查看: 1120|回复: 2
modelsim为何仿真出现# Error loading design
创客 发表于 2014-5-4 14:35:54 | 显示全部楼层 |阅读模式
这个是倍频文本代码:
// synopsys translate_off
`timescale 1 ps / 1 ps
// synopsys translate_on
module my_pll (
        inclk0,
        c0);
        input          inclk0;
        output          c0;
        wire [4:0] sub_wire0;
        wire [0:0] sub_wire4 = 1'h0;
        wire [0:0] sub_wire1 = sub_wire0[0:0];
        wire  c0 = sub_wire1;
        wire  sub_wire2 = inclk0;
        wire [1:0] sub_wire3 = {sub_wire4, sub_wire2};
        altpll        altpll_component (
                                .inclk (sub_wire3),
                                .clk (sub_wire0),
                                .activeclock (),
                                .areset (1'b0),
                                .clkbad (),
                                .clkena ({6{1'b1}}),
                                .clkloss (),
                                .clkswitch (1'b0),
                                .configupdate (1'b0),
                                .enable0 (),
                                .enable1 (),
                                .extclk (),
                                .extclkena ({4{1'b1}}),
                                .fbin (1'b1),
                                .fbmimicbidir (),
                                .fbout (),
                                .fref (),
                                .icdrclk (),
                                .locked (),
                                .pfdena (1'b1),
                                .phasecounterselect ({4{1'b1}}),
                                .phasedone (),
                                .phasestep (1'b1),
                                .phaseupdown (1'b1),
                                .pllena (1'b1),
                                .scanaclr (1'b0),
                                .scanclk (1'b0),
                                .scanclkena (1'b1),
                                .scandata (1'b0),
                                .scandataout (),
                                .scandone (),
                                .scanread (1'b0),
                                .scanwrite (1'b0),
                                .sclkout0 (),
                                .sclkout1 (),
                                .vcooverrange (),
                                .vcounderrange ());
        defparam
                altpll_component.bandwidth_type = "AUTO",
                altpll_component.clk0_divide_by = 1,
                altpll_component.clk0_duty_cycle = 50,
                altpll_component.clk0_multiply_by = 2,
                altpll_component.clk0_phase_shift = "0",
                altpll_component.compensate_clock = "CLK0",
                altpll_component.inclk0_input_frequency = 20000,
                altpll_component.intended_device_family = "Cyclone IV E",
                altpll_component.lpm_hint = "CBX_MODULE_PREFIX=my_pll",
                altpll_component.lpm_type = "altpll",
                altpll_component.operation_mode = "NORMAL",
                altpll_component.pll_type = "AUTO",
                altpll_component.port_activeclock = "PORT_UNUSED",
                altpll_component.port_areset = "PORT_UNUSED",
                altpll_component.port_clkbad0 = "PORT_UNUSED",
                altpll_component.port_clkbad1 = "PORT_UNUSED",
                altpll_component.port_clkloss = "PORT_UNUSED",
                altpll_component.port_clkswitch = "PORT_UNUSED",
                altpll_component.port_configupdate = "PORT_UNUSED",
                altpll_component.port_fbin = "PORT_UNUSED",
                altpll_component.port_inclk0 = "PORT_USED",
                altpll_component.port_inclk1 = "PORT_UNUSED",
                altpll_component.port_locked = "PORT_UNUSED",
                altpll_component.port_pfdena = "PORT_UNUSED",
                altpll_component.port_phasecounterselect = "PORT_UNUSED",
                altpll_component.port_phasedone = "PORT_UNUSED",
                altpll_component.port_phasestep = "PORT_UNUSED",
                altpll_component.port_phaseupdown = "PORT_UNUSED",
                altpll_component.port_pllena = "PORT_UNUSED",
                altpll_component.port_scanaclr = "PORT_UNUSED",
                altpll_component.port_scanclk = "PORT_UNUSED",
                altpll_component.port_scanclkena = "PORT_UNUSED",
                altpll_component.port_scandata = "PORT_UNUSED",
                altpll_component.port_scandataout = "PORT_UNUSED",
                altpll_component.port_scandone = "PORT_UNUSED",
                altpll_component.port_scanread = "PORT_UNUSED",
                altpll_component.port_scanwrite = "PORT_UNUSED",
                altpll_component.port_clk0 = "PORT_USED",
                altpll_component.port_clk1 = "PORT_UNUSED",
                altpll_component.port_clk2 = "PORT_UNUSED",
                altpll_component.port_clk3 = "PORT_UNUSED",
                altpll_component.port_clk4 = "PORT_UNUSED",
                altpll_component.port_clk5 = "PORT_UNUSED",
                altpll_component.port_clkena0 = "PORT_UNUSED",
                altpll_component.port_clkena1 = "PORT_UNUSED",
                altpll_component.port_clkena2 = "PORT_UNUSED",
                altpll_component.port_clkena3 = "PORT_UNUSED",
                altpll_component.port_clkena4 = "PORT_UNUSED",
                altpll_component.port_clkena5 = "PORT_UNUSED",
                altpll_component.port_extclk0 = "PORT_UNUSED",
                altpll_component.port_extclk1 = "PORT_UNUSED",
                altpll_component.port_extclk2 = "PORT_UNUSED",
                altpll_component.port_extclk3 = "PORT_UNUSED",
                altpll_component.width_clock = 5;
这个是测试代码:
`timescale 1ns/1ns
`include "my_pll.v"
module my_pll_tb;
reg  inclk0;
wire  c0;
my_pll u1(
              .inclk0(inclk0),
              .c0(c0)
initial begin
        inclk0 = 0;
                forever
                #10 inclk0 = ~inclk0;
编译可以通过,在simulation时出现# Error loading design,不知是为何,请各位点评
 楼主| 创客 发表于 2014-5-6 14:45:19 | 显示全部楼层
解决了,谢谢啊
GMT+8, 2026-5-23 11:35 , Processed in 0.030761 second(s), 20 queries .
