查看: 1266|回复: 0
用verilog写的程序老是出错,求大神帮解决
tianfuTOY 发表于 2014-5-23 12:02:16 | 显示全部楼层 |阅读模式
这是我的毕业设计,使用adderF_F.v和multFXF.v实现浮点数的加法和乘法用butter_2.v实现2点蝶形算子,用fft_16.v实现十六点FFT运算,前面三个都编译通过,并用MODELSIM进行了仿真,但是把前几个综合到一起是fft.v就老是说文件过大,不能编译通过并提示:Error:Out of memotu in module quartus_map.exe(2132 megabytes used),才开始觉得是因为计算机内存不足,可是加了一个内存条以后仍然无法编译通过(大概编译到20%就停了),下面是fft_16.v的代码,大神帮忙看一下,感激不尽!!!!!!
module fft_16 (
              clk,
              rst,
              butt16_real0,
              butt16_imag0,
              butt16_real1,
              butt16_imag1,
              butt16_real2,
              butt16_imag2,
              butt16_real3,
              butt16_imag3,
              butt16_real4,
              butt16_imag4,
              butt16_real5,
              butt16_imag5,
              butt16_real6,
              butt16_imag6,
              butt16_real7,
              butt16_imag7,
              butt16_real8,
              butt16_imag8,
              butt16_real9,
              butt16_imag9,
              butt16_real10,
              butt16_imag10,
              butt16_real11,
              butt16_imag11,
              butt16_real12,
              butt16_imag12,
              butt16_real13,
              butt16_imag13,
              butt16_real14,
              butt16_imag14,
              butt16_real15,
              butt16_imag15,
              y_real0,
              y_imag0,
              y_real1,
              y_imag1,
              y_real2,
              y_imag2,
              y_real3,
              y_imag3,
              y_real4,
              y_imag4,
              y_real5,
              y_imag5,
              y_real6,
              y_imag6,
              y_real7,
              y_imag7,
              y_real8,
              y_imag8,
              y_real9,
              y_imag9,
              y_real10,
              y_imag10,
              y_real11,
              y_imag11,
              y_real12,
              y_imag12,
              y_real13,
              y_imag13,
              y_real14,
              y_imag14,
              y_real15,
              y_imag15,
parameter RST_LVL = 1'b0;
input clk;
input rst;
input [31:0] butt16_real0;
input [31:0] butt16_imag0;
input [31:0] butt16_real1;
input [31:0] butt16_imag1;
input [31:0] butt16_real2;
input [31:0] butt16_imag2;
input [31:0] butt16_real3;
input [31:0] butt16_imag3;
input [31:0] butt16_real4;
input [31:0] butt16_imag4;
input [31:0] butt16_real5;
input [31:0] butt16_imag5;
input [31:0] butt16_real6;
input [31:0] butt16_imag6;
input [31:0] butt16_real7;
input [31:0] butt16_imag7;
input [31:0] butt16_real8;
input [31:0] butt16_imag8;
input [31:0] butt16_real9;
input [31:0] butt16_imag9;
input [31:0] butt16_real10;
input [31:0] butt16_imag10;
input [31:0] butt16_real11;
input [31:0] butt16_imag11;
input [31:0] butt16_real12;
input [31:0] butt16_imag12;
input [31:0] butt16_real13;
input [31:0] butt16_imag13;
input [31:0] butt16_real14;
input [31:0] butt16_imag14;
input [31:0] butt16_real15;
input [31:0] butt16_imag15;
output [31:0] y_real0;
output [31:0] y_imag0;
output [31:0] y_real1;
output [31:0] y_imag1;
output [31:0] y_real2;
output [31:0] y_imag2;
output [31:0] y_real3;
output [31:0] y_imag3;
output [31:0] y_real4;
output [31:0] y_imag4;
output [31:0] y_real5;
output [31:0] y_imag5;
output [31:0] y_real6;
output [31:0] y_imag6;
output [31:0] y_real7;
output [31:0] y_imag7;
output [31:0] y_real8;
output [31:0] y_imag8;
output [31:0] y_real9;
output [31:0] y_imag9;
output [31:0] y_real10;
output [31:0] y_imag10;
