查看: 2552|回复: 5
各位大虾帮我看看这个程序错在哪?万分感激!
yyh1910 发表于 2010-11-1 20:35:46 | 显示全部楼层 |阅读模式
module jz_keys(
  input            clk,
  input            rst,
  input      [3:0] row,                 // 矩阵键盘 行
  output reg [3:0] col,                 // 矩阵键盘 列
  output reg [6:0] keyboard_val         // 键盘值
// 状态机部分 开始
// 状态编码
parameter NO_KEY_PRESSED = 6'b000_001;  // 没有按键按下
parameter SCAN_COL0      = 6'b000_010;  // 扫描第0列
parameter SCAN_COL1      = 6'b000_100;  // 扫描第1列
parameter SCAN_COL2      = 6'b001_000;  // 扫描第2列
parameter SCAN_COL3      = 6'b010_000;  // 扫描第3列
parameter KEY_PRESSED    = 6'b100_000;  // 有按键按下
reg [5:0] current_state, next_state;    // 现态、次态
reg  key_pressed_flag;          // 键盘按下标志
reg [3:0] col_reg, row_reg;             // 列值、行值
reg delay_en;       //延时5ms后使能端为1,否则为0
reg [10:0]c0;
reg clk0;
always @(posedge clk0 or negedge rst)
   if(!rst)
     next_state<=NO_KEY_PRESSED;
     current_state<=next_state;
always @*
     case(current_state)
      NO_KEY_PRESSED:begin
           if(row!=4'b1111)  next_state=SCAN_COL0;
           else  next_state=NO_KEY_PRESSED;end
      SCAN_COL0:begin
           if(row!=4'b1111)
             next_state=KEY_PRESSED;
           else  next_state=SCAN_COL1;end
      SCAN_COL1: begin
           if(row!=4'b1111)
           else  next_state=SCAN_COL2;end
      SCAN_COL2: begin
           if(row!=4'b1111)
           else  next_state=SCAN_COL3;end
      SCAN_COL3: begin
           if(row!=4'b1111)
           else  next_state=NO_KEY_PRESSED; end
      KEY_PRESSED:begin
           if(row!=4'b1111)
    endcase
always @ (posedge clk0 or negedge rst)
  if (!rst)
    col<= 4'h0; key_pressed_flag<=0;
    case(next_state)
      NO_KEY_PRESSED:begin col<=4'b0000;key_pressed_flag<=0;end
      SCAN_COL0:  col<=4'b1110;
      SCAN_COL1:  col<=4'b1101;
      SCAN_COL2:  col<=4'b1011;
      SCAN_COL3:  col<=4'b0111;
      KEY_PRESSED: begin
                   col_reg<=col;row_reg<=row;
                   key_pressed_flag<=1;
    endcase
always@(posedge clk0 or negedge rst) begin
    if(!rst) keyboard_val<=7'b0000000;
    else if(key_pressed_flag)
      case({col,row})
        8'b1110_1110: keyboard_val<=7'b1111110; //显示"0"
                8'b1110_1101: keyboard_val<=7'b0110011; //显示"4"
                8'b1110_1011: keyboard_val<=7'b1111111; //显示"8"
                8'b1110_0111: keyboard_val<=7'b1001111; //显示"C"
                8'b1101_1110: keyboard_val<=7'b0110000; //显示"1"
                8'b1101_1101: keyboard_val<=7'b1011011; //显示"5"
                8'b1101_1011: keyboard_val<=7'b1110011; //显示"9"
                8'b1101_0110: keyboard_val<=7'b0111101; //显示"d"
                8'b1011_1110: keyboard_val<=7'b1101101; //显示"2"
                8'b1011_1101: keyboard_val<=7'b1011111; //显示"6"
                8'b1011_1011: keyboard_val<=7'b1110111; //显示"A"
                8'b1011_0111: keyboard_val<=7'b1001111; //显示"E"
                8'b0111_1110: keyboard_val<=7'b1111001; //显示"3"
                8'b0111_1101: keyboard_val<=7'b1110000; //显示"7"
                8'b0111_1011: keyboard_val<=7'b0011111; //显示"b"
        8'b0111_0111: keyboard_val<=7'b1000111; //显示"F"
      endcase end
always @(posedge clk or negedge rst)begin //分频为5KHz
       if (!rst) c0<=0;
        else if(c0<2000) c0<=c0+1;
          else begin clk0=~clk0; c0<=0;end
 楼主| yyh1910 发表于 2010-11-1 20:39:31 | 显示全部楼层
kelly07050505 发表于 2010-11-1 21:34:08 | 显示全部楼层
你在两个always里面都next-state<=***,这是不可以的,赋值不能同时赋给一个变量
kelly07050505 发表于 2010-11-1 21:35:02 | 显示全部楼层
   if(!rst)
    current_state<=NO_KEY_PRESSED;
这样至少编译没有问题
 楼主| yyh1910 发表于 2010-11-2 09:30:19 | 显示全部楼层
感谢这位大虾,就是这个问题!
格林凯 发表于 2010-11-2 11:32:41 | 显示全部楼层
路过~…………
GMT+8, 2026-5-24 04:56 , Processed in 0.034405 second(s), 21 queries .
