查看: 4267|回复: 2
请教个问题 关于Warning: Output pins are stuck at VCC or GND
hero238 发表于 2013-4-4 20:20:54 | 显示全部楼层 |阅读模式
总出现警告:Warning: Output pins are stuck at VCC or GND
Warning (13410): Pin "L" is stuck at GND
程序如下
//test button and led
module button(E,L,clk);  //capital
output L;
input E,clk;
reg sig=1'd0,count=11'd0,LED=1'd0;
always@ (negedge E)
sig <= 1'd1;
always@ (posedge clk) begin
if (sig == 1'd1)
        if (count == 11'd1999) begin
        sig <= 1'd0;
        count <= 11'd0;
        LED <= 1'd1;
        else count <= count + 1'd1;
assign L = LED;
显示警告:Warning: Output pins are stuck at VCC or GND
      Warning: Design contains 2 input pin(s) that do not drive logic
        Warning (15610): No output dependent on input pin "E"
        Warning (15610): No output dependent on input pin "clk"
Warning: Following 1 pins have nothing, GND, or VCC driving datain port -- changes to this connectivity may change fitting results
        Info: Pin L has GND driving its datain port
 楼主| hero238 发表于 2013-4-5 13:18:48 | 显示全部楼层
额,显示有人回复,怎么看不到呢
GMT+8, 2026-5-23 15:04 , Processed in 0.042662 second(s), 23 queries .
