查看: 2620|回复: 3
testbench哪里错了呢..
ATA 发表于 2010-6-27 23:30:27 | 显示全部楼层 |阅读模式
原程序: module adder4(cout,sum,bina,binb,cin);
input[3:0]bina,binb;
input cin;
output cout;
output [3:0]sum;
assign {cout,sum}=bina+binb+cin;
testbench:
`timescale 1ns/1ns
`include"E:/ge/adder4.v"
module adder_tb;
reg [3:0] a,b;
reg cin;
wire cout;
wire [3:0] sum;
integer i,j;
adder4 adder(cout,sum,a,b,cin);
always #5 cin=~cin;
initial
a=0;
b=0;
cin=0;
for(i=0;i<16;i=i+1)
#10 a=i;
initial
for(j=0;j<16;j=j+1)
#10 b=j;
initial
$monitor($time,,,"%d+%d+%b={%b,%d},a,b,cin,cout,sum);
#160 $finish;
compile testbench时候就是有错...找不出来...各位帮忙看下不..
CHANG 发表于 2010-6-28 00:35:42 | 显示全部楼层
$monitor($time,,,"%d+%d+%b={%b,%d},a,b,cin,cout,sum);<br>
改为$monitor($time,,,"%d+%d+%b={%b,%d}",a,b,cin,cout,sum);试试
UFP 发表于 2010-6-28 02:18:43 | 显示全部楼层
其实很多时候是读写问题,但会出一大堆的错误。
CCIE 发表于 2010-6-28 02:47:31 | 显示全部楼层
要说错误觉得楼上说得不错,但如果想去随机数应该用random比较好
GMT+8, 2026-5-24 07:05 , Processed in 0.039165 second(s), 22 queries .
