查看: 2256|回复: 3
FPGA控制触摸屏调试程序
114369623 发表于 2010-10-20 11:23:20 | 显示全部楼层 |阅读模式
entity TOUCH_TEST1_VHDL is
port(BUSY1: OUT STD_LOGIC;
     CSX : out std_logic;
          DIN : out std_logic;
          DOUT: IN std_logic;
          DCLK : out std_logic;
          clkin : in std_logic;
          DT : out std_logic_vector(11 downto 0)
end TOUCH_TEST1_VHDL;
architecture Behavioral of TOUCH_TEST1_VHDL is
   signal fclk :std_logic:='0';
   signal count: integer range 0 to 33000000:=0;
        signal count1: integer range 0 to 33000000:=0;
   signal DCLKCnt : integer range 0 to 264:= 0;
        signal THR :   std_logic_vector(7 downto 0);
        signal TSR :        std_logic_vector(7 downto 0);
        signal ShiftCnt1 : std_logic_vector(3 downto 0):="0000";
        signal RSR :        std_logic_vector(11 downto 0);
        signal RSRII :        std_logic_vector(11 downto 0);
        signal ShiftCnt2 : std_logic_vector(4 downto 0):="00000";
        type State_Typ is (idle, start,shift, delay,ad,stop);
          signal TXM_State    : State_Typ;
DIN1:process(fclk)
          if rising_edge(fclk) then
         THR <="10010101"; --X+\AD12位\节电\无中断;
          case   TXM_State is
                 when  idle =>
                                   CSX<= '1';
                                   BUSY1<='1';
                                   TXM_State <= start;
                 when  start =>
                         if  (count=20)  then
                                   CSX<= '0';
                              BUSY1<= '0';
                                   TSR <= THR;
                                   TXM_State <= shift;
                         else count<=count+1;
          end if;
          if  (count=10)  then
               CSX <= '1';
                                   BUSY1<='1';
                         end if;
                 when  shift =>
                         BUSY1<= '0';
                                   CSX<= '0';
                                   DIN <= TSR(0);
                                   TSR <= TSR(7 downto 1) & '0';
                                        TXM_State <= shift;
               ShiftCnt1 <= ShiftCnt1+1;
                              if  (ShiftCnt1=7) then
                                        TXM_State <= delay;
                                             TXM_State <= shift;
                              end if;
       when delay =>
                         if   (count=20) then
                               BUSY1<='0';
                                         CSX<='0';
                                    TXM_State <= ad;
          end if;
          if   (count=10)  then
                BUSY1<='1';
                                         CSX<='0';
                DT<="ZZZZZZZZZZZZ";
          end if;
       when   ad =>
                BUSY1<='0';
                                         CSX<='0';
          if   (RSR(0)=DOUT) then
                                    RSR <= DOUT & RSR(11 downto 1);
                                         ShiftCnt2 <= ShiftCnt2+1;
                                 if (ShiftCnt2=11) then
                                          RSRII <= RSR;
                                          DT<= RSRII;
                                          TXM_State <= stop;
                 TXM_State <= ad;
                                end if;
          end if;
       when   stop =>
                               CSX<= '1';
                                    BUSY1<='1';
                                    TXM_State <= idle;
                 when others =>
                                  TXM_State <= idle;
                end case;
        end if;
end process DIN1;
p2: process(clkin)
    if(clkin'event and clkin='1') then
                if (count1<11) then
                        count1<=count1+1;
                        count1<=0;
                             fclk<=not fclk;
                                  DCLK<= fclk;
          end if;
     end if;
  end process;
end Behavioral;
上面是我做的一个触摸屏调试程序,发送8位控制字有些问题,请高手指点问题出在哪里,附件是触摸屏资料
 楼主| 114369623 发表于 2010-10-20 11:31:16 | 显示全部楼层
大家进来就讨论下啊
TCL 发表于 2010-10-21 21:02:35 | 显示全部楼层
zhichiyixia
weibode01 发表于 2010-11-9 10:56:09 | 显示全部楼层
触摸屏诶,好深
GMT+8, 2026-5-24 04:12 , Processed in 0.034086 second(s), 22 queries .
