rf_re&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_state&lt;=W0;&nbsp; &nbsp;&nbsp; &nbsp;--寄存器读状态<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; when MA_WR=&gt;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if(ma_ack='0')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;ma_req&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;ma_we&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;wb_ack_d&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;next_state&lt;=W1;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;end if;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; when MA_RD=&gt;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if(ma_ack='0') then<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; when W0=&gt;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; wb_ack_d&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_state&lt;=W1;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--W1<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; when W1=&gt;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_state&lt;=W2;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--W2<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; when W2=&gt;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_state&lt;=IDLE;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;--IDLE<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; when others=&gt;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; null;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; end case;<br>
&nbsp; &nbsp;&nbsp; &nbsp;end process;<br>
&nbsp; &nbsp;&nbsp; &nbsp;end architecture;<br>
<br>
[ 本帖最后由 DARkKNIGHT 于 2006-5-25 02:53 编辑 ]
ATA 发表于 2010-6-28 02:14:36 | 显示全部楼层
--控制器协议层<br>
--file&nbsp; &nbsp;&nbsp; &nbsp; :usbf_pd.vhd<br>
<br>
library ieee;<br>
<br>
entity usb_pd is&nbsp; &nbsp; --实体声明<br>
&nbsp; &nbsp;&nbsp; &nbsp; generic(<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_OUT:std_logic_vector(3 downto 0):="0001";<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_IN:std_logic_vector(3 downto 0):="1001";<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_SOF:std_logic_vector(3 downto 0):="0101";<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_SETUP:std_logic_vector(3 downto 0):="1101";<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_DATA0:std_logic_vector(3 downto 0):="0011";<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_DATA1:std_logic_vector(3 downto 0):="1011";<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_DATA2:std_logic_vector(3 downto 0):="0111";<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_MDATA:std_logic_vector(3 downto 0):="1111";<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_ACK&nbsp;&nbsp;:std_logic_vector(3 downto 0):="0010";<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_NACK :std_logic_vector(3 downto 0):="1010";<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_STALL:std_logic_vector(3 downto 0):="1110";<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_NYET :std_logic_vector(3 downto 0):="0110";&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_PRE&nbsp;&nbsp;:std_logic_vector(3 downto 0):="1100";<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_ERR&nbsp;&nbsp;:std_logic_vector(3 downto 0):="1100";&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; <br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_SPLIT:std_logic_vector(3 downto 0):="1000";&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_PING :std_logic_vector(3 downto 0):="0100";&nbsp; &nbsp;&nbsp; &nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp; USBF_T_PID_RES&nbsp;&nbsp;:std_logic_vector(3 downto 0):="0000";<br>
&nbsp; &nbsp;&nbsp; &nbsp; );<br>
&nbsp; &nbsp;&nbsp; &nbsp; port(clk,rst:in std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;rx_data:in std_logic_vector(7 downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;rx_valid,rx_active,rx_err:in std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;--PID数据包标试符信息输出<br>
&nbsp; &nbsp;&nbsp; &nbsp; pid_OUT,pid_IN,pid_SOF,pid_SETUP:buffer std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp; pid_DATA0,pid_DATA1,pid_DATA2,pid_MDATA:buffer std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp; pid_ACK,pid_NACK,pid_STALL,pid_NYET:buffer std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp; pid_PRE,pid_ERR,pid_SPLIT,pid_PING:buffer std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp; pid_cks_err:buffer std_logic;&nbsp; &nbsp;&nbsp; &nbsp; --pid出错标识<br>
&nbsp; &nbsp;&nbsp; &nbsp; --令牌包信息输出接口<br>
&nbsp; &nbsp;&nbsp; &nbsp; token_fadr:buffer std_logic_vector(6 downto 0);&nbsp; &nbsp; --地址信息<br>
&nbsp; &nbsp;&nbsp; &nbsp; token_endp:buffer std_logic_vector(3 downto 0);&nbsp; &nbsp; --端点信息<br>
&nbsp; &nbsp;&nbsp; &nbsp; token_valid:buffer std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --令牌包有效信息<br>
&nbsp; &nbsp;&nbsp; &nbsp; crc5_err
ut std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --令牌包的CRC5错误检查<br>
&nbsp; &nbsp;&nbsp; &nbsp; frame_no
ut std_logic_vector(10 downto 0);&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--SOF信息包输出信息<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; --数据包信息输出接口<br>
&nbsp; &nbsp;&nbsp; &nbsp; rx_data_st
ut std_logic_vector(7 downto 0);&nbsp; &nbsp;&nbsp; &nbsp; --数据输出<br>
&nbsp; &nbsp;&nbsp; &nbsp; rx_data_validut std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--数据有效<br>
&nbsp; &nbsp;&nbsp; &nbsp; rx_data_doneut std_logic&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --数据传输结束<br>
&nbsp; &nbsp;&nbsp; &nbsp; crc16_errut std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;--数据包CRC6出错检测<br>
&nbsp; &nbsp;&nbsp; &nbsp; seq_err:buffer std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--状态机出错信息<br>
&nbsp; &nbsp;&nbsp; &nbsp; end entity;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; architecture arch_usbf_pd of usbf_pd is<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; compand usbf_crc5 port(<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;crc_in:in std_logic_vector(15 downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;din:in std_logic_vector(7 downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;crc_outut std_logic_vector(15 downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;);<br>