output [31:0] y_real11;
output [31:0] y_imag11;
output [31:0] y_real12;
output [31:0] y_imag12;
output [31:0] y_real13;
output [31:0] y_imag13;
output [31:0] y_real14;
output [31:0] y_imag14;
output [31:0] y_real15;
output [31:0] y_imag15;
wire [31:0] L1_real[15:0];
wire [31:0] L1_imag[15:0];
wire [31:0] L2_real[15:0];
wire [31:0] L2_imag[15:0];
wire [31:0] L3_real[15:0];
wire [31:0] L3_imag[15:0];
wire [31:0] L4_real[15:0];
wire [31:0] L4_imag[15:0];
wire [31:0] factor_real[7:0];
wire [31:0] factor_imag[7:0];
assign factor_real[0] =  32'd8192;
assign factor_imag[0] = 32'd0;
assign factor_real[1] =  32'd7568;
assign factor_imag[1] = 32'd3135;
assign factor_real[2] =  32'd5793;
assign factor_imag[2] = 32'd5793;
assign factor_real[3] =  32'd3135;
assign factor_imag[3] = 32'd7568;
assign factor_real[4] =  32'd0;
assign factor_imag[4] = 32'd8192;
assign factor_real[5] = -32'd3135;
assign factor_imag[5] = 32'd7568;
assign factor_real[6] = -32'd5793;
assign factor_imag[6] = 32'd5793;
assign factor_real[7] = -32'd7568;
assign factor_imag[7] = 32'd3135;
butter_2  ButtL1_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(butt16_real0 ),
          .butt2_imag0(butt16_imag0 ),
          .butt2_real1(butt16_real8 ),
          .butt2_imag1(butt16_imag8 ),
          .factor_real(factor_real[0]),
          .factor_imag(factor_imag[0]),
          .y0_real  (L1_real[0]    ),
          .y0_imag  (L1_imag[0]    ),
          .y1_real  (L1_real[8]    ),
          .y1_imag  (L1_imag[8]    )
butter_2  ButtL1_N2(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(butt16_real4 ),
          .butt2_imag0(butt16_imag4 ),
          .butt2_real1(butt16_real12 ),
          .butt2_imag1(butt16_imag12 ),
          .factor_real(factor_real[1]),
          .factor_imag(factor_imag[1]),
          .y0_real  (L1_real[4]    ),
          .y0_imag  (L1_imag[4]    ),
          .y1_real  (L1_real[12]    ),
          .y1_imag  (L1_imag[12]    )
butter_2  ButtL1_N3(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(butt16_real2 ),
          .butt2_imag0(butt16_imag2 ),
          .butt2_real1(butt16_real10 ),
          .butt2_imag1(butt16_imag10 ),
          .factor_real(factor_real[2]),
          .factor_imag(factor_imag[2]),
          .y0_real  (L1_real[2]    ),
          .y0_imag  (L1_imag[2]    ),
          .y1_real  (L1_real[10]    ),
          .y1_imag  (L1_imag[10]    )
butter_2  ButtL1_N4(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(butt16_real6 ),
          .butt2_imag0(butt16_imag6 ),
          .butt2_real1(butt16_real14 ),
          .butt2_imag1(butt16_imag14 ),
          .factor_real(factor_real[3]),
          .factor_imag(factor_imag[3]),
          .y0_real  (L1_real[6]    ),
          .y0_imag  (L1_imag[6]    ),
          .y1_real  (L1_real[14]    ),
          .y1_imag  (L1_imag[14]    )
butter_2  ButtL1_N5(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(butt16_real1 ),
          .butt2_imag0(butt16_imag1 ),
          .butt2_real1(butt16_real9 ),
          .butt2_imag1(butt16_imag9 ),
          .factor_real(factor_real[4]),
          .factor_imag(factor_imag[4]),
          .y0_real  (L1_real[1]    ),
          .y0_imag  (L1_imag[1]    ),
          .y1_real  (L1_real[9]    ),
          .y1_imag  (L1_imag[9]    )
butter_2  ButtL1_N6(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(butt16_real5 ),
          .butt2_imag0(butt16_imag5 ),
          .butt2_real1(butt16_real13 ),
          .butt2_imag1(butt16_imag13 ),
          .factor_real(factor_real[5]),
          .factor_imag(factor_imag[5]),
