查看: 2720|回复: 2
fpga实例集合(最具价值):LED控制VHDL程序与仿真,FPGA驱动LED静态显示
ddr 发表于 2010-4-12 12:04:50 | 显示全部楼层 |阅读模式
--文件名:decoder.vhd
--功能:译码输出模块,LED为共阳接法
--最后修改日期:2004.3.24
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity decoder is
Port (seg:in std_logic_vector(3 downto 0 );   --四位二进制码输入
q3ut std_logic_vector(6 downto 0) );   --输出LED七段码
end decoder;
architecture Behavioral of decoder is
process(seg)
case seg is
when "0000" => q3<="0000001";--0
when "0001" => q3<="1001111";--1
when "0010" => q3<="0010010";--2
when "0011" => q3<="0000110";--3
when "0100" => q3<="1001100" --4
when "0101" => q3<="0100100";--5
when "0110" => q3<="0100000";--6
when "0111" => q3<="0001111";--7
when "1000" => q3<="0000000";--8
when "1001" => q3<="0000100";--9
when others => q3<="1111111";
end case;
end process;
end Behavioral;
 楼主| ddr 发表于 2010-4-12 12:05:08 | 显示全部楼层
例2:FPGA驱动LED动态显示(4位)
--文件名:dynamic.vhd。
--功能:动态扫描模块,位选信号高电平有效。
--最后修改日期:2004.3.24。
library IEEE;
entity dynamic is
  Port ( clk : in std_logic;
          reset: in std_logic;
            din1 : in std_logic_vector(6 downto 0);       --译码后的数据信号1(4位2进制数据
通过例1中的decoder模块译码得到din1,din2,din3,din4)
       din2 : in std_logic_vector(6 downto 0);       --译码后的数据信号2
       din3 : in std_logic_vector(6 downto 0);       --译码后的数据信号3
       din4 : in std_logic_vector(6 downto 0);       --译码后的数据信号4
          shift: out std_logic_vector(3 downto 0);      --位选信号
       bus4 : out std_logic_vector(6 downto 0));     --数据信号
end dynamic;
architecture Behavioral of dynamic is
  signal scan_clk:std_logic_vector(1 downto 0);
process(clk,scan_clk,reset)                        --分频进程
variable scan:std_logic_vector(17 downto 0);
if reset='1' then
scan:="000000000000000000";
       scan_clk<="00";
elsif clk'event and clk='1'then
scan:=scan+1;
end if;
       scan_clk<=scan(17 downto 16);
end process;
process(scan_clk,din1,din2,din3,din4)       --扫描进程
case scan_clk is
when "00"=>
         bus4<=din1;
         shift<="0001";
       when "01"=>
         bus4<=din2;
         shift<="0010";
       when "10"=>
         bus4<=din3;
         shift<="0100";
when "11"=>
         bus4<=din4;
         shift<="1000";
       when others=> bus4<="0000000";shift<="0000";
end case;
end process;
end Behavioral;
阿甘正传 发表于 2012-1-31 14:36:53 | 显示全部楼层
很好很强大!学习中,谢谢!
GMT+8, 2026-5-23 21:24 , Processed in 0.031131 second(s), 20 queries .