&nbsp; &nbsp;&nbsp; &nbsp; end compand;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; --状态机状态定义<br>
&nbsp; &nbsp;&nbsp; &nbsp; constant IDLE:std_logic_vector(3 downto 0):="0001";<br>
&nbsp; &nbsp;&nbsp; &nbsp; constant ACTIVE:std_logic_vector(3 downto 0):="0010";<br>
&nbsp; &nbsp;&nbsp; &nbsp; constant TOKEN:std_logic_vector(3 downto 0):="0100";<br>
&nbsp; &nbsp;&nbsp; &nbsp; constant DATA:std_logic_vector(3 downto 0):="1000";<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal state,next_state:std_logic_vector(3 downto 0);<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal pid:std_logic_vector(7 downto 0);&nbsp; &nbsp;&nbsp; &nbsp; --PDI<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal pid_le_sm:std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--状态机pid有效<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal pid_ld_en:std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--pid有效使能<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal pid_RES:std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal pid_TOKEN:std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--所有的令牌包统一的信号<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal pid_DATA:std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;--所有的数据包统一信号<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal token0,token1:std_logic_vector(7 downto 0);&nbsp; &nbsp;--令牌包缓存<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal token_le_1,token_le_2:std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--令牌包缓存有效使能<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal token_crc5:std_logic_vector(4 downto 0);<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal d0,d1,d2:std_logic_vector(7 downto 0);&nbsp; &nbsp; --数据通道延迟线(计算CRC5)<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal data_valid_d:std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --状态机输出数据有效信号<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal data_done:std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --数据有效信号延迟<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal rxv1:std_logic; <br>
&nbsp; &nbsp;&nbsp; &nbsp; signal rxv2:std_logic;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal got_pid_ack:std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal token_valid_r1:std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal token_valid_str1:std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal rx_active_r:std_logic;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --输出有效<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal crc5_out:std_logic_vector(4 doento 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal crc5_out2:std_logic_vector(4 doento 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal crc16_clr:std_logic;<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal crc16_sum:std_logic_vector(15 down 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal crc16_out:std_logic_vector(15 down 0);&nbsp; &nbsp;--crc5 crc16校验<br>
&nbsp; &nbsp; <br>
&nbsp; &nbsp;&nbsp; &nbsp; signal rx_data_temp:std_logic_vector(7 downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp; signal token_temp:std_logic_vector(10 downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp; --PID逻辑分析<br>
&nbsp; &nbsp;&nbsp; &nbsp; pid_ld_en&lt;=pid_le_sm and rx_active and rx_valid;<br>
&nbsp; &nbsp;&nbsp; &nbsp; --PID输入寄存<br>
&nbsp; &nbsp;&nbsp; &nbsp; process(clk,rst)begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if(rst='0')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;pid&lt;="11110000";<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;elsif clk'event and clk='1'then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if(pid_ld_en='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;pdi&lt;=rx_data;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;end if;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; end process;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; --PID校验,识别<br>
&nbsp; &nbsp;&nbsp; &nbsp; process(pid)begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)/=not(pid(7 downto 4))then pid_cks_err&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else pid_cks_err&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;end if;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --PID校验<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_OUT then pid_out&lt;="1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else pid_OUT&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_IN then pid_IN&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_SETUP&lt;='0';<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_SOF then pid_SOF&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_SOF&lt;='0';<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_SETUP then pid_setup&lt;='1';<br>
&nbsp; &nbsp; <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_DATA0 then pid_DATA0&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_DATA0&lt;='0';<br>
&nbsp; &nbsp; <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_DATA1 then pid_DATA&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_DATA1&lt;='0';<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_DATA2 then pid_DATA2&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_DATA2&lt;='0';<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_MDATA then pid_MDATA&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_MDATA&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_ACK then pid_ACK&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_ACK&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;end if;&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_NACK then pid_NACK&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_NACK&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_STALL then pid_STALL&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_STALL&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_NYET then pid_NYET&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_NYET&lt;='0';<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_PRE then pid_PRE&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_PRE&lt;='0';<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_ERR then