查看: 2063|回复: 9
新人有个VHDL编程错误,无法理解,求指导
chump0912 发表于 2014-4-17 11:41:50 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity top is
generic (n:integer:=16);
port (clk : in std_logic;
clr : in std_logic;
ena: in std_logic;
di: in std_logic_vector(7 downto 0);
do: out std_logic_vector(7 downto 0));
end top;
architecture rtl of top is
component countern
port(clr,ena,clk:in std_logic;
     q:buffer integer range 0 to n-1:=0;
     cout: out std_logic);
end component;
component rom
    port(addr: in integer range 0 to n-1;
     clk: in std_logic;
     data: out std_logic_vector(7 downto 0));
end component;
     component XZQ
         port(d0: in std_logic_vector(7 downto 0);
              d1: in integer range 0 to n-1;
              sel: in std_logic;
              yout: out std_logic_vector(7 downto 0));
              end component;
component ram
port (ad: in std_logic_vector(7 downto 0);
      clk : in std_logic;
      do: out std_logic_vector(7 downto 0);
      wr_en: in std_logic:='0';
      rd_en: in std_logic:='0');
end component;
signal qs:integer range 0  to n-1:=0;
signal ds:std_logic_vector(7 downto 0);
signal ys:std_logic_vector(7 downto 0);
signal cout:std_logic;
signal wr_en:std_logic:='0';
signal rd_en:std_logic:='0';
signal sel:std_logic:='1';
ct:countern
port map(clk=>clk,
          clr=>clr,
          ena=>ena,
          cout=>cout,
          q=>qs);
rom0:rom
port map(clk=>clk,
            addr=>qs,
            data=>ds);
mux:XZQ
port map (d1=>qs,
d0=>ds,
sel=>sel,
yout=>ys);
ram0:ram
port map(clk=>clk,
do=>do,
di=>di,
wr_en=>wr_en,
rd_en=>rd_en,
ad=>ys);
process(cout)
if cout'event and cout='0' then
sel <=not sel;
end if;
if sel='1' then
wr_en<='1';
rd_en<='1';
end if;
end process;
end rtl;
这是两个错误,不是正式的端口宽度的实例化的实体声明兼容。
Error: Actual width (4) of port "d1" on instance "XZQ:mux" is not compatible with the formal port width (1) declared by the instantiated entity
Error: Actual width (4) of port "q" on instance "countern:ct" is not compatible with the formal port width (8) declared by the instantiated entity
那我应该怎么改?
zhiweiqiang33 发表于 2014-4-17 11:55:42 | 显示全部楼层
错误:端口实际宽度(4)“D1”的实例“XZQ:MUX”是不是跟正式的端口宽度(1)通过实例化的实体宣告兼容
错误:端口实际宽度(4)“Q”的实例“countern:克拉”是不是跟正式的端口宽度(8)通过实例化的实体宣告兼容
 楼主| chump0912 发表于 2014-4-17 11:57:12 | 显示全部楼层
那么我应该怎么改?
zhiweiqiang33 发表于 2014-4-17 12:01:53 | 显示全部楼层
端口实际宽度(4)“D1”的实例“XZQ:MUX”是不是跟正式的端口宽度(1)端口不一致;
 楼主| chump0912 发表于 2014-4-17 12:10:07 | 显示全部楼层
还是不懂,我才学习这个,小白能请大神耐心指导一下么?就比如源程序发上来了,端口宽度应该怎么看。
 楼主| chump0912 发表于 2014-4-17 12:35:28 | 显示全部楼层
这个是conuntern的代码。
library ieee;
entity countern is
generic(n:integer:=16);
port(clr,ena,clk : in std_logic;
q:buffer integer range 0 to n-1;
coutut std_logic);
end countern;
architecture rtl of countern is
begin process(clk,clr)
if clr='1' then
q<=0;
     if clk='1'and clk'event then
        if ena='1' then
           if q=q'high then
              q<=0;
else q<=q+1;
end if;
end if;
end if;
end if;
if q=q'high then
cout<='1';
cout<='0';
end if;
end process;
end rtl;
这个是xzq的代码。
library ieee;
entity XZQ is
         port (d0 : in std_logic_vector(7 downto 0);
d1: in integer range 0 to -1;
sel:in std_logic;
youtut std_logic_vector(7 downto 0));
end XZQ;
architecture if_march of XZQ is
     process(d0,d1,sel)
    if(sel='1')then
yout<=conv_std_logic_vector(d1,8);
    yout<=d0;
    end if;
    end process;
    end if_march;
 楼主| chump0912 发表于 2014-4-17 13:00:08 | 显示全部楼层
laokai 发表于 2014-4-17 12:20
位宽不匹配原因,
请把下边两个模块的代码帖出来
component countern
我发出来了。
 楼主| chump0912 发表于 2014-4-17 18:06:44 | 显示全部楼层
laokai 发表于 2014-4-17 14:52
XZQ的代码接口 d1: in integer range 0 to -1;--这里错误你少了n,按照你第一贴的错误提示应该countern ...
是的,我改过来了。我做的是一个矩阵交织器。可还是不能实现功能,现在正在纠结。
GMT+8, 2026-5-23 11:04 , Processed in 0.032465 second(s), 20 queries .
