查看: 2053|回复: 0
Innovation multi-channel DDCs IP core
pornanier 发表于 2010-7-19 01:07:19 | 显示全部楼层 |阅读模式
innovation:
32-Channel DDCs/64-Channel DDCs
The core is based on a novel channelisation architecture, which provides the flexibility traditionally associated with DDC cores and ASIC devices, but with significantly greater silicon efficiency,It Can be integrated into a single three million equivalent logic gates for Xilinx or Altera FPGA, in xilinx VirtexV6 devices or altera StratixIV devices can be integrated 1024-channel independent DDCs.
Specifications:
• Two 16-bit ADC inputs(for more inputs can custom), Fs > 220MS/s
• 64 independently configurable channels
• Independent tuning, gain, sample rate and output filter selection controls
• Output sample rates from Fs/128 to Fs/8192 or more
• Maximum alias-free output bandwidth of Fs/320 (= 625kHz for Fs = 200MS/s)
• 8 programmable output shaping filters
• Example filter performance: 0.1dB peak to peak ripple, alias-free bandwidth 80% of output sample rate and 90dB image rejection
• Centre frequency tuning accuracy to within 0.003Hz(Fs/2^36)
• Resampling provides any output rate to within 0.003Hz(Fs/2^36)
• >90dB spurious free end to end performance
• Resampled output maintains >90dB spurious free performance
• 0 to 90dB gain boost MGC & AGC
applications:
• Telecommunications base stations 移动基站
• Satellite communication systems 卫星通信系统
• Software defined radio 软件无线电系统
• Military communications systems 军事通信系统
• Radio monitoring systems 无线电监测系统
• Satellite ground stations 卫星地面站
• MIMO receivers MIMO 接收机
We can provide the logic netlist and HDL source code, technology does not transfer, thank co-operation. We Can be different according to the customer's specific requirements such as bandwidth custom channel number (4/8/16/32/64 channels)
contact email: pornanier@163.com
GMT+8, 2026-5-24 05:38 , Processed in 0.032233 second(s), 22 queries .
