查看: 2198|回复: 0
关于VHDL到Verilog HDL的移植
usd 发表于 2010-6-27 23:49:04 | 显示全部楼层 |阅读模式
将VHDL写的16位cisc cpu的顶层程序包代码用Verilog HDL描述,这段主要描述各元件之间的信号类型
可是不太会啊
哪位高手指点一下啊~~~
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
package cpu_lib is
type t_shift is (shftpass, shl, shr, rotl, rotr);
subtype t_alu is unsigned(3 downto 0);
constant alupass : unsigned(3 downto 0) := "0000";
constant andOp : unsigned(3 downto 0) := "0001";
constant orOp : unsigned(3 downto 0) := "0010";
constant notOp : unsigned(3 downto 0) := "0011";
constant xorOp : unsigned(3 downto 0) := "0100";
constant plus : unsigned(3 downto 0) := "0101";
constant alusub : unsigned(3 downto 0) := "0110";
constant inc : unsigned(3 downto 0) := "0111";
constant dec : unsigned(3 downto 0) := "1000";
constant zero : unsigned(3 downto 0) := "1001";
type t_comp is (eq, neq, gt, gte, lt, lte);
subtype t_reg is std_logic_vector(2 downto 0);
type state is (reset1, reset2, reset3, reset4,reset5,
reset6, execute, nop, load, store,move,load2,load3,
load4, store2, store3,store4, move2, move3,move4,incPc,
incPc2,incPc3, incPc4, incPc5, incPc6, loadPc,loadPc2,
loadPc3, loadPc4, bgtI2, bgtI3,bgtI4,bgtI5,bgtI6, bgtI7,
bgtI8, bgtI9,bgtI10, braI2, braI3,braI4,braI5, braI6,
loadI2,loadI3, loadI4, loadI5, loadI6,inc2, inc3, inc4);
subtype bit16 is std_logic_vector(15 downto 0);
end cpu_lib;
PS: 在vhdl 中 type t_shift is (shftpass, shl, shr, rotl, rotr);
当 port( a : in bit16; sel : in t_shift ; y : out bit16);时出错
说declaration for port "sel" cannot be of complex type
sel 定义类型有限制???
GMT+8, 2026-5-24 07:02 , Processed in 0.032878 second(s), 22 queries .