          .y0_real  (L1_real[5]    ),
          .y0_imag  (L1_imag[5]    ),
          .y1_real  (L1_real[13]    ),
          .y1_imag  (L1_imag[13]    )
butter_2  ButtL1_N7(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(butt16_real3 ),
          .butt2_imag0(butt16_imag3 ),
          .butt2_real1(butt16_real11 ),
          .butt2_imag1(butt16_imag11 ),
          .factor_real(factor_real[6]),
          .factor_imag(factor_imag[6]),
          .y0_real  (L1_real[3]    ),
          .y0_imag  (L1_imag[3]    ),
          .y1_real  (L1_real[11]    ),
          .y1_imag  (L1_imag[11]    )
butter_2  ButtL1_N8(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(butt16_real7 ),
          .butt2_imag0(butt16_imag7 ),
          .butt2_real1(butt16_real15 ),
          .butt2_imag1(butt16_imag15 ),
          .factor_real(factor_real[7]),
          .factor_imag(factor_imag[7]),
          .y0_real  (L1_real[7]    ),
          .y0_imag  (L1_imag[7]    ),
          .y1_real  (L1_real[15]    ),
          .y1_imag  (L1_imag[15]    )
butter_2  ButtL2_1_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L1_real[0] ),
          .butt2_imag0(L1_imag[0] ),
          .butt2_real1(L1_real[4] ),
          .butt2_imag1(L1_imag[4] ),
          .y0_real  (L2_real[0]    ),
          .y0_imag  (L2_imag[0]    ),
          .y1_real  (L2_real[4]    ),
          .y1_imag  (L2_imag[4]    )
butter_2  ButtL2_2_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L1_real[8] ),
          .butt2_imag0(L1_imag[8] ),
          .butt2_real1(L1_real[12] ),
          .butt2_imag1(L1_imag[12] ),
          .y0_real  (L2_real[8]    ),
          .y0_imag  (L2_imag[8]    ),
          .y1_real  (L2_real[12]    ),
          .y1_imag  (L2_imag[12]    )
butter_2  ButtL2_1_N2(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L1_real[2] ),
          .butt2_imag0(L1_imag[2] ),
          .butt2_real1(L1_real[6] ),
          .butt2_imag1(L1_imag[6] ),
          .y0_real  (L2_real[2]    ),
          .y0_imag  (L2_imag[2]    ),
          .y1_real  (L2_real[6]    ),
          .y1_imag  (L2_imag[6]    )
butter_2  ButtL2_2_N2(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L1_real[10] ),
          .butt2_imag0(L1_imag[10] ),
          .butt2_real1(L1_real[14] ),
          .butt2_imag1(L1_imag[14] ),
          .y0_real  (L2_real[10]    ),
          .y0_imag  (L2_imag[10]    ),
          .y1_real  (L2_real[14]    ),
          .y1_imag  (L2_imag[14]    )
butter_2  ButtL2_1_N3(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L1_real[1] ),
          .butt2_imag0(L1_imag[1] ),
          .butt2_real1(L1_real[5] ),
          .butt2_imag1(L1_imag[5] ),
          .y0_real  (L2_real[1]    ),
          .y0_imag  (L2_imag[1]    ),
          .y1_real  (L2_real[5]    ),
          .y1_imag  (L2_imag[5]    )
butter_2  ButtL2_2_N3(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L1_real[9] ),
          .butt2_imag0(L1_imag[9] ),
          .butt2_real1(L1_real[13] ),
          .butt2_imag1(L1_imag[13] ),
          .y0_real  (L2_real[9]    ),
          .y0_imag  (L2_imag[9]    ),
          .y1_real  (L2_real[13]    ),
          .y1_imag  (L2_imag[13]    )
butter_2  ButtL2_1_N4(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L1_real[3] ),
          .butt2_imag0(L1_imag[3] ),
          .butt2_real1(L1_real[7] ),
          .butt2_imag1(L1_imag[7] ),
          .y0_real  (L2_real[3]    ),
          .y0_imag  (L2_imag[3]    ),
          .y1_real  (L2_real[7]    ),
          .y1_imag  (L2_imag[7]    )
