查看: 2206|回复: 0
基于FPGA实现并口EPP协议
CPLD 发表于 2010-8-10 06:23:31 | 显示全部楼层 |阅读模式
用FPGA做图像处理算法时,经常需要传输大数据量的图像数据到FPGA或者从FPGA到PC。这样就需要简单快速的传输方法。单片机常用串口,但速度有限。并口是PC机基本配置,传输速度相对较快。且EPP协议时序比较简单,故本文基于FPGA用Verilog HDL实现并口EPP协议,与PC机通讯。     并口有SPP,EPP,ECP3种模式,具体区别就不说了。选用EPP模式。其特性,时序及PC机端的IO端口地址见附件里的资料(Interfacing the Enhanced Parallel Port)。下面为用有限状态机实现的EPP协议(epp.v):module EPP (EPP_Write0,EPP_Data,EPP_Interrupt,EPP_Wait,EPP_DataStrobe0,EPP_Reset0,EPP_AddressStrobe0,,clk24,rst,led);     //EPP interface signals    input EPP_Write0;    inout [7:0] EPP_Data;    output EPP_Interrupt;    output EPP_Wait;    input EPP_DataStrobe0;    input EPP_Reset0;    input EPP_AddressStrobe0;    //    input clk24;    input rst;    output led; /******************** module regs define ***************************/    //regs related to EPP    reg EPP_Interrupt,EPP_Wait;    reg EPP_Write,EPP_DataStrobe,EPP_AddressStrobe,EPP_Reset;    reg [7:0] epp_dataout,epp_datain;     //internal regs    reg led;    reg [2:0] epp_state;    reg [7:0] cmd;//from epp address write /**********************  module constant define *****************/    //parameters EPP state parameter EPP_IDLE=3'b000,EPP_WAIT_ADDRREAD=3'b001,EPP_WAIT_ADDRWRITE=3'b010,        EPP_WAIT_DATAREAD=3'b011,EPP_WAIT_DATAWRITE=3'b100;/*********************  module internal logic  ******************/ //并口输入进来的信号,需要同步。加入锁存器always @ (posedge clk24)begin    if(!rst)        EPP_Write<=1;    else        EPP_Write<=EPP_Write0;end always @ (posedge clk24)begin    if(!rst)        EPP_DataStrobe<=1;    else        EPP_DataStrobe<=EPP_DataStrobe0;end always @ (posedge clk24)begin    if(!rst)        EPP_AddressStrobe<=1;    else        EPP_AddressStrobe<=EPP_AddressStrobe0;end always @ (posedge clk24)begin    if(!rst)        EPP_Reset<=1;    else        EPP_Reset<=EPP_Reset0;end //EPP state machinealways @ (posedge clk24)begin    if(!rst )    begin        epp_state<=EPP_IDLE;        EPP_Interrupt<=0;        EPP_Wait<=0;        epp_dataout<=8'b0;        epp_datain<=8'b0;        cmd<=8'b0;        //SRAM_Addr<=20'b0;        sram_raddr<=20'b0;        sram_waddr<=20'd0;    end    else        case(epp_state)            EPP_IDLE:            begin                epp_state<=EPP_IDLE;                EPP_Wait<=0;                if(!EPP_AddressStrobe)                begin                   if(EPP_Write)                   begin//EPP address read                       epp_dataout<=EPP地址读,这里是要从地址寄存器读取的数据;                       EPP_Wait<=1;                       epp_state<=EPP_WAIT_ADDRREAD;                   end                   else                   begin//EPP address write    cmd come from EPP address write                       cmd<=EPP_Data;//EPP_Data为EPP地址寄存器写入的数据                       EPP_Wait<=1;                       epp_state<=EPP_WAIT_ADDRWRITE;                   end                end                else if(!EPP_DataStrobe)                begin                   if(EPP_Write)                   begin//EPP data read                       epp_dataout<=EPP数据读,这里是要从数据寄存器读取的数据;                       EPP_Wait<=1;                       epp_state<=EPP_WAIT_DATAREAD;                   end                   else                   begin//EPP data write                       epp_datain<=EPP_Data;//EPP数据写,是写入数据寄存器的数据                       EPP_Wait<=1;                       epp_state<=EPP_WAIT_DATAWRITE;                   end                end            end            EPP_WAIT_ADDRREAD:            begin                if(EPP_AddressStrobe)                begin                   EPP_Wait<=0;                   //led<=~led;                   epp_state<=EPP_IDLE;                end            end            EPP_WAIT_ADDRWRITE:            begin                if(EPP_AddressStrobe)                begin                   EPP_Wait<=0;                   epp_state<=EPP_IDLE;                end            end            EPP_WAIT_DATAREAD:            begin                if(EPP_DataStrobe)                begin                   EPP_Wait<=0;                   //led<=~led;                   epp_state<=EPP_IDLE;                   sram_raddr<=sram_raddr+1;                end            end            EPP_WAIT_DATAWRITE:            begin                if(EPP_DataStrobe)                begin                   EPP_Wait<=0;                   //led<=~led;                    epp_state<=EPP_IDLE;                   sram_waddr<=sram_waddr+1;                end            end            default: epp_state<=EPP_IDLE;        endcase    end assign EPP_Data=((epp_state==EPP_WAIT_DATAREAD)||(epp_state==EPP_WAIT_ADDRREAD))?epp_dataout:8'bz; endmodule           以上模块实现的状态机转换图如下:图1 并口EPP状态转换图        为上面模块指定IO口,编程进FPGA,通过并口线连接到PC机。即可在PC中读写IO端口与FPGA通讯。在Windows NT平台下,IO口属于保护资源,需要写驱动或者第3方的开发库,我这里使用DLPortIO库。即可使用该库导出的DlPortReadPortUchar和DlPortWritePortUchar函数读写EPP端口。EPP地址寄存器为基地址+3,EPP数据寄存器为基地址+4。    比如给EPP地址寄存器写入数据0,则:DlPortWritePortUchar(PORTBASE+3,addmask(PORTBASE+3,0));则在epp.v里的“cmd<=EPP_Data;//EPP_Data为EPP地址寄存器写入的数据”处即可得到PC写入的数据0。    另外,由于并口内部有的位有反向器,故先要用addmask函数处理要写入的数据,该函数如下:#define PORTBASE 0x378   //EPP端口基地址 unsigned char addmask(UINT port,unsigned char value){    UCHAR mask;    switch(port) //并口有些IO口的位写入1得时候输出是0,写入0得时候输出是1,可自己测试。。。。    {    case PORTBASE:        mask=value^0x00;        break;    case PORTBASE+1:        mask=value^0x80;        break;    case PORTBASE+2:        mask=value^0x0B;        break;    case PORTBASE+3:        mask=value^0x00;        break;    case PORTBASE+4:        mask=value^0x00;        break;    default:        mask=value;    }    return mask;}
GMT+8, 2026-5-24 05:38 , Processed in 0.031496 second(s), 21 queries .
