查看: 1018|回复: 0
各位帮小弟看看问题出在哪
z2500053109 发表于 2013-12-3 22:30:02 | 显示全部楼层 |阅读模式
entity crltime is
        port(clk :in std_logic;
                        s:in std_logic;
                        begn,cbegnut std_logic:='1');
end crltime;
architecture Behavioral of crltime is
        signal cnt:integer range 0 to 50000500;
--        signal statu: std_logic_vector(1 downto 0);
        process(clk)
        if rising_edge(clk) then
                if s='0' then cbegn<='0';
                elsif cnt=50000499 then
                        begn<='0';cnt<=0;cbegn<='1';
                elsif cnt=49999999 then begn<='1';
                        cnt<=cnt+1;
                end if;
        end if;
        end process;
end Behavioral;
综合后提示
Xst:2677 - Node <u1/cnt_25> of sequential type is unconnected in block <top>.
还有begn 和cbegn也是这个提示  没和顶层文件链接上   怎么改
GMT+8, 2026-5-23 13:30 , Processed in 0.031262 second(s), 21 queries .
