查看: 1210|回复: 1
Verilog多个模块怎么整合到一块,然后通过下载线下载到FPGA里边呢,谢谢
Felixluoqingqun 发表于 2014-5-10 16:32:15 | 显示全部楼层 |阅读模式
大家好,这是我在书上找的几个模块,都用Quartus编译通过了,但是我现在要把他们整合在一起,实现一个完整的功能,在Quartus上该怎么做呢,谢谢大家了
DS18B20的温度测量模块
module temperature(clk,dq,d,cont,temp);
input clk;
input dq;
output d;
output cont;
output[9:0] temp;
reg d;
reg cont;
reg[9:0] temp;
reg data;
reg[6:0] num;
reg[6:0] count;
reg[9:0] t;
always @(posedge clk)
  num=num+1;
  if(num>'b1000100)
    begin num='b0000000;
     if(count=='b1001011)
       begin count='b0000000;end
       begin count=count+1;end
   begin num=num+1;end
if(count>='b0000000&&count<='b0000110)
  begin data=0;cont=0;end
else if(count>'b0000110&&count<='b0001101)
  begin cont<=0;end
else if(count=='b0001110||count=='b0001111||count=='b0010010||count=='b0010011)
     if(num>='b0000000&&num<'b0111100)
        begin data=0;cont=1;end
        begin cont=0;end
else if(count=='b0010000||count=='b0010001||count=='b0010100||count=='b0010101)
     if(num>='b0000000&&num<'b0001010)
        begin cont=0;end
else if(count=='b0010110||count=='b0010111||count=='b0011001||count=='b0011010||count=='b0011011||count=='b0011101)//convert'0'
        begin cont=0;end
else if(count=='b0011000||count=='b0011100)
        begin cont=0;end
else if(count>='b0011110&&count<='b0100100)
else if(count>='b0100101&&count<='b0101011)
   begin cont=0;end
else if(count=='b0101100||count=='b0101101||count=='b0110000||count=='b0110001)
        begin cont=0;end
else if(count=='b0101110||count=='b0101111||count=='b0110010||count=='b0110011)
        begin cont=0;end
else if(count=='b0110100||count=='b0111010)
         begin cont=0;end
else if(count=='b0110101||count=='b0110110||count=='b0110111||count=='b01110000||count=='b0111001||count=='b0111011)
         begin cont=0;end
else if(count=='b0111100)
     if(num<='b0000000&&num<'b0001010)
          begin cont=0;end
      if(num=='b0001110)
          begin t[0]=dq;end
else if(count=='b0111101)
          begin cont=0;end
      if(num=='b0001110)
          begin t[1]=dq;end
else if(count=='b0111110)
          begin cont=0;end
      if(num=='b0001110)
          begin t[2]=dq;end
else if(count=='b0111111)
          begin cont=0;end
      if(num=='b0001110)
          begin t[3]=dq;end
else if(count=='b1000000)
          begin cont=0;end
      if(num=='b0001110)
          begin t[4]=dq;end
else if(count=='b1000001)
          begin cont=0;end
      if(num=='b0001110)
          begin t[5]=dq;end
else if(count=='b1000010)
          begin cont=0;end
      if(num=='b0001110)
          begin t[6]=dq;end
else if(count=='b1000011)
          begin cont=0;end
      if(num=='b0001110)
          begin t[7]=dq;end
else if(count=='b1000100)
          begin cont=0;end
      if(num=='b0001110)
          begin t[8]=dq;end
else if(count=='b1000101)
          begin cont=0;end
      if(num=='b0001110)
          begin t[9]=dq;end
  d=data;
  temp=t;
温度显示模块
module Two_to_ten(temp,inte_ten,inte_one,deci_ten,deci_one,dot);
input[9:0] temp;
output[3:0] inte_ten;
output[3:0] inte_one;
output[3:0] deci_ten;
output[3:0] deci_one;
output dot;
reg[3:0] inte_ten;
reg[3:0] inte_one;
reg[3:0] deci_ten;
reg[3:0] deci_one;
reg dot;
reg[9:0] t;
reg[3:0] deci;
reg[5:0] inte;
always @(inte,deci,t,temp)
  dot<=1;
  begin t<=temp;end
  inte<=t[9:4];
  deci<=t[3:0];
if(inte<'b011110)
       if(inte>='b001010)
            if(inte>='b010100)
              begin inte_ten<='b0010;
                  if(inte=='b010100)
                     begin inte_one<='b0000;end
                  if(inte=='b010101)
                     begin inte_one<='b0001;end
                  if(inte=='b010110)
                     begin inte_one<='b0010;end
                  if(inte=='b010111)
                     begin inte_one<='b0011;end
                  if(inte=='b011000)
                     begin inte_one<='b0100;end
                  if(inte=='b011001)
                     begin inte_one<='b0101;end
                  if(inte=='b011010)
                     begin inte_one<='b0110;end
                  if(inte=='b011011)
                     begin inte_one<='b0111;end
                  if(inte=='b011100)
                     begin inte_one<='b1000;end
                  if(inte=='b011101)
                     begin inte_one<='b1001;end
               begin inte_ten<='b0001;
                  if(inte=='b001010)
                  if(inte=='b001011)
                  if(inte=='b001100)
                  if(inte=='b001101)
                  if(inte=='b001110)
                  if(inte=='b001111)
                  if(inte=='b010000)
