查看: 1012|回复: 0
求教verilog 问题
林大伟 发表于 2013-3-19 21:30:18 | 显示全部楼层 |阅读模式
AD7864转换器的控制模块设计程序如下:
module ads7864_control(reset,clk,BUSY,ad_data,wraddress,wrdata,wren,WR,RD,CS);
input reset,clk,BUSY;
inout[7:0] ad_data;
output[2:0] wraddress;
output[15:0] wrdata;
output wren,WR,RD,CS;
reg[7:0] cnt0,cnt1,cnt2;
reg[2:0] wraddress;
reg[15:0] wrdata;
reg wren,WR,RD,CS;
reg[2:0] state;
reg[15:0] ad_buffer;
reg[7:0] ad_data;
parameter ad_init=3'b000,ad_sample_hold=3'b001,ad_convert=3'b010,ad_cyclemode=3'b011,ad_read=3'b100,ad_finish=3'b101;
always@(posedge clk)
  if(!reset)
   ad_data[0]<=1;
   ad_data[1]<=1;
   ad_data[2]<=1;
   ad_data[5]<=1'bz;
   ad_data[6]<=1'bz;
   ad_data[7]<=1'bz;
   RD<=1;
   CS<=1;
   wren<=0;
   cnt0<=0;
   cnt1<=0;
   cnt2<=0;
   WR<=1;
   state<=ad_init;
case(state)
  ad_init:
   ad_data[0]<=1;
   ad_data[1]<=1;
   ad_data[2]<=1;
   ad_data[5]<=1'bz;
   ad_data[6]<=1'bz;
   ad_data[7]<=1'bz;
   RD<=1;
   CS<=1;
   wren<=0;
   cnt0<=0;
   cnt1<=0;
   cnt2<=0;
   WR<=1;
   state<=ad_sample_hold;
ad_sample_hold:
   if(cnt0<4)
   ad_data[0]<=1;
   ad_data[1]<=1;
   ad_data[2]<=1;
   cnt0<=cnt0+1'b1;
   else if(cnt0<7)
   ad_data[0]<=0;
   ad_data[1]<=0;
   ad_data[2]<=0;
   cnt0<=cnt0+1'b1;
   ad_data[0]<=1;
   ad_data[1]<=1;
   ad_data[2]<=1;
   cnt0<=0;
   CS<=1;
   WR<=0;
   state<=ad_convert;
ad_convert:
    if(cnt0<67)
    cnt0<=cnt0+1'b1;
    state<=ad_convert;
    cnt0<=0;
    state<=ad_cyclemode;
ad_cyclemode:
    WR<=1;
    ad_data[5]<=1;
    ad_data[6]<=1;
    ad_data[7]<=0;
#2  WR<=0;
    CS<=0;
    state<=ad_read;
   ad_read:
     CS<=0;
     cnt1<=cnt0;
     if(cnt1<3)
     RD<=1;
     cnt1<=cnt1+1'b1;
     else if(cnt1<6)
     RD<=0;
     cnt1<=cnt1+1'b1;
     ad_buffer[7:0]<=ad_data;
     else if(cnt1<9)
     RD<=1;
     cnt1<=cnt1+1'b1;
     else if(cnt1<12)
     RD<=0;
     cnt1<=cnt1+1'b1;
     ad_buffer[15:8]<=ad_data;
      if(ad_buffer[15]==1)
         wraddress<=ad_buffer[14:12];
         wrdata<={1'b0,1'b0,1'b0,1'b0,ad_buffer[11:0]};
         wren<=1;
         cnt2<=cnt2+1'b1;
         wren<=0;
         cnt2<=0;
      if(cnt2<6)
      state<= ad_read;
      cnt2<=0;
      state<=ad_finish;
   ad_finish:
     ad_data[0]<=1;
     ad_data[1]<=1;
     ad_data[2]<=1;
     ad_data[5]<=1'bz;
     ad_data[6]<=1'bz;
     ad_data[7]<=1'bz;
     WR<=1;
     RD<=1;
     CS<=1;
     wren<=0;
     cnt0<=0;
     cnt1<=0;
     cnt2<=0;
     state<=ad_init;
    default:
          ad_data[0]<=1;
          ad_data[1]<=1;
          ad_data[2]<=1;
          ad_data[5]<=1'bz;
          ad_data[6]<=1'bz;
          ad_data[7]<=1'bz;
          WR<=1;
          RD<=1;
          CS<=1;
          wren<=0;
          cnt0<=0;
          cnt1<=0;
          cnt2<=0;
          state<=ad_init;
   endcase
编译后出现错误提示如下:是什么问题?
Error (10170): Verilog HDL syntax error at ads7864_control.v(96) near text ":";  expecting "<=", or "="
Error (10170): Verilog HDL syntax error at ads7864_control.v(107) near text ":";  expecting "<=", or "="
Error (10170): Verilog HDL syntax error at ads7864_control.v(156) near text ":";  expecting "<=", or "="
Error (10170): Verilog HDL syntax error at ads7864_control.v(174) near text "default";  expecting "@", or "end", or an identifier ("default" is a reserved keyword ), or a system task, or "{", or a sequential statement
Error (10170): Verilog HDL syntax error at ads7864_control.v(191) near text "endcase";  expecting "@", or "end", or an identifier ("endcase" is a reserved keyword ), or a system task, or "{", or a sequential statement
GMT+8, 2026-5-23 15:00 , Processed in 0.052789 second(s), 21 queries .
