查看: 2018|回复: 2
麻烦各位给修改下,我这个实现不了输出的结果,结果直接置位高低电平了..
interi 发表于 2010-6-28 00:44:22 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity control_4 is
port(  clk: instd_logic;
   linesy: instd_logic;
  pixelena: out std_logic;
   lineena: out std_logic);
end control_4;
architecture rtl of control_4 is
signal pixelcount:integer;
process(pixelcount,clk,linesy)
  if linesy='0' then
   null;--pixelcount<=0;
  elsif rising_edge(clk) then
   if(pixelcount=4064) then
    pixelcount<=0;
    lineena<='1';
    pixelena<='0';
    pixelcount<=pixelcount+1;  --行计数
   end if;
  end if;
end process;
end rtl;
出现下面的错误:
Warning: Reduced register "lineena~reg0" with stuck data_in port to stuck value VCC
Warning: Reduced register "pixelena~reg0" with stuck data_in port to stuck value GND
Warning: Output pins are stuck at VCC or GND
Warning: Pin "pixelena" stuck at GND
Warning: Pin "lineena" stuck at VCC
Warning: Design contains 2 input pin(s) that do not drive logic
Warning: No output dependent on input pin "clk"
Warning: No output dependent on input pin "linesy"
谢谢各位了啊~
inter 发表于 2010-6-28 02:33:20 | 显示全部楼层
不会吧~哪位大大帮下忙啊
ups 发表于 2010-6-28 03:58:01 | 显示全部楼层
用什么软件仿真的?
GMT+8, 2026-5-24 06:20 , Processed in 0.043056 second(s), 20 queries .
