查看: 1590|回复: 2
求助:大家帮忙分析下代码逻辑上的问题,VHDL代码如下
lwpj 发表于 2010-10-27 10:19:19 | 显示全部楼层 |阅读模式
附件的图片中就是出现逻辑问题的地方
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY test IS
        PORT(
                        status0_rise          : IN  STD_LOGIC;
                        status1_rise        : IN  STD_LOGIC;
                        status2_rise    : IN  STD_LOGIC;
                        status3_rise          : IN  STD_LOGIC;
                        status4_rise        : IN  STD_LOGIC;
                        status5_rise    : IN  STD_LOGIC;
                        clkin           : IN  STD_LOGIC;
                        alcr            : IN  STD_LOGIC;
                        cnt_ctrl0       : BUFFER STD_LOGIC;
                        cnt_ctrl1       : BUFFER STD_LOGIC;
                        cnt_ctrl2       : BUFFER STD_LOGIC;
                        cnt_ctrl3       : BUFFER STD_LOGIC;
                        cnt_ctrl4       : BUFFER STD_LOGIC;
                        cnt_ctrl5       : BUFFER STD_LOGIC
end test;
ARCHITECTURE rtl OF test IS
BEGIN
process(clkin,alcr)
BEGIN
if(alcr ='0') then
        cnt_ctrl0<='0';
        cnt_ctrl1<='0';
        cnt_ctrl2<='0';
        cnt_ctrl3<='0';
        cnt_ctrl4<='0';
        cnt_ctrl5<='0';
     if (clkin'event and clkin='1') then
        if(cnt_ctrl0 = '1' and status0_rise ='0')then
           cnt_ctrl0 <= '0';
        end if;
        if(cnt_ctrl1 = '1' and status1_rise ='0')then
           cnt_ctrl1 <= '0';
        end if;
        if(cnt_ctrl2 = '1' and status2_rise ='0')then
           cnt_ctrl2 <= '0';
        end if;
        if(cnt_ctrl3 = '1' and status3_rise ='0')then
           cnt_ctrl3 <= '0';
        end if;
        if(cnt_ctrl4 = '1' and status4_rise ='0')then
            cnt_ctrl4 <= '0';
        end if;
        if(cnt_ctrl5 = '1' and status5_rise ='0')then
            cnt_ctrl5 <= '0';
        end if;
        if (status0_rise ='1' and (cnt_ctrl1='0' or cnt_ctrl2='0' or cnt_ctrl3='0' or cnt_ctrl4='0' or cnt_ctrl5='0' ))then
              cnt_ctrl0 <= '1';
           if (status1_rise ='1'and (cnt_ctrl0='0' or cnt_ctrl2='0' or cnt_ctrl3='0' or cnt_ctrl4='0' or cnt_ctrl5='0' )) then
                cnt_ctrl1 <= '1';
               if (status2_rise ='1'and (cnt_ctrl0='0' or cnt_ctrl1='0' or cnt_ctrl3='0' or cnt_ctrl4='0' or cnt_ctrl5='0' )) then
                   cnt_ctrl2 <= '1';
                  if (status3_rise ='1'and (cnt_ctrl0='0' or cnt_ctrl1='0' or cnt_ctrl2='0' or cnt_ctrl4='0' or cnt_ctrl5='0' ) )then
                     cnt_ctrl3 <= '1';
                     if (status4_rise ='1'and (cnt_ctrl0='0' or cnt_ctrl1='0' or cnt_ctrl2='0' or cnt_ctrl3='0' or cnt_ctrl5='0' ))then
                        cnt_ctrl4 <= '1';
                        if (status5_rise ='1' and (cnt_ctrl0='0' or cnt_ctrl1='0' or cnt_ctrl2='0' or cnt_ctrl3='0' or cnt_ctrl4='0' ))then
                           cnt_ctrl5 <= '1';
                        end if;
                     end if;
                  end if;
                end if;
              end if;
           end if;
         end if;
end if;
end process;
end rtl;
 楼主| lwpj 发表于 2010-10-27 15:37:59 | 显示全部楼层
谢谢大家的关注,问题已经解决!
Sunlife 发表于 2015-4-8 14:50:31 | 显示全部楼层
    怎么解决的
GMT+8, 2026-5-23 10:32 , Processed in 0.060048 second(s), 22 queries .
