查看: 1988|回复: 5
程序报错 请帮忙看看
zhiweiqiang33 发表于 2013-4-16 10:30:38 | 显示全部楼层 |阅读模式
@ (posedge  scl) shift[7] = sda;
     @ (posedge  scl) shift[6] = sda;
     @ (posedge  scl) shift[5] = sda;
     @ (posedge  scl) shift[4] = sda;
     @ (posedge  scl) shift[3] = sda;
     @ (posedge  scl) shift[2] = sda;
     @ (posedge  scl) shift[1] = sda;
     @ (posedge  scl) shift[0] = sda;
请问这是什么意思?
 楼主| zhiweiqiang33 发表于 2013-4-16 10:32:04 | 显示全部楼层
是不是 scl 上升沿 来时 shift = sda
tonggl150 发表于 2013-4-17 20:55:11 | 显示全部楼层
scl上升沿将8位的sda数据打给shift寄存器(8位)。
 楼主| zhiweiqiang33 发表于 2013-5-3 12:43:56 | 显示全部楼层
整体赋值 先谢谢
gusumurong 发表于 2013-5-3 13:35:17 | 显示全部楼层
把=换成<=。
 楼主| zhiweiqiang33 发表于 2013-5-3 13:37:36 | 显示全部楼层
把阻塞赋值换成非阻塞赋值 谢谢了
GMT+8, 2026-5-23 15:04 , Processed in 0.053804 second(s), 21 queries .
