查看: 1589|回复: 0
vhdl问题
983921847 发表于 2010-10-19 12:38:00 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
entity vhdl1 is
port (a,b,c:in std_logic;
                  re:in std_logic;
                  yut std_logic_vector(1 downto 0));
end entity vhdl1;
architecture responder_table of vhdl1 is
shared variable door:bit:='0';
process(a,b,c)is
variable con:std_logic_vector(2 downto 0);
        con:=a&b&c;
if(door='0') then
        case con is
                when "100"=>y<="01";
                when "010"=>y<="10";
                when "001"=>y<="11";
                when others => y<="XX";
        end case;
        door:='1';
end if;
end process;
process(re) is
        door:='0';
end process;
end architecture responder_table;
不能运行,谢谢大家!
GMT+8, 2026-5-24 04:57 , Processed in 0.031557 second(s), 21 queries .
