查看: 1841|回复: 1
ps2键盘问题,有的键识别好,有的识别不好 ,各位牛人帮我看看程序啊
yf210yf 发表于 2010-10-27 10:24:35 | 显示全部楼层 |阅读模式
module ps2_driver(CLK,ps2_clk_out,RST,data,LED_OUT);
input  CLK;
input  RST;
input  ps2_clk_out;
input  data;
output [7:0]LED_OUT;
reg  [7:0] data_tem;
reg  [3:0] state;
reg  [7:0] LED_OUT_tem;
reg  clk_r0,clk_r1,clk_r2;
wire neg_ps2_clk;
assign LED_OUT[7:0]=LED_OUT_tem[7:0];
parameter  idle                                =4'b0000,
                   check_clk                =4'b0001,
                   check_0                    =4'b0010,
                   receive_data0        =4'b0011,
                   receive_data1        =4'b0100,
                   receive_data2        =4'b0101,
                   receive_data3        =4'b0110,
                   receive_data4        =4'b0111,
                   receive_data5        =4'b1000,
                   receive_data6        =4'b1001,
                   receive_data7        =4'b1010,
                   receive_p                =4'b1011,
                   receive_1                =4'b1100,
                   receive_over         =4'b1101;
always@(posedge CLK or negedge RST)
                if(!RST)
                                clk_r0<=1'b0;
                                clk_r1<=1'b0;
                                clk_r2<=1'b0;
                                clk_r0<=ps2_clk_out;
                                clk_r1<=clk_r0;
                                clk_r2<=clk_r1;
assign neg_ps2_clk=(!clk_r1)&clk_r2;
                if(!RST)
                                data_tem        <=8'h0;
                                state                <=idle;
                if(neg_ps2_clk)
                                case(state)
                                        idle:
                                                    data_tem[7:0]<=8'h0;
                                                        state<=check_clk;
                                        check_clk:
                                                        state<=check_0;
                                        check_0:
                                                        if(!data)
        state<=receive_data0;
        state<=idle;
                                        receive_data0:
                                                        data_tem[0]<=data;
                                                        state<=receive_data1;
                                        receive_data1:
                                                        data_tem[1]<=data;
                                                        state<=receive_data2;
                                        receive_data2:
                                                        data_tem[2]<=data;
                                                        state<=receive_data3;
                                        receive_data3:
                                                        data_tem[3]<=data;
                                                        state<=receive_data4;
                                        receive_data4:
                                                        data_tem[4]<=data;
                                                        state<=receive_data5;
                                        receive_data5:
                                                        data_tem[5]<=data;
                                                        state<=receive_data6;
                                        receive_data6:
                                                        data_tem[6]<=data;
                                                        state<=receive_data7;
                                        receive_data7:
                                                        data_tem[7]<=data;
                                                        state<=receive_p;
                                        receive_p:
                                                        //if((~^data_tem)==data)
        //begin
        state<=receive_1;
        //end
                                                        //else
        //begin
        //state<=idle;
        //end
                                        receive_1:
                                                        if(data)
        state<=receive_over;
        state<=idle;
                                        receive_over:
                                                        state<=idle;
                                        default :
                                                        state<=idle;
                                endcase
                if(!RST)
                                LED_OUT_tem<=8'b0000_0000;
                                if(state==receive_over)
                                        if((data_tem!=8'hf0)&&(data_tem!=8'h00)&&(data_tem!=8'he0))
                                                        //LED_OUT_tem<=data_tem;
                                                         case (data_tem)
        8'h70: LED_OUT_tem<=8'b0000_0001; //0
        8'h69: LED_OUT_tem<=8'b0000_0010;
        8'h72: LED_OUT_tem<=8'b0000_0011;
        8'h7a: LED_OUT_tem<=8'b0000_0111;
        8'h6b: LED_OUT_tem<=8'b0000_1000;
        8'h73: LED_OUT_tem<=8'b0000_1001;
        8'h37: LED_OUT_tem<=8'b0000_1010;
        8'h6c: LED_OUT_tem<=8'b0000_1011;
        8'h75: LED_OUT_tem<=8'b0000_1100;
        8'h7d: LED_OUT_tem<=8'b0000_1101;  //9
        8'h77: LED_OUT_tem<=8'b0000_1111;  //num
        8'h4a: LED_OUT_tem<=8'b0001_0000;  ///
        8'h7c: LED_OUT_tem<=8'b0001_0001;  //*
        8'h7b: LED_OUT_tem<=8'b0001_0010;  //-
        8'h79: LED_OUT_tem<=8'b0001_0011;  //+
        8'h5a: LED_OUT_tem<=8'b0001_0100;  //enter
        8'h75: LED_OUT_tem<=8'b0001_0101;  //up
        8'h32: LED_OUT_tem<=8'b0001_0110;  //down
        defaultED_OUT_tem<=8'h00;
                                                         endcase
kelly07050505 发表于 2010-10-31 21:35:12 | 显示全部楼层
可以讨论下,有点意思
GMT+8, 2026-5-24 04:56 , Processed in 0.037347 second(s), 19 queries .
