查看: 1973|回复: 2
如何产生300hz的三相方波
AAT 发表于 2010-6-28 00:38:39 | 显示全部楼层 |阅读模式
如何产生300hz的三相方波
HANG 发表于 2010-6-28 01:06:56 | 显示全部楼层
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity test is
port
rst:instd_logic;-- 高电平有效
clk:in std_logic;-- 输入时钟1.8KHz
oabc utstd_logic_vector(2 downto 0)-- 从高位到低位分别对应于A、B、C三相输出
end test;
architecture bhv of test is
signalcounter:std_logic_vector(2 downto 0);
process(rst,clk)
if rst= '1' then
counter<="000";
elsif clk'event and clk = '1' then
if counter = "101" then
counter<="000";
counter<=counter + 1;
end if;
end if;
end process;
process(rst,clk,counter)
if rst = '1' thenoabc<= "101";
case counter is
when "000"=>oabc<= "101";
when "001"=>oabc<= "100";
when "010"=>oabc<= "110";
when "011"=>oabc<= "010";
when "100"=>oabc<= "011";
when "101"=>oabc<= "001";
when others=>null;
end case;
end if;
end process;
end bhv;
说明:这里按照输入时钟为1.8KHz设计的,需要用锁相环生成1.8KHz时钟提供给这个模块
FFT 发表于 2010-6-28 02:02:42 | 显示全部楼层
同样期待中!
GMT+8, 2026-5-24 06:21 , Processed in 0.031584 second(s), 20 queries .
