查看: 3698|回复: 6
verilog请教程序中的一点小问题
CCIE 发表于 2010-6-27 23:53:03 | 显示全部楼层 |阅读模式
`timescale 1ns/100ps
module div_freq (
     reset_n,
     clockin,
     datain,
     clockout
input     reset_n;
input     clockin;
input[7:0]  datain;
output    clockout;
reg     clockout;
reg  [7:0]  counter;
always @( posedge clockin or negedge reset_n ) begin
  if ( ~reset_n ) begin
   counter <= 8'h00;
  else if ( ~|counter ) begin
   counter <= datain;
  else begin
   counter <= counter - 8'h01;
// If we use the carry out as clock out, duty cycle is not 50%.
// wire cout;
// assign cout = (counter == 8'hff);
// If we use the following clockout as clock out, duty cycle is 50%.
// However, we must know the following code has included 2-div
// frequence.
   clockout <= 1'b0;
   clockout <= ~clockout;
请问粗体字中的~|counter是什么意思
ATA 发表于 2010-6-28 01:38:36 | 显示全部楼层
咋的没人来帮忙呢????????????????????
UFO 发表于 2010-6-28 03:03:12 | 显示全部楼层
是归约运算符或非<br>
&bull; | ( 归约或)<br>
如果存在位值为1,那么结果为1;如果存在位x或z,结果为x;否则结果为0。<br>
&bull; ~| ( 归约或非)<br>
与归约操作符|相反。
encounter 发表于 2010-6-28 04:03:44 | 显示全部楼层
谢谢楼上 小弟刚学几天 呵呵
interige 发表于 2010-6-28 04:22:36 | 显示全部楼层
一起学习,一起进步
interi 发表于 2010-6-28 05:09:04 | 显示全部楼层
共同学习,不过这个还是用的比较少
VVC 发表于 2010-6-28 05:20:33 | 显示全部楼层
恩,不怎么常见,我在考试复习时看过,
GMT+8, 2026-5-24 05:45 , Processed in 0.032992 second(s), 20 queries .
