查看: 2175|回复: 4
RAM读写
ICE 发表于 2010-6-27 23:34:39 | 显示全部楼层 |阅读模式
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
------------------------ ENTITY DECLARATION --------------------------------------
entity ram is
generic (ADDRES : INTEGER := 7;
   DWIDTH : integer := 8;
   DEPTH: integer :=128);
port (clk_i  : instd_logic; -- clock signal
  reset_i  : instd_logic; -- reset signal
  ram_data_i : instd_logic_vector(DWIDTH-1 downto 0);-- data input
  ram_data_o : out std_logic_vector(DWIDTH-1 downto 0);-- data output
  ram_adr_i: instd_logic_vector(ADDRES-1 downto 0);-- adresses
  ram_wr_i : instd_logic; -- read=0, write=1
  ram_en_i : instd_logic); -- inactive=0;active=1
end ram;
architecture sim of ram is
type ram_type is array (DEPTH-1 downto 0) of unsigned(DWIDTH-1 downto 0);
signals_gpram:  ram_type;     -- general purpose RAM
-- ram_read
p_read : process (clk_i, reset_i)
  if reset_i='1' then
  ram_data_o <= (others=>'0');
  if Rising_Edge(clk_i) then
    ram_data_o <= std_logic_vector(s_gpram(conv_integer(unsigned(ram_adr_i))));
  end if;
  end if;
end process p_read;
-- ram_write
p_write : process (clk_i, reset_i, ram_en_i)
  if reset_i='1' then
  s_gpram <= (others => (others =>'0'));  -- reset every bit
  if ((ram_en_i='1') and (ram_wr_i='1')) then
  s_gpram(conv_integer(unsigned(ram_adr_i))) <= unsigned(ram_data_i);
  end if;
  end if;
  end if;
end process p_write;
end sim;
  请教大侠,在读RAM时ram_data_o <= std_logic_vector(s_gpram(conv_integer(unsigned(ram_adr_i)))) 这个语句是怎么动作的,他是怎么把地址单元说存储的数据读出送到ram_data_o的
  s_gpram(conv_integer(unsigned(ram_adr_i))) <= unsigned(ram_data_i) 这条语句又是怎么动作的,???SOS
usb 发表于 2010-6-28 00:51:17 | 显示全部楼层
不用这么复杂的吧?<br>
使用<br>
if(oe = '0') then<br>
&nbsp; &nbsp;&nbsp;&nbsp;data_o &lt;= ram1(conv_integer(addr));<br>
&nbsp; &nbsp; else<br>
&nbsp; &nbsp;&nbsp;&nbsp;ram1(conv_integer(addr)) &lt;= data_i;<br>
&nbsp; &nbsp; end if;<br>
就可以了
longtim 发表于 2010-6-28 02:38:01 | 显示全部楼层
确实哈<br>
&hellip;&hellip;&hellip;&hellip;&hellip;&hellip;&hellip;&hellip;
CHA 发表于 2010-6-28 02:43:43 | 显示全部楼层
看懂了一点点<br>
yihui 发表于 2011-1-14 14:44:59 | 显示全部楼层
sram的verilog程序
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date:
// Design Name:
// Module Name:  sram_test
// Project Name:
// Target Device:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module sram_test( rst  ,
      clkin  ,
      sram_ab  ,
      sram_db  ,
      sram_wr  ,
      sram_rd  ,
      sram_cs  ,
      sram_be  ,
     error,
      task_start , //Start  Testing ---LED1
      task_finish,//TestingFinish---LED2
  flash_ce,
  flash_oe,
  flash_we
input   rst   ;
input   clkin ;
output [17:0] sram_ab ;
output [1:0]  sram_be ;
inout[15:0] sram_db ;
output    sram_wr ;
output    sram_rd ;
output    sram_cs ;
output error;
output    task_start ;
output    task_finish;
output  flash_ce,flash_oe,flash_we;
//ports
wire    rst   ;
wire    clkin ;
reg  [17:0] sram_ab ;
wire [15:0] sram_db ;
reg     sram_wr ;
reg     sram_rd ;
reg     task_start ;
reg     task_finish;
wire flash_ce=1;
wire flash_oe=1;
wire flash_we=1;
reg     clk_2;
wire    clk;
reg[2:0]  STATE,NEXT;
reg     error ;
reg[15:0] sram_db_reg;
reg[15:0] count  ;
//parameters
parameter IDLE = 3'D0,
     WRITE_1= 3'D1,
     WRITE_2= 3'D2,
     READ_1 = 3'D3,
     READ_2 = 3'D4;
assignsram_cs = 1'b0;
assignsram_be = 2'd0;
assignsram_db = sram_rd ? sram_db_reg:'hz;
reg [1:0] clk_count;
always @(posedge clkin or negedge rst)
if(!rst)
clk_count&lt;=2'd0;
  clk_count&lt;=clk_count+1'b1;
assign clk = clk_count[1];
//state machine
always @ (STATE or sram_ab or error or task_start)
case(STATE)
IDLE  : if(task_start)
       NEXT = WRITE_1;
       NEXT = IDLE ;
WRITE_1 : NEXT = WRITE_2;
WRITE_2 : if( sram_ab &gt;= 18'h3ffff)
       NEXT = READ_1;
       NEXT = WRITE_1;
READ_1: NEXT = READ_2;
READ_2: if(sram_ab &gt;= 18'h3ffff)//error ||
       NEXT = IDLE;
       NEXT = READ_1;
default : NEXT = IDLE ;
endcase
//registe the state
always @ (posedge clk or negedge rst)
if(!rst)
  STATE &lt;= IDLE;
  STATE &lt;= NEXT;
if(!rst)
  sram_ab  &lt;=18'h3ffff;
  sram_db_reg&lt;=16'h1fff;
  sram_wr  &lt;=1'b1;
  sram_rd  &lt;=1'b1;
  case(STATE)
  IDLE  : begin
      sram_rd &lt;= 1;
      sram_wr &lt;= 1;
  WRITE_1 : begin
      sram_ab &lt;= sram_ab+1;
      sram_db_reg &lt;= sram_db_reg+1;
      sram_wr &lt;= 1'b0;
      sram_rd &lt;= 1'b1;
  WRITE_2 : begin
      sram_wr&lt;= 1'b1;
      sram_rd&lt;= 1'b1;
  READ_1: begin
      sram_wr &lt;= 1'b1;
      sram_rd &lt;= 1'b0;
      sram_db_reg &lt;= 'h1fff;
  endcase
if(!rst)
   error  &lt;= 1'b0;
   task_start &lt;= 1'b1;
   task_finish&lt;= 1'b0;
   count  &lt;= 16'h1fff;
case(STATE)
WRITE_1 : //if( sram_ab &lt; 'd1024 )
READ_1: begin
     count&lt;=count+1;
READ_2: begin
     if( sram_db != count)
       error &lt;= 1'b1;
       error &lt;= 1'b0;
         task_finish &lt;= 1'b1;
         //task_start&lt;= 1'b1;
endcase
GMT+8, 2026-5-24 02:02 , Processed in 0.041173 second(s), 21 queries .
