查看: 1473|回复: 3
quartus调用modesim的问题
wenchenggan 发表于 2014-4-15 12:30:48 | 显示全部楼层 |阅读模式
Info: Start Nativelink Simulation process
Error: You did not generate the simulation model files or you generated the IP file using an older version of MegaCore which is not supported by RTL NativeLink Simulation
Error: Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly
Error: NativeLink simulation flow was NOT successful
老是跳出这个错误,应该怎么改过来啊?
 楼主| wenchenggan 发表于 2014-4-15 12:49:49 | 显示全部楼层
Nativelink Simulation路径设置都是正确的,因为以前都调用过;;;然后把IP屏蔽掉就能调用modesim了。。什么原因,怎么修改了?
 楼主| wenchenggan 发表于 2014-4-15 16:23:23 | 显示全部楼层
错误下面还有一段解释如下:
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode:  NONE
Nativelink TCL script failed with errorInfo:  Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly
    (procedure "get_ip_info" line 1)
    invoked from within
"get_ip_info $full_file_name"
    (procedure "run_eda_simulation_tool" line 195)
    invoked from within
"run_eda_simulation_tool eda_opts_hash"
GMT+8, 2026-5-23 11:35 , Processed in 0.031155 second(s), 21 queries .
