查看: 1089|回复: 1
一段VHDL程序,不知道哪里出错了,请大神指点!
ppyy 发表于 2013-5-11 19:30:25 | 显示全部楼层 |阅读模式
--2.状态控制模块(CONTROL_STATUS)
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY CONTROL_STATUS IS
        PORT(RESET,CLK:IN STD_LOGIC;
                STATUS:OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
                LOAD_EW,LOAD_SN:OUT STD_LOGIC;
                DJS_EW,DJS_SN:OUT INTEGER RANGE 0 TO 80);
END CONTROL_STATUS;
ARCHITECTURE ONE OF CONTROL_STATUS IS
        SIGNAL T:INTEGER;
BEGIN
        PROCESS(CLK)
        BEGIN
                IF RESET='0' THEN
                         T<=0;
                ELSIF CLK'EVENT AND CLK='1' THEN
                         LOAD_EW<='0';LOAD_SN<='0';
                IF T=0 THEN
                        STATUS<="000";DJS_EW<=80;LOAD_EW<='1';
                ELSIF T=15 THEN
                        STATUS<="001";DJS_SN<=45;LOAD_SN<='1';
                ELSIF T=60 THEN
                        STATUS<="010";DJS_SN<=5;LOAD_SN<='1';
                ELSIF T=65 THEN
                        STATUS<="011";DJS_SN<=80;LOAD_SN<='1';
                ELSIF T=80 THEN
                        STATUS<="100";DJS_EW<=45;LOAD_EW<='1';
                ELSIF T=125 THEN
                        STATUS<="101";DJS_EW<=5;LOAD_EW<='1';
                END IF;
                        T<=T+1;
                        IF T=130 THEN
                                T<=0;
                        END IF;
                END IF;
        END PROCESS;
END;
仿真出来应该是这样的:
至芯兴洪 发表于 2013-5-12 23:25:09 | 显示全部楼层
把T分离出来吧。
GMT+8, 2026-5-23 16:34 , Processed in 0.033173 second(s), 22 queries .
