查看: 2089|回复: 0
求图像处理程序注释
interi 发表于 2010-6-27 23:56:46 | 显示全部楼层 |阅读模式
有高手能帮忙解释一下下列程序中hstart,hstop,vstart,vstop的作用吗?是用来干嘛的,是一个类似于计数器的信号还是说是一行数据第一个像素的像素值?谢谢
entity hw_calc is
port (
-- interface from sensor
  vclk    : in  std_logic;        -- videoclock
  vsy     : in  std_logic;        -- VSync (Micron: FRAME_VALID-Signal)
  vref    : in  std_logic;        -- Frame Valid
  hsy     : in  std_logic;        -- HSync (Micron: LINE_VALID-Signal)
  href    : in  std_logic;        -- Line Valid (pixel between hstart and hstop)
  vdata   : in  std_logic_vector( 7 downto 0);  -- Video Data (line between vstart and vstop)
  hstart    : in  std_logic_vector(15 downto 0);  -- horizontal start pixel after hsy
  hstop   : in  std_logic_vector(15 downto 0);  -- horizonatl stop pixel after hsy
  vstart    : in  std_logic_vector(15 downto 0);  -- vertical start line after vsy (always 0 in line mode)
  vstop   : in  std_logic_vector(15 downto 0);  -- vertical stop line after vsy (always 0 in line mode)
-- interface to sdram-controller (framebuffer)
  hw_wr   : out std_logic;        -- write enable
  hw_data   : out std_logic_vector( 7 downto 0);  -- data
end entity;
architecture hw_calc_arch of hw_calc is
--  data processing
calc: process (vclk)
if (vclk'event and vclk = '1') then
  if sys_res= '1' then
    hw_data <= x"00";
    hw_wr <= '0';
   hw_data <=vdata;   --invert image
  hw_wr <= '1';
end if;
end if;
end process calc;
end hw_calc_arch;
GMT+8, 2026-5-24 06:20 , Processed in 0.037772 second(s), 20 queries .
