查看: 2353|回复: 0
状态机实现的与8051总线接口
usb 发表于 2010-6-27 23:19:45 | 显示全部楼层 |阅读模式
module bus_fsm(clk,ale,rd,wr,cs,data);
input clk,ale,rd,wr,cs;//cs由P2口译码得到
inout [7:0] data; //双向地址/数据总线
reg [7:0] address_reg,//地址寄存器
    data_reg1,  //数据寄存器1,2
    data_reg2,
    data_temp;  //输入/输出数据暂存
reg [15:0] result;  //计算结果寄存器
reg wr1,rd1;//WR RD信号延迟一个周期,供检测用
wire [7:0] data_hold;//输入数据线
reg [3:0] state;   //状态机
parameter waiting_write=4'b0000,
    data_in  =4'b0001,
    data_done  =4'b0010,
    waiting_read =4'b0100,
    data_out =4'b1000;
assign data  =!rd ? data_temp : 8'hzz, //RD为低时将TEMP中内容送入总线
   data_hold =!wr ? data : data_hold;//WR为低时锁存总线上的数据
always@(negedge ale)
if(!cs)
  address_reg<=data;//CS有效时,ALE下降沿锁存8位地址
  address_reg<=8'hff; //片选无效,置1
always@(posedge clk)
case(state)
waiting_write:
  if(wr1&&!wr) //WR出现下降沿时,锁存数据
    data_temp <=data_hold;
    state <=data_in;
  state<=waiting_write;//WR没有下降沿,等待
  wr1<=wr;
data_in:
  if(address_reg==8'hf0)
    data_reg1 <=data_temp;//锁存第一个数据
    state <=waiting_write; //等待写入第二个数据
  else if(address_reg==8'hf1)
    data_reg2 <=data_temp;
    state <=data_done;//两个数据锁存完毕
    data_reg1 <=8'h00;   //地址错误,
    data_reg2 <=8'h00;   //寄存器清零,转等待写入状态
data_done:
   result   <=data_reg1*data_reg2;//计算结果送RESULT
   state  <=waiting_read;
waiting_read:
   if(rd1&&!rd)
   state  <=data_out;  //RD出现下降沿,转入下一状态
   else        //否则,等待读信号
   rd1<=rd;
data_out:
   if(address_reg==8'hf2)
   data_temp <=result [7:0]; //读低8位,
   state <=waiting_read; //等待读高8位
   else if(address_reg==8'hf3)
   data_temp <=result [15:0];
   state <=waiting_write;//数据读完,转等待写数据
   state <=waiting_read; //地址错误,继续等待
  default:
  endcase
GMT+8, 2026-5-24 07:00 , Processed in 0.032981 second(s), 24 queries .
