查看: 1571|回复: 0
求解答 拜谢
zhiweiqiang33 发表于 2013-6-26 14:24:13 | 显示全部楼层 |阅读模式
Critical Warning (332012): Synopsys Design Constraints File file not found: 'LED_Test.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
大家是怎么解决的这个警告
没有时序约束
GMT+8, 2026-5-23 15:00 , Processed in 0.044835 second(s), 24 queries .
