返回列表 发新帖
楼主: longtime
verilog来分析下啊
UFO 发表于 2010-6-28 12:31:08 | 显示全部楼层
原帖由 janye 于 2006-10-20 20:08 发表<br>
你进程里的时钟源太多了吧,改少点应该就可以了<br>
试试这样可以吗<br>
<br>
library ieee;<br>
use ieee.std_logic_1164.all;<br>
use ieee.std_logic_unsigned.all;<br>
<br>
ENTITY myfpga IS<br>
&nbsp; &nbsp; PORT(&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;CLK&nbsp;&nbsp;:&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;IN ... 我试过了~~~可以,,谢谢
AAT 发表于 2010-6-28 12:55:56 | 显示全部楼层
CNT := 0; TRAGOUT &lt;= '0'; <br>
&nbsp;&nbsp;ELSE CNT := CNT + 1;<br>
END IF;<br>
END IF;<br>
END PROCESS; <br>
TRAGOUT&lt;=T_OUT;<br>
这里输出犯了错误!!!!!!!!!<br>
IF语句逻辑 表达的也不太好
interi 发表于 2010-6-28 13:30:51 | 显示全部楼层
LIBRARY IEEE;<br>
USE IEEE.STD_LOGIC_1164.ALL; <br>
<br>
ENTITY test IS<br>
&nbsp; &nbsp; PORT(&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;CLK&nbsp;&nbsp;:&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;IN&nbsp;&nbsp;STD_LOGIC;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;TRAG:&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;IN&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;STD_LOGIC;<br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;TRAGOUT:&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;BUFFER&nbsp;&nbsp;STD_LOGIC);<br>
END;<br>
<br>
ARCHITECTURE BHV OF test IS<br>
&nbsp; &nbsp; SIGNAL T_OUT:STD_LOGIC;<br>
BEGIN<br>
PROCESS(CLK,TRAG,TRAGOUT)<br>
BEGIN<br>
IF TRAG'EVENT AND TRAG='1' THEN <br>
&nbsp; &nbsp;T_OUT &lt;= '1'; <br>
END IF;<br>
END PROCESS;<br>
<br>
PROCESS(T_OUT,CLK)<br>
VARIABLE CNT:INTEGER range 0 to 10 := 0;<br>
BEGIN<br>
IF CLK'EVENT AND CLK='0' THEN<br>
&nbsp; &nbsp; IF T_OUT = '1' AND CNT = 10 THEN <br>
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;CNT := 0; <br>
&nbsp; &nbsp; TRAGOUT &lt;= '0'; <br>
&nbsp; &nbsp;ELSE <br>
&nbsp; &nbsp;&nbsp; &nbsp;CNT := CNT + 1;<br>
&nbsp; &nbsp; TRAGOUT&lt;=T_OUT;<br>
&nbsp; &nbsp;END IF;<br>
END IF;<br>
END PROCESS; <br>
<br>
END;<br>
是这样的效果么 ????????????
usb 发表于 2010-6-28 14:40:37 | 显示全部楼层
原帖由 liushui666 于 2006-10-22 09:33 发表<br>
END IF;<br>
END IF;<br>
END PROCESS; <br>
IF语句逻辑 表达的也不太好 谢谢了~~
VVC 发表于 2010-6-28 16:37:04 | 显示全部楼层
把BUFFER改掉试拭
ICE 发表于 2010-6-28 17:48:44 | 显示全部楼层
process不可以同时对上,下沿敏感~~~~
GMT+8, 2026-5-24 07:11 , Processed in 0.033037 second(s), 16 queries .