butter_2  ButtL2_2_N4(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L1_real[11] ),
          .butt2_imag0(L1_imag[11] ),
          .butt2_real1(L1_real[15] ),
          .butt2_imag1(L1_imag[15] ),
          .y0_real  (L2_real[11]    ),
          .y0_imag  (L2_imag[11]    ),
          .y1_real  (L2_real[15]    ),
          .y1_imag  (L2_imag[15]    )
butter_2  ButtL3_1_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L2_real[0] ),
          .butt2_imag0(L2_imag[0] ),
          .butt2_real1(L2_real[2] ),
          .butt2_imag1(L2_imag[2] ),
          .y0_real  (L3_real[0]    ),
          .y0_imag  (L3_imag[0]    ),
          .y1_real  (L3_real[2]    ),
          .y1_imag  (L3_imag[2]    )
butter_2  ButtL3_2_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L2_real[4] ),
          .butt2_imag0(L2_imag[4] ),
          .butt2_real1(L2_real[6] ),
          .butt2_imag1(L2_imag[6] ),
          .y0_real  (L3_real[4]    ),
          .y0_imag  (L3_imag[4]    ),
          .y1_real  (L3_real[6]    ),
          .y1_imag  (L3_imag[6]    )
butter_2  ButtL3_3_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L2_real[8] ),
          .butt2_imag0(L2_imag[8] ),
          .butt2_real1(L2_real[10] ),
          .butt2_imag1(L2_imag[10] ),
          .y0_real  (L3_real[8]    ),
          .y0_imag  (L3_imag[8]    ),
          .y1_real  (L3_real[10]    ),
          .y1_imag  (L3_imag[10]    )
butter_2  ButtL3_4_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L2_real[12] ),
          .butt2_imag0(L2_imag[12] ),
          .butt2_real1(L2_real[14] ),
          .butt2_imag1(L2_imag[14] ),
          .y0_real  (L3_real[12]    ),
          .y0_imag  (L3_imag[12]    ),
          .y1_real  (L3_real[14]    ),
          .y1_imag  (L3_imag[14]    )
butter_2  ButtL3_1_N2(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L2_real[1] ),
          .butt2_imag0(L2_imag[1] ),
          .butt2_real1(L2_real[3] ),
          .butt2_imag1(L2_imag[3] ),
          .y0_real  (L3_real[1]    ),
          .y0_imag  (L3_imag[1]    ),
          .y1_real  (L3_real[3]    ),
          .y1_imag  (L3_imag[3]    )
butter_2  ButtL3_2_N2(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L2_real[5] ),
          .butt2_imag0(L2_imag[5] ),
          .butt2_real1(L2_real[7] ),
          .butt2_imag1(L2_imag[7] ),
          .y0_real  (L3_real[5]    ),
          .y0_imag  (L3_imag[5]    ),
          .y1_real  (L3_real[7]    ),
          .y1_imag  (L3_imag[7]    )
butter_2  ButtL3_3_N2(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L2_real[9] ),
          .butt2_imag0(L2_imag[9] ),
          .butt2_real1(L2_real[11] ),
          .butt2_imag1(L2_imag[11] ),
          .y0_real  (L3_real[9]    ),
          .y0_imag  (L3_imag[9]    ),
          .y1_real  (L3_real[11]    ),
          .y1_imag  (L3_imag[11]    )
butter_2  ButtL3_4_N2(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L2_real[13] ),
          .butt2_imag0(L2_imag[13] ),
          .butt2_real1(L2_real[15] ),
          .butt2_imag1(L2_imag[15] ),
          .y0_real  (L3_real[13]    ),
          .y0_imag  (L3_imag[13]    ),
          .y1_real  (L3_real[15]    ),
          .y1_imag  (L3_imag[15]    )
butter_2  ButtL4_1_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L3_real[0] ),
          .butt2_imag0(L3_imag[0] ),
          .butt2_real1(L3_real[1] ),
          .butt2_imag1(L3_imag[1] ),
          .y0_real  (L4_real[0]    ),
          .y0_imag  (L4_imag[0]    ),
          .y1_real  (L4_real[1]    ),
          .y1_imag  (L4_imag[1]    )