                  if(inte=='b01001)
                  if(inte=='b010010)
                  if(inte=='b010011)
              begin inte_ten<='b0000;inte_one<=inte[3:0];end
else if(inte>='b110010)
      if(inte>='b111100)
        begin inte_ten<='b0110;
                if(inte=='b111100)
                else if(inte=='b111101)
                else if(inte=='b111110)
                else if(inte=='b111111)
        begin inte_ten<='b0101;
                 if(inte=='b110010)
                 else if(inte=='b110011)
                 else if(inte=='b110100)
                 else if(inte=='b110101)
                 else if(inte=='b110110)
                 else if(inte=='b110111)
                 else if(inte=='b111000)
                 else if(inte=='b111001)
                 else if(inte=='b111010)
                 else if(inte=='b111011)
else if(inte>='b101000)
          inte_ten<='b0100;
          if(inte>='b101000&&inte<='b101111)
               begin inte_one[2:0]<=inte[2:0];inte_one[3]<='b0;end
          else if(inte=='b110000)
          else if(inte=='b110001)
           inte_ten<='b0011;
           if(inte=='b011110)
                 else if(inte=='b011111)
                 else if(inte=='b100000)
                 else if(inte=='b100001)
                 else if(inte=='b100010)
                 else if(inte=='b100011)
                 else if(inte=='b100100)
                 else if(inte=='b100101)
                 else if(inte=='b100110)
                 else if(inte=='b100111)
if(deci[3]=='b1)
      if(deci[2]=='b1)
            if(deci[1]=='b1)
                 if(deci[0]=='b1)
                    begin deci_ten<='b1001;deci_one<='b0100;end
                    begin deci_ten<='b1000;deci_one<='b1000;end
             else if(deci[0]=='b1)
                begin deci_ten<='b1000;deci_one<='b0001;end
                      begin deci_ten<='b0111;deci_one<='b0101;end
            else if(deci[1]=='b1)
                   if(deci[0]=='b1)
                      begin deci_ten<='b0110;deci_one<='b1001;end
                      begin deci_ten<='b0110;deci_one<='b0011;end
                   begin deci_ten<='b0101;deci_one<='b0110;end
                   begin deci_ten<='b0101;deci_one<='b0000;end
          else if(deci[2]=='b1)
                 if(deci[1]=='b1)
                     if(deci[0]=='b1)
                   begin deci_ten<='b0100;deci_one<='b0100;end
                   begin deci_ten<='b0011;deci_one<='b1000;end
                    begin deci_ten<='b0011;deci_one<='b0001;end
                    begin deci_ten<='b0010;deci_one<='b0101;end
            if(deci[0]=='b1)
              begin deci_ten<='b0001;deci_one<='b1001;end
              begin deci_ten<='b0001;deci_one<='b0011;end
          begin deci_ten<='b0000;deci_one<='b0110;end
          begin deci_ten<='b0000;deci_one<='b0000;end
BCD--七段译码模块
module seven(i,y);
input[3:0] i;
output[6:0] y;
reg[6:0] y;
always @(i)
   case(i)
   'b0000:y<='b1111110;
   'b0001:y<='b0110000;
   'b0010:y<='b1101101;
   'b0011:y<='b1111001;
   'b0100:y<='b0110011;
   'b0101:y<='b1011011;
   'b0110:y<='b1011111;
   'b0111:y<='b1110000;
   'b1000:y<='b1111111;
   'b1001:y<='b1111011;
   default:y<='b1111111;
   endcase
麻烦大家了,帮帮我,老师说要我把他们三个整合到一块,然后仿真时序,最后做实测,说做不出来,就让我延期毕业,痛苦啊,谢谢谢谢大家了
calbvxeo 发表于 2014-6-3 20:47:46 | 显示全部楼层
Hon Billie Mother's Day p replica oakley sunglasse
Grateful heart , thank you, dear mother ! Mother's Day preferred gift for mom , not the clothing , not the jewelry , the truth is, accompanied by sons and daughters . To accompany her mother to dinner , and her mother together, that is the top gift for mom ! HON.B wish the entire planet red Billie 's mother Satisfied Mother's Day ! When Mother's Day approaching ,replica oakley sunglasses, red Billie as all mothers launched a Mother's Day celebration attire , let Xiaobian take you to appreciate it ! For kids and households,replica oakleys free shipping, every single mother is faded angel wings , will glory away, wash Magnificence , waiting with a primitive sight of eternal like , the guardian on the continuation of life . A comfortable and sophisticated dresses that can make her regain beauty. The classic diamond checkered skirt, with black openwork knit jacket , displaying a mature elegance. Mother's Day, Mother's really like for us to offer you the crucial to open the door towards the fantastic and let her really like , without worry of time , has been pretty down ...... WU Dandan
相关的主题文章:
   China's first men's Index - Index r replica oakley
GMT+8, 2026-5-23 10:28 , Processed in 0.033668 second(s), 22 queries .
