查看: 947|回复: 0
大家分享一下
zhiweiqiang33 发表于 2013-5-15 10:38:41 | 显示全部楼层 |阅读模式
This UART chip always produces level active interrupts, and the IIR
         * only indicates the highest priority interrupt.
         * In the case that receive and transmit interrupts happened at the same time, we must clear both interrupt pending to prevent edge-triggered interrupt(output from interrupt controller) from locking up. One way doing it is to disable all the interrupts at the beginning of the ISR and enable at the end.
这段是完整的
GMT+8, 2026-5-24 01:12 , Processed in 0.031394 second(s), 20 queries .
