查看: 3953|回复: 8
如何用VERILOG实现串-并转换?请各位达人指教!
tim 发表于 2010-6-28 00:02:24 | 显示全部楼层 |阅读模式
用FPGA实现л/4DQPSK的调制解调,这是我第一次做项目,不会的很多,请大家帮忙,感激不尽!
CHA 发表于 2010-6-28 01:50:24 | 显示全部楼层
串并转换用一个任务实现,然后在通过在always里调用任务;如把一串数据转换位一个8位并行数据输出:注意代码如下<br>
...<br>
reg&nbsp; &nbsp;serial; //存储串行数据的寄存器<br>
reg&nbsp; &nbsp;[7:0]&nbsp; &nbsp;parallel;&nbsp;&nbsp;//并行数据的输出寄存器<br>
reg&nbsp; &nbsp;[8:0]&nbsp;&nbsp;shift_state;&nbsp;&nbsp;//状态机变量<br>
parameter&nbsp; &nbsp;shift_bit7 = 9'b000000001,<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_bit6 = 9'b000000010,<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_bit5 = 9'b000000100,<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_bit4 = 9'b000001000, <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_bit3 = 9'b000010000, <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_bit2 = 9'b000100000,<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_bit1 = 9'b001000000,<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_bit0 = 9'b010000000,<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_end = 9'b100000000;<br>
<br>
always&nbsp;&nbsp;@ (posedge clk)<br>
begin<br>
&nbsp; &nbsp;shift_state&nbsp;&nbsp;&lt;=&nbsp;&nbsp;shift_bit7; //初始化移位状态变量,使其有一个初状态<br>
&nbsp; &nbsp;if(...) <br>
&nbsp; &nbsp;shift;&nbsp; &nbsp;//在条件成立的时候调用任务&nbsp;&nbsp;<br>
end<br>
<br>
//定义串并移位的任务<br>
task&nbsp; &nbsp;shift;<br>
begin<br>
&nbsp; &nbsp;&nbsp; &nbsp; case(shift_state)<br>
&nbsp; &nbsp;&nbsp; &nbsp; shift_bit7: begin&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;parallel[7]&nbsp;&nbsp;&lt;= serial;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_state &lt;= shift_bit6; <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;end<br>
&nbsp; &nbsp;&nbsp; &nbsp; shift_bit6: begin&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;parallel[6]&nbsp;&nbsp;&lt;= serial;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_state &lt;= shift_bit5; <br>
&nbsp; &nbsp;&nbsp; &nbsp; shift_bit5: begin&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;parallel[5]&nbsp;&nbsp;&lt;= serial;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_state &lt;= shift_bit4; <br>
&nbsp; &nbsp;&nbsp; &nbsp; shift_bit4: begin&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;parallel[4]&nbsp;&nbsp;&lt;= serial;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_state &lt;= shift_bit3; <br>
&nbsp; &nbsp;&nbsp; &nbsp; shift_bit3: begin&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;parallel[3]&nbsp;&nbsp;&lt;= serial;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_state &lt;= shift_bit2; <br>
&nbsp; &nbsp;&nbsp; &nbsp; shift_bit2: begin&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;parallel[2]&nbsp;&nbsp;&lt;= serial;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_state &lt;= shift_bit1; <br>
&nbsp; &nbsp;&nbsp; &nbsp; shift_bit1: begin&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;parallel[1]&nbsp;&nbsp;&lt;= serial;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_state &lt;= shift_bit0; <br>
&nbsp; &nbsp;&nbsp; &nbsp; shift_bit0: begin&nbsp;&nbsp;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;parallel[0]&nbsp;&nbsp;&lt;= serial;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;shift_state &lt;= shift_end; <br>
&nbsp; &nbsp;&nbsp; &nbsp; shift_end: shift_state &lt;=&nbsp;&nbsp;shift_end;<br>
&nbsp; &nbsp;&nbsp; &nbsp; default:shift_state &lt;= shift_end;<br>
&nbsp; &nbsp;&nbsp; &nbsp; endcase<br>
end<br>
endtask
CHANG 发表于 2010-6-28 03:25:01 | 显示全部楼层
如果只是2位的输出的话,有没有比较简单的方法?
VVIC 发表于 2010-6-28 03:57:10 | 显示全部楼层
两位的话直接在alwas里用一个状态变量为两位的状态机实现就可,不用单独写任务也可以吧<br>
任务就是实现某种功能,然后调用,这样程序更有条理,个人理解
AAT 发表于 2010-6-28 05:08:27 | 显示全部楼层
真的很谢谢你的热心帮助!<br>
如果这样的话&nbsp;&nbsp;能否实现:<br>
input&nbsp; &nbsp;in;&nbsp; &nbsp;&nbsp;&nbsp;//定义输入是1位的数据<br>
output [1:0] out;&nbsp; &nbsp;//定义输出是2位的数据<br>
reg [1:0] out;<br>
....<br>
out={out,in};&nbsp; &nbsp;//使用拼接符
CHA 发表于 2010-6-28 05:53:09 | 显示全部楼层
串行数据是每个时钟下只有一个数据,要用位拼接,就要把前一个时钟的数据保存一个时钟然后再和后一个时钟的数据一起用位拼接输出吧<br>
input&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; rst_n;<br>
input&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; in;<br>
output&nbsp;&nbsp;[1:0] out;<br>
reg&nbsp; &nbsp;&nbsp; &nbsp; [1:0] out;<br>
reg&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; in_reg;&nbsp;&nbsp;//锁存in的寄存器<br>
reg&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; cnt;&nbsp; &nbsp;&nbsp; &nbsp; //一位计数器<br>
<br>
always&nbsp;&nbsp;@ (posedge clk or negedge&nbsp;&nbsp;rst_n)<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; if(!rst_n)<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;cnt&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&lt;= 1'b0;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;in_reg&nbsp;&nbsp;&lt;= 1'b0; <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;out&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&lt;= 2'b00;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;else&nbsp;&nbsp;if(cnt == 1'b1)<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;cnt&nbsp;&nbsp;&lt;= 1'b0;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;out&nbsp;&nbsp;&lt;= {in_reg,in}; //当两个时钟后用位拼接方式并行输出一次<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; else<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;begin<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;cnt &lt;= cnt + 1'b1;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;in_reg &lt;= in;&nbsp; &nbsp;//对in锁存一个时钟<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;end<br>
ICE 发表于 2010-6-28 06:32:04 | 显示全部楼层
太好了,找了很久才找到的东西,谢谢
inter 发表于 2010-6-28 07:11:57 | 显示全部楼层
学习学习<br>
不错
VVIC 发表于 2010-6-28 08:05:23 | 显示全部楼层
3x 谢谢
GMT+8, 2026-5-18 17:57 , Processed in 0.047136 second(s), 21 queries .
