查看: 1990|回复: 2
vhdl程序的功能
usb 发表于 2010-6-27 23:36:05 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_arith.all;
use ieee.std_logic_1164.all;
entity fsk3 is
port(clk :in std_logic;
start :in std_logic;
x :in std_logic;
y
ut std_logic);
end fsk3;
architecture behav of fsk3 is
signal q1:integer range 0 to 11;
signal q2:integer range 0 to 3;
signal f1,f2:std_logic;
process(clk)
if clk'event and clk='1' then
if start='0' then q1<=0;
elsif q1<=5 then f1<='1';q1<=q1+1;
elsif q1=11 then f1<='0';q1<=0;
elsef1<='0';q1<=q1+1;
end if;
end if;
end process;
process(clk)
if start='0' then q2<=0;
elsif q2<=0 then f2<='1';q2<=q2+1;
elsif q2=1 then f2<='0';q2<=0;
else f2<='0';q2<=q2+1;
end if;
end if;
end process;
process(clk,x)
if x='0' then y<=f1;
else y<=f2;
end if;
end if;
end process;
end behav;
请问这段程序的功能?
UFP 发表于 2010-6-28 00:28:42 | 显示全部楼层
这个程序的两个进程的判断分支逻辑好像都有问题。<br>
意图好像是做两个分频器以及之间的切换输出。<br>
<br>
[ 本帖最后由 xiaoyanxue 于 2006-6-9 09:49 编辑 ]
Sunlife 发表于 2015-7-4 09:59:34 | 显示全部楼层
GMT+8, 2026-5-23 06:04 , Processed in 0.035141 second(s), 22 queries .
