查看: 2819|回复: 2
大神求助呀!
225631 发表于 2012-12-14 16:34:43 | 显示全部楼层 |阅读模式
小弟在做一个简单的程序,在综合时候出现下面的错误!
ERROR:HDLCompiler:806 - "C:\learnfpga\uart\uart.v" Line 69: Syntax error near "parameter".
ERROR:HDLCompiler:806 - "C:\learnfpga\uart\uart.v" Line 70: Syntax error near "parameter".
ERROR:HDLCompiler:806 - "C:\learnfpga\uart\uart.v" Line 71: Syntax error near "parameter".
ERROR:HDLCompiler:806 - "C:\learnfpga\uart\uart.v" Line 72: Syntax error near "parameter".
ERROR:HDLCompiler:806 - "C:\learnfpga\uart\uart.v" Line 74: Syntax error near "[".
ERROR:HDLCompiler:806 - "C:\learnfpga\uart\uart.v" Line 75: Syntax error near "[".
ERROR:HDLCompiler:806 - "C:\learnfpga\uart\uart.v" Line 84: Syntax error near "always".
ERROR:HDLCompiler:806 - "C:\learnfpga\uart\uart.v" Line 123: Syntax error near "endmodule".
可是检查了好久也不知道到底是什么问题,用的是xilinx的13.4.
下面是代码截图
 楼主| 225631 发表于 2012-12-14 17:07:37 | 显示全部楼层
我自己做了个工程,我传上来,大家帮我看看,谢谢了
 楼主| 225631 发表于 2012-12-15 00:37:55 | 显示全部楼层
问题自己解决了,是少打了个END,自己真是糊涂呀!
GMT+8, 2026-5-23 18:05 , Processed in 0.034760 second(s), 21 queries .