butter_2  ButtL4_2_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L3_real[2] ),
          .butt2_imag0(L3_imag[2] ),
          .butt2_real1(L3_real[3] ),
          .butt2_imag1(L3_imag[3] ),
          .y0_real  (L4_real[2]    ),
          .y0_imag  (L4_imag[2]    ),
          .y1_real  (L4_real[3]    ),
          .y1_imag  (L4_imag[3]    )
butter_2  ButtL4_3_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L3_real[4] ),
          .butt2_imag0(L3_imag[4] ),
          .butt2_real1(L3_real[5] ),
          .butt2_imag1(L3_imag[5] ),
          .y0_real  (L4_real[4]    ),
          .y0_imag  (L4_imag[4]    ),
          .y1_real  (L4_real[5]    ),
          .y1_imag  (L4_imag[5]    )
butter_2  ButtL4_4_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L3_real[6] ),
          .butt2_imag0(L3_imag[6] ),
          .butt2_real1(L3_real[7] ),
          .butt2_imag1(L3_imag[7] ),
          .y0_real  (L4_real[6]    ),
          .y0_imag  (L4_imag[6]    ),
          .y1_real  (L4_real[7]    ),
          .y1_imag  (L4_imag[7]    )
butter_2  ButtL4_5_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L3_real[8] ),
          .butt2_imag0(L3_imag[8] ),
          .butt2_real1(L3_real[9] ),
          .butt2_imag1(L3_imag[9] ),
          .y0_real  (L4_real[8]    ),
          .y0_imag  (L4_imag[8]    ),
          .y1_real  (L4_real[9]    ),
          .y1_imag  (L4_imag[9]    )
butter_2  ButtL4_6_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L3_real[10] ),
          .butt2_imag0(L3_imag[10] ),
          .butt2_real1(L3_real[11] ),
          .butt2_imag1(L3_imag[11] ),
          .y0_real  (L4_real[10]    ),
          .y0_imag  (L4_imag[10]    ),
          .y1_real  (L4_real[11]    ),
          .y1_imag  (L4_imag[11]    )
butter_2  ButtL4_7_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L3_real[12] ),
          .butt2_imag0(L3_imag[12] ),
          .butt2_real1(L3_real[13] ),
          .butt2_imag1(L3_imag[13] ),
          .y0_real  (L4_real[12]    ),
          .y0_imag  (L4_imag[12]    ),
          .y1_real  (L4_real[13]    ),
          .y1_imag  (L4_imag[13]    )
butter_2  ButtL4_8_N1(
          .clk        (clk         ),
          .rst        (rst         ),
          .butt2_real0(L3_real[14] ),
          .butt2_imag0(L3_imag[14] ),
          .butt2_real1(L3_real[15] ),
          .butt2_imag1(L3_imag[15] ),
          .y0_real  (L4_real[14]    ),
          .y0_imag  (L4_imag[14]    ),
          .y1_real  (L4_real[15]    ),
          .y1_imag  (L4_imag[15]    )
assign y_real0 = L4_real[0];
assign y_imag0 = L4_imag[0];
assign y_real1 = L4_real[8];
assign y_imag1 = L4_imag[8];
assign y_real2 = L4_real[4];
assign y_imag2 = L4_imag[4];
assign y_real3 = L4_real[12];
assign y_imag3 = L4_imag[12];
assign y_real4 = L4_real[2];
assign y_imag4 = L4_imag[2];
assign y_real5 = L4_real[10];
assign y_imag5 = L4_imag[10];
assign y_real6 = L4_real[6];
assign y_imag6 = L4_imag[6];
assign y_real7 = L4_real[14];
assign y_imag7 = L4_imag[14];
assign y_real8 = L4_real[1];
assign y_imag8 = L4_imag[1];
assign y_real9 = L4_real[9];
assign y_imag9 = L4_imag[9];
assign y_real10 = L4_real[5];
assign y_imag10 = L4_imag[5];
assign y_real11 = L4_real[13];
assign y_imag11 = L4_imag[13];
assign y_real12 = L4_real[3];
assign y_imag12 = L4_imag[3];
assign y_real13 = L4_real[11];
assign y_imag13 = L4_imag[11];
assign y_real14 = L4_real[7];
assign y_imag14 = L4_imag[7];
assign y_real15 = L4_real[15];
assign y_imag15 = L4_imag[15];
GMT+8, 2026-5-23 10:32 , Processed in 0.042930 second(s), 21 queries .
