查看: 1787|回复: 0
PS2键盘控制实验
lichangyun 发表于 2010-10-19 16:45:56 | 显示全部楼层 |阅读模式
这是一个主机和键盘的双向通讯的实验,扫描码在四个数码管上显示,其中包括分频电路,键盘电路和显示电路,在分频和键盘电路上存有疑惑和问题,恳请大家帮忙。分频电路为:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity divclk is
port(
     clk : in std_logic;     ------50MHZ
          clk400 : out std_logic;    -------400KHZ
          scanclk : out std_Logic
end divclk;
architecture Behavioral of divclk is
process(clk)
variable count : std_logic_vector(19 downto 0):=X"00000";
if(rising_edge(clk))then
   count:=count+1;
end if;
clk400<=count(2);
scanclk<=count(12);
end process;
end Behavioral;
在此程序中是怎么得到400KHZ和25HZ的?
键盘的程序如下:
library IEEE;
entity key_board is
port( clr    : in std_logic;
      clk400 : in std_logic;   --400KHZ
      ps2clk : in std_logic;
                ps2data : in std_logic;
                dataout : out std_logic_vector(15 downto 0)
end key_board;
architecture Behavioral of key_board is
signal clk : std_logic:='0';
signal data : std_logic:='0';
signal shift1,shift2 : std_logic_vector(10 downto 0);
signal ps2c,ps2d : std_logic;
ps2c<=ps2clk;
ps2d<=ps2data;
dataout<=shift1(8 downto 1) & shift2(8 downto 1);
process(clk400,clr)
variable tempclk : std_logic_vector(7 downto 0):=X"00";
variable tempdata: std_logic_vector(7 downto 0):=X"00";
if(clr='0') then
  tempclk:=X"00";
  tempdata:=X"00";
  clk<='0';
  data<='0';
else if(clk400'event and clk400='1') then
      tempclk(0):=ps2c;
                tempclk(7 downto 1):=tempclk(6 downto 0);
                tempdata(0):=ps2d;
                tempdata(7 downto 1):=tempdata(6 downto 0);
end if;
end if;
if(tempclk="11111111") then
clk<='1';
    if(tempclk="00000000") then
         clk<='0';
     end if;
end if;
if(tempdata="11111111") then
data<='1';
  if(tempdata="00000000") then
    data<='0';
  end if;
end if;
end process;
process(clk,clr)
if(clr='0')then
shift1<=(others => '0');
shift2<=(others => '0');
else if(clk'event and clk='0') then
   shift1(10)<=data;
        shift1(9 downto 0)<=shift1(10 downto 1);
        shift2(10)<=shift1(0);
        shift2(9 downto 0)<=shift2(10 downto 1);
--   shift1(0)<=data;
--        shift1(10 downto 1)<=shift1(9 downto 0);
--        shift2(0)<=shift1(10);
--        shift2(10 downto 1)<=shift2(9 downto 0);
end if;
end if;
end process;
end Behavioral;
哪位高手能给解析一下这个程序?谢谢!
GMT+8, 2026-5-24 05:45 , Processed in 0.039769 second(s), 19 queries .
