查看: 1790|回复: 1
写了一个用74HC163为底层元件的19进制计数器 帮忙看看哪有问题啊???
zzx123xxz321 发表于 2010-11-20 20:36:40 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity s41 is                         --底层实体1
port(
     clk1,enp1,ent1,ld1,cr1:in std_logic;
     d1: in unsigned(3 downto 0);
     q1ut unsigned(3 downto 0);
     co1: out std_logic);
end s41;
architecture s41a of s41 is
signal iq:unsigned(3 downto 0):="1101";
--signal fc:bit:=1;
process(clk1,enp1,ent1,ld1,cr1,d1)
q1<=iq;
if(clk1'event and clk1='1' )then
                if(ld1='0')then
                        iq<=d1;
                elsif(cr1='0')then
                        iq<=(others=>'0');
                elsif (ent1 and enp1)='1' then
                                iq<=iq+1;
                end if;
                                if(iq=15) and (ent1='1')then
                                        co1<='1';
                                        co1<='0';
                                end if;
        q1<=iq;
end if;
end process;
end  s41a;
library ieee;
--use ieee.std_logic_unsigned.all;
entity s42 is                         --底层实体2
port(
     clk2,enp2,ent2,ld2,cr2:in std_logic;
     d2: in unsigned(3 downto 0);
     q2ut unsigned(3 downto 0);
     co2: out std_logic);
end s42;
architecture s42a of s42 is
signal iq:unsigned(3 downto 0):="1110";
--signal nco:std_logic;
process(clk2,enp2,ent2,ld2,cr2,d2)
q2<=iq;
if(clk2'event and clk2='1' )then
                if(ld2='0')then
                        iq<=d2;
                elsif(cr2='0')then
                        iq<=(others=>'0');
                elsif (ent2 and enp2)='1' then
                                iq<=iq+1;
                end if;
                                if(iq=15 )and (ent2='1')then
                                        co2<='1';
                                        co2<='0';
                                end if;
        q2<=iq;
end if;
end process;
end  s42a;
library ieee;
entity nt is                         --底层实体3
port(
         y:in std_logic;
         zut std_logic);
end nt;
architecture nta of nt is
        process(y)
        z<=not y;
end process;
end  nta;
library ieee;
entity s4 is                         --top
port(
     cp,enp,ent,ld,cr:in std_logic;
     dd: in unsigned(7 downto 0);--:="11011110";
     qout unsigned(4 downto 0));
end s4;
architecture s19s of s4 is
signal a,b,c,d:std_logic;
component s41
port(
end component;
component s42
port(
end component;
component nt
port(
         y:in std_logic;
         zut std_logic);
end component;
   G1:s41 port map
                (clk1=>cp,
                 enp1=>'1',
                 ent1=>'1',
                 cr1=>'1',
                 co1=>a,
                 ld1=>c,
                 q1(0)=>qo(0),
                 q1(1)=>qo(1),
                 q1(2)=>qo(2),
                 q1(3)=>qo(3),
                 d1(0)=>dd(4),
                 d1(1)=>dd(5),
                 d1(2)=>dd(6),
                 d1(3)=>dd(7)
   G2:s42 port map
                (clk2=>cp,
                 enp2=>a,
                 ent2=>a,
                 cr2=>'1',
                 co2=>d,
                 ld2=>c,
                 q2(0)=>qo(4),
                 d2(0)=>dd(0),
                 d2(1)=>dd(1),
                 d2(2)=>dd(2),
                 d2(3)=>dd(3)
   G3:nt port map
                (y=>d,
                 z=>c
end s19s;
weibode01 发表于 2010-11-22 11:02:46 | 显示全部楼层
还在计数器这徘徊呢。。。Verilog的计数器我上传了好几个,当参考吧
GMT+8, 2026-5-24 04:14 , Processed in 0.031949 second(s), 21 queries .
