查看: 2686|回复: 0
菜鸟求助VHDL语段解释,谢谢~
tashixuexi 发表于 2013-3-19 22:51:39 | 显示全部楼层 |阅读模式
有如下的程序段,搞不清楚几个信号最后的关系是什么,求高手解答。为了表达清楚把整段程序贴上了,但问题其实很简短~
entity bt656gen is
         port(
                 clk                                 : in  STD_LOGIC;
                 reset                                 : in  STD_LOGIC;
                 sd_din                         : in  STD_LOGIC_VECTOR(7 downto 0);
                 syn_h                         : out STD_LOGIC;
                 syn_v                         : out STD_LOGIC;
                 syn_f                     : out STD_LOGIC;
                 regenh             : out STD_LOGIC;
                 regenf             : out STD_LOGIC;
                 sd_dout                         : out STD_LOGIC_VECTOR(7 downto 0)
end bt656gen;
architecture a of bt656gen is
signal state         : integer range 0 to 3 :=0;
signal sd_dinTmp : STD_LOGIC_VECTOR(7 downto 0);
signal syn_hTmp  : STD_LOGIC;
signal syn_hTmp_tmp1:STD_LOGIC;
signal syn_hTmp_tmp2:STD_LOGIC;
signal syn_fTmp  : STD_LOGIC;
signal syn_fTmp_tmp1:STD_LOGIC;
signal syn_fTmp_tmp2:STD_LOGIC;
    sd_dout<=sd_dinTmp;
    syn_h<=syn_hTmp;
    process(clk)
         if(clk'event and clk='1') then
            sd_dinTmp<=sd_din;
         end if;
    end process;
process(clk)
     if (clk 'event AND clk ='1') then
        syn_hTmp_tmp1<=syn_hTmp;
        syn_hTmp_tmp2<=syn_hTmp_tmp1;
        regenh<=(not syn_hTmp_tmp2)and syn_hTmp;
     end if;
end process;
这段程序运行过程中,regenh的输出结果和syn_hTmp到底是什么关系呢?
谢谢~
GMT+8, 2026-5-23 16:40 , Processed in 0.046936 second(s), 24 queries .