pid_ERR&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_ERR&lt;='0';<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_SPLIT then pid_SPLIT&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_SPLIT&lt;='0';<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_PING then pid_PING&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else PID_PING&lt;='0';<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if pid(3 downto 0)=USBF_T_PID_RES then pid_RES&lt;='1';<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;end process<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--令牌包数据包的统一识别<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;pid_TOKEN&lt;=pid_OUT or pid_SOF or pid_SRTUP or pid_PING;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;pid_DATA&lt;=pid_DATA0 or pid_DATA1 or pid_DATA2 or pid_MDATA;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--令牌包分析模块<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;process(clk)begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if clk'event and clk='1'then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if(token_le_1='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;token0&lt;=rx_data;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; end if<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;end process;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if(token_le_2='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;token1&lt;=rx_data;<br>
&nbsp; &nbsp; <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; token_valid_r1&lt;=token_le_2;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;;<br>
<br>
[ 本帖最后由 DARkKNIGHT 于 2006-5-25 02:54 编辑 ]
ANG 发表于 2010-6-28 04:06:25 | 显示全部楼层
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; token_valid_str1&lt;=token_valid_r1 or got_pid_ack;&nbsp; &nbsp;&nbsp; &nbsp;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; token_valid&lt;=token_valid_str1;<br>
&nbsp; &nbsp;&nbsp; &nbsp;--CRC5数据校验模块,时序需要一个时钟周期<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; process(token_valid,crc5_out2,token_crc5)begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if(crc5_out2/=token_crc5)then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;crc5_err&lt;=token_valid;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else crc5_err&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp; end process<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; token_temp&lt;=token_fadr(0)&amp;token_fadr(1)&amp;token_fadr(2)&amp;token_fadr(3)&amp;token_fadr(4)&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; &amp;token_fadr(5)&amp;token_fadr(6)&amp;token_endp(0)&amp;token_endp(1)&amp;token_endp(2)<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; &amp;token_endp(03);<br>
&nbsp; &nbsp;&nbsp; &nbsp; usbf_crc5_u0:usbf_crc5 port map(<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;"11111",<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;token_temp,<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;crc5_out<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; --CRC5校验输出<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;crc5_out2&lt;=not(crc5_out(0)&amp;crc5_out(1)&amp;crc5_out(2)&amp;crc5_out(3)&amp;crc5_out(4);<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;frame_no&lt;=token1(2 downto 0)&amp;token0;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;token_fadr&lt;=token0(6 downto 0);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;token_endp&lt;=token1(2 downto 0)&amp;token0(7);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;token_crc5&lt;=token1(7 downto 3);<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp; --数据接收逻辑<br>
&nbsp; &nbsp;&nbsp; &nbsp; --rxv1 rxv2的作用是对数据有效信号做2个时钟的延迟<br>
&nbsp; &nbsp;&nbsp; &nbsp;process(clk,rst)begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if(rst='0') then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; rxv1&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;elsif clk'event and clk='1'then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if(data_valid_d='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;rxv1&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;elsif(data_done='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;rxv1&lt;='0';<br>
&nbsp; &nbsp; <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;rxv2&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;elsif clk'event and clk='1'then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(rxv1='1' and data_valid_d='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; rxv2&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; elsif(data_done='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;rxv2&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; end if;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;end process;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;process(clk)begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if clk'event and clk='1'then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;data_valid0&lt;=rxv2 and data_valid_d;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if(data_valid_d='1')then d0&lt;=rx_data;end if;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if(data_valid_d='1')then d1&lt;=d0;end if;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;if(data_valid_d='1')then d2&lt;=d1;end if;&nbsp; &nbsp;&nbsp; &nbsp; --数据2个时钟延迟<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;end if;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;rx_data_st&lt;=d2;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;rx_data_valid&lt;=data_vlid0;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;rx_data_done&lt;=data_done;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--crc16数据校验<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; rx_active_r&lt;=rx_active;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;crc16_clr&lt;=rx_active and not(rx_active_r);<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(crc16_clr='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; crc16_sum&lt;='1111111111111111";<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; else<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(data_valid_d='1')then