查看: 2534|回复: 1
有一段图像采集的代码没看懂 请教下
wuliao0845 发表于 2010-9-24 17:44:51 | 显示全部楼层 |阅读模式
module TV_to_VGA (
                        OSC_27,
                        RESET,
                        VGA_BLANK,
                        VGA_SYNC,
                        VGA_CLOCK,
                        VGA_HS,
                        VGA_VS,
                        VGA_R,
                        VGA_G,
                        VGA_B,
                        TD_D,
                        TD_HS,
                        TD_VS
input                    OSC_27;
input                        RESET;
output                         VGA_BLANK;
output                        VGA_SYNC;
output                        VGA_CLOCK;
output                        VGA_HS;
output                         VGA_VS;
output                        [7:0]VGA_R;
output                         [7:0]VGA_G;
output                         [7:0]VGA_B;
input                         [7:0]TD_D;
input                         TD_HS;
input                         TD_VS;
wire [7:0]        Y;       //4:4:4 Y
wire [7:0]        Cb;      //4:4:4 Cb
wire [7:0]        Cr;      //4:4:4 Cr
wire mTD_HSx2;
wire [9:0]  R;
wire [9:0]  G;
wire [9:0]  B;
assign VGA_R={R[9:2]};
assign VGA_G={G[9:2]};
assign VGA_B={B[9:2]};
itu_r656_decoder U1
        .CLOCK(OSC_27),                //system clock
        .TD_D(TD_D[7:0]),        //4:2:2 video data stream
        .TD_HS(TD_HS),                //Decoder_hs
        .TD_VS(TD_VS),                //Decoder_vs
        .Y(Y[7:0]),               //4:4:4 Y
        .Cb(Cb[7:0]),              //4:4:4 Cb
        .Cr(Cr[7:0]),              //4:4:4 Cr
    .HSx2(mTD_HSx2),
        .blank(VGA_BLANK)
YCbCr2RGB U2(
        .Red(R[9:0]),
        .Green(G[9:0]),
        .Blue(B[9:0]),
        .iY(~Y[7:0]),
        //.iY((Y[7:0]>8'h90)? 8'hff: 8'h00),
        //.iCb(Cb[7:0]),
        //.iCr(Cr[7:0]),
        .iCb(8'h80),
        .iCr(8'h80),
        .iRESET(!RESET),
        .iCLK(OSC_27)
`include "VGA_Param.h"
reg         [10:0]L_COUNTER;//<<
reg         [10:0]RL_COUNTER;//<<
reg     [10:0]RL_COUNTER1;
wire         sync_reset=(RL_COUNTER>9)?1:0;//<<
//(RL_COUNTER==9)?1:0;//<<
//((RL_COUNTER==24)||(RL_COUNTER==25))?1:0;//<<
reg          sync_en;//<<
reg          [7:0]delay;//<<
reg                [9:0]        H_Cont;
reg                [9:0]        V_Cont;
reg                                oVGA_H_SYNC;
reg                                oVGA_V_SYNC;
reg                                Pre_HS;
reg                                Pre_VS;
reg                                mACT_HS;
reg                                mACT_VS;
always@(posedge OSC_27 or negedge sync_en)//<<
        if(!sync_en)//<<
                Pre_HS                <=        0;
                mACT_HS                <=        0;
                H_Cont                <=        0;
                oVGA_H_SYNC        <=        0;
                Pre_HS        <=        mTD_HSx2;
                if({Pre_HS,mTD_HSx2}==2'b10)
                mACT_HS        <=        1;
                if(mACT_HS)
                        //        H_Sync Counter
                        if( H_Cont < 858 )
                        H_Cont        <=        H_Cont+1;
                                H_Cont        <=        0;
                                mACT_HS        <=        0;
                        //        H_Sync Generator
                        if( H_Cont < H_SYNC_CYC )
                        oVGA_H_SYNC        <=        0;
                        oVGA_H_SYNC        <=        1;
                        oVGA_H_SYNC        <=        0;
                        H_Cont                <=        0;
        if(!sync_en)//<<
                Pre_VS                <=        1;
                mACT_VS                <=        0;
                V_Cont                <=        0;
                oVGA_V_SYNC        <=        0;
                Pre_VS        <=        TD_VS;
                if({Pre_VS,TD_VS}==2'b01)
                mACT_VS        <=        1;
                if( (H_Cont==1) && mACT_VS)
                        //        V_Sync Counter
                        if( V_Cont < 624 )
                        V_Cont        <=        V_Cont+1;
                        V_Cont        <=        0;
                        //        V_Sync Generator
                        if(        V_Cont < V_SYNC_CYC )
                        oVGA_V_SYNC        <=        0;
                        oVGA_V_SYNC        <=        1;
assign        VGA_HS                =        oVGA_H_SYNC;
assign        VGA_VS                =        oVGA_V_SYNC;
assign        VGA_SYNC        =        1'b0;        //sync始终有效
assign        VGA_CLOCK        =        OSC_27;        //象素时钟
//>>lock detector
always @(posedge TD_HS)
        if (TD_VS) L_COUNTER=0;          //遇到场同步,行计数清零
        else L_COUNTER=L_COUNTER+1;//否则行计数+1
always @(posedge TD_VS)       //TD_VS上深沿行计数保存到RL_COUNTER
                RL_COUNTER=L_COUNTER; //1714
always@(negedge sync_reset or posedge TD_VS)
        if (!sync_reset)
                delay=0;
        else if (delay < 100)
                delay=delay+1;
always@(negedge sync_reset or negedge TD_VS) begin
if (!sync_reset)
                sync_en=0;
else if (delay < 50)
    sync_en=0;
        sync_en=1;
fpga_feixiang 发表于 2021-10-26 15:38:09 | 显示全部楼层
666666666666666666666
GMT+8, 2026-5-24 07:55 , Processed in 0.050611 second(s), 20 queries .