crc16_sum&lt;=crc16_out;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;rx_data_temp&lt;=rx_data(0)&amp;rx_data(1)&amp;rx_data(2)&amp;rx_data(3)<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; &amp;rx_data(4)&amp;rx_data(5)&amp;rx_data(6)&amp;rx_data(7);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;usbf_crc16_u1:usb_crc16 port map(<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; crc16_sum,<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; rx_data_temp,<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; crc16_out<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; );<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;process(data_done,crc16_sum)begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if crc16_sum/="1000000000001101"then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; crc16_err&lt;=data_done;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; else crc16_err&lt;='0';<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;--状态机设计<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;process(clk,rst)begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(rst='0') then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;state&lt;=IDLE;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; elseif clk'event and clk='1'then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;state&lt;=next_state;<br>
<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;process(state,rx_valid,rx_active,rx_err,pid_ACK,pid_TOKEN,pid_DATA)<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_state&lt;=state;&nbsp;&nbsp;--默认状态不改变状态机状态<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; pid_le_sm&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; token_le_1&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; token_le_2&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; data_valid_d&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; data_done&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; seq_err&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; got_pid_ack&lt;='0';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; case state is&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;---状态机<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; when IDLE=&gt;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; pid_le_sm&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(rx_valid='1' and rx_active='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_state&lt;=ACTIVE;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; when ACTIVE=&gt;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --收到数据包标识符号<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(pid_ACK='1' and rx_err='0')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; got_pid_ack&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(rx_active='0')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_atate&lt;=IDLE;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; end if;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --收到令牌token数据包标识符<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; elsif(pid_TOKEN='1' and rx_valid='1' and rx_ctive='1' and&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;rx_err='0')then&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; token_le_1&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_state&lt;=TOKEN;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --收到data数据包标识符<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; elsif(pid_TOKEN='1' and rx_valid='1' and rx_ctive='1' and&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;rx_err='0')then&nbsp; &nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; data_valid_d&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_state&lt;=DATA;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; elsif(rx_active='0' or rx_err='1'or<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;(rx_valid='1' and not(pid_TOKEN='1' or pid_DATA='1')))then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;seq_err&lt;==not(rx_err);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if(rx_active='0')then next_state&lt;=IDLE;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;end if;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;end if;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;--令牌token数据包处理<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;when TOKEN=&gt;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if(rx_valid='1' and rx_active='1' and rx_err='0')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;token_le_2&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;next_state&lt;=IDLE;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;elsif(rx_active='0' or rx_err='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;seq_err&lt;=not(rx_err);<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;if(rx_active='0')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;next_state&lt;=IDLE;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; --DATA数据包处理<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; when DATA=&gt;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(rx_valid='1' and rx_active='1' and rx_err='0') then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; data_vlid_d&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(rx_active='0' or rx_err='1')then<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; data_done&lt;='1';<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; next_state&lt;=IDLE;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; when other=&gt;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; null;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;end case;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; end process;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; end architecture;<br>
<br>
[ 本帖最后由 DARkKNIGHT 于 2006-5-25 02:52 编辑 ]
longtime 发表于 2010-6-28 05:04:11 | 显示全部楼层
还有剩下的CRC15,CRC16没写出&hellip;&hellip;熬不住了&hellip;&hellip;睡觉先&hellip;&hellip;
VVC 发表于 2010-6-28 06:18:57 | 显示全部楼层
tai niu le
CCIE 发表于 2010-6-28 08:06:21 | 显示全部楼层
支持,没有细看代码<br>
但是很整齐<br>
我想内容也一定很精彩
ANG 发表于 2010-6-28 09:29:39 | 显示全部楼层
内容的确很精彩&hellip;&hellip;不过遗憾的是就不是我自己写出来的,我也是参照了有关书籍&hellip;&hellip;实在写不出啊,这是高手的作品。
CCIE 发表于 2010-6-28 10:54:20 | 显示全部楼层
很不错,顶
usb 发表于 2010-6-28 12:46:36 | 显示全部楼层
ding yige xian
GMT+8, 2026-5-24 07:07 , Processed in 0.036349 second(s), 20 queries .
